Question about Retail Supplies
Re Verifone Omni 3470 Pat # Omni M197-410-14-US 1 What are the specks for voltage and amps? (also called "Raging") Might be 22-26VDC 1.5A. Could you help?
    Scholar:
    New Friend:
  • 154 Answers
Are you missing the power adaptor? input range is AC 100V - 240V
Posted on Feb 11, 2015
  • 6 Answers
SOURCE: Verifone Omni 3750, set up problem
Your processor should be able to essentially blow out the memory on the terminal. From their a dummy program can be loaded to finish wiping out any residual memory. Lastly, you will need to do a completely new core load with your actual file build. The process takes much longer than normal due to the multiple core loads but it is effective. If your processor is not familiar with this or is unable, I would be more than happy to take over your services but am unable to solicit on this site. So, feel free to email me with any questions you may have at CJepson@federal-financial.com. Hope this helps.
Posted on Aug 28, 2008
SOURCE: verifone omni 3750
Use this Master Password from the manufacture #23378463
Posted on Mar 22, 2009
SOURCE: Need help hooking up pin pad
Simply plug the PIN pad cable into the comm port on the back of the terminal marked with a PIN pad symbol. As far as programming, has this PIN pad been injected with the proper encryption key? If you bought it right off the shelf, you will need to send it to your payment services provider for key injection.
Posted on Jul 02, 2009
  • 5 Answers
SOURCE: verifone omni 3740
Most likely:
1, alpha, alpha (little gray button between the four purple keys), 66831, enter
Posted on Jul 31, 2009
  • 37 Answers
SOURCE: need to reset password for verifone omni 3740
If you press the F2 and F4 buttons and enter 1 Alpha Alpha 66831 and the terminal goes back to the idle screen then the system password has been changed or the battery is bad in the unit and will have to be replaced. Either way it will have to go to a repair facility to be corrected.
Posted on Oct 08, 2009
Change battery in verifone 3730
battery is located inside the machine. You need to open the plastic case to see it. 7 screws holding the case together, but be careful not to break the case, multiple sensors inside the unit, don't loose it. If you still needs help, call us at (775) 358-2922 ask for Randy. http://freshpoint.org
Oct 05, 2012 | VeriFone Omni 3700
I'm trying to reset the Group 1 password on my Verifone Omni 3750
The password on most vx510's can be reset by pulling battery and clearing RAM. Reassemble, clear Tamper and password will reset to original password (1aa66831). But if the certificate has been changed, only your download provider can help you. Call Frank @ 775-338-6634
Jun 08, 2011 | VeriFone Omni 3700
Verifone Omni 3730 says "Bad RTC Chip. Please Reboot". How do I reboot?
The "RTC chip" is an integrated circuit that provides the R(eal) T(ime) C(lock) functionality. If your device cannot keep the correct date & time, it's time to replace it.
To reboot, turn the device off, and then remove the battery.
Wait 60 seconds, reinsert the battery, and turn the device on.
Aug 20, 2010 | VeriFone Omni 3700
My Omni 3730/3730LE VeriFone printer does not print on the paper
Ensure thermal paper is being fed from underneath the roll, as it will only print on one side of the paper. hope this help
Jan 16, 2010 | VeriFone Omni 3700
I have a verifone omni 3750 . It has a continuous
The continuous beep indicates a break in the PED (pin entry device) connections on the main board or the PED fence is bad. It will need repair by a reputable repair facility.
Oct 06, 2009 | VeriFone Omni 3700
I am looking for a users guide for the Verifone Omni 3200
In PDF Format:
Download the quick reference operation manual for Verifone Omni 3200
Download the complete operations manual for the Verifone Omni 3200
Feb 21, 2009 | VeriFone Omni 3200 Printer
FILE ERROR VSCPT .DAT VERIFON OMNI 3200SE
You need to call your merchant services provider's tech support dept and have the terminal redownloaded, or a new file built.
Dec 08, 2008 | VeriFone OMNI 3200 (P092-101-10) Printer
Verifone omni 3740
Most likely:
Sep 23, 2008 | VeriFone Omni 3700
Verifone omni 3750
here's some passwords you can Try: 1, 0000, 1234, 1701, 1739, 000000, 12345, 998877, 123456, 752036, 23378463, 45803155, 53664337, 1[Alpha][Alpha]66831, 6[Alpha]78727[Alpha][Alpha], Hope this help if not call us @ 775- 358-2922 : - )
Jul 09, 2008 | VeriFone Omni 3700
Error message
Start by calling the processor help desk and see if they can reload the application. If they can't, you will need a new unit.
May 02, 2008 | VeriFone OMNI 3200 (P092-101-10) Printer
Retail Supplies Logo
55 people viewed this question
Top Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Retail Supply Expert? Answer questions, earn points and help others
