Question about Hitachi 42HDS69 42 in. Plasma Television
Why does my Hitachi 42HDS69 have horizontal green lines all the way across the screen? The sound is fine. The lines are not solid, they dotted-like, like snowy and are not thin. It started all at once when the tv was turned on. It was my son's TV so I know it's not had a firmware update. Could this be the problem? I have checked all the connections and did the trouble shooting to no avail.
    Top Expert:
  • Hitachi Master
  • 74,251 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Posted on Dec 14, 2014
Why does my Hitachi 42HDS69 42 inch Plasma TV have horizontal green lines across the screen? I have checked all connections and tried to tweek the color settings but nothing has helped. I went thru th
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 13, 2014 | Hitachi 42HDS69 42 in. Plasma Television
Msi L1350d screen has tiny horizontal lines
If it works fine when you connect to your tv then you've probably got a loose cable on the screen. You'll have to strip it to check.
Mar 29, 2014 | MSI L1350D-1672US Netbook
Dell inspiron laptop grey dotted line across
You could try removing the display device in device manager then rebooting. At boot up windows will reinstall the drivers.
Check for new display drivers at Dell's support site.
Mar 13, 2014 | Dell Inspiron E1505 Notebook
Hitachi 42HDS69 verticle green line thru center. just started about 2 days ago. what is this from? can I fix myself?
Maybe only is dirty conection.
You need diss. the back cover and look for a dirty conection near the edge of the screen, disconect and clean w. isopro alcohol all conections and reconect.
Sep 24, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Solid vertical black line on my hitachi 42"plasma towards the left quarter of screen.bout an inch an a half thick.
This will be a block defect caused either by one of the flat flexible connectors to the screen giving a poor contact or a fault within the screen itself, which result in a replacement screen required
Sep 22, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Sony 65" Rear Projection loses picture, then gets diagonal lines
This is common problem on this tv, picture tube is bad. Blue and green is more % bad.
Thank you
Aug 07, 2009 | Hitachi 51F59 51" HDTV Projection...
Yellow stripe across middle of the picture
yes rteh color of the wires(ends)red,blue,green,sounds like they may ahve gone bad or are interchanged, what does it do with a dvd picture
May 23, 2009 | Hitachi 42V710 42" Rear Projection HDTV
42HDS69 42 in. Plasma has several thin green vertical lines in middle of screen
If the set is still in warranty, call for warranty service. If not and you feel comfortable working on the set, carefully open up the back and reseat all of hte cables and connectors. This can be caused by marginal connections inside the set.
Keep us posted on your progress and results.
Dan
Aug 29, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Hitachi Plasma Model PD32-A3000/AVC-A3000
vertical red line on screen - I have a Hitachi plasma 42HDs69
Jul 29, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Green horizontal lines across screen
try adjusting the green screen control. remove the front bottom panel of the tv by removing any screws holding it in place. gently pull of the front panel, there are gromets holding it in place, you will be able to gently remove the front, just make sure you get all those screws. now reove the small wodden or plastioc panel. now you will see the screen/focus assy. check to see of the screen controls are the top 3 or bottom 3. adjusted the center screen it's the green one, the other 2 are the red & blue. it is best to adjust in a dark room where the lines will show up easier. good luck
Dec 19, 2006 | Hitachi 43FDX01B TV
Hitachi 42HDS69 42 in. Plasma Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
