Question about KitchenAid Dishwashers
My dishwasher will work only on "baked on cookware" cycle. What is wrong??
Model KUDS01IJ It does not work on any cycle other than "baked on cookware"
  • KitchenAid Master
  • 3,382 Answers
Your timer or control unit whatever you want to call it has probably failed.
Posted on Dec 14, 2014
The detergent is not coming out of the dispenser, when I use capsules or powder. What could be wrong?
If the dispenser has soap "crud" around the latch area that could be the cause. Thake a stiff bristle brush and scrub it using a bit of Dawn and water get it clean as possible and try it again. I found that switching to a clear liquid helped me.
May 11, 2014 | KitchenAid KUDS01IJ - Multiple Color...
Can visionware go in oven
The short answer is YES!
In the 1990's Corning produced a series of Visions cookware, brown amber and cranberry colored glass-ceramic dishes and casseroles, that had the same basic properties of its white Pyroceram cookware. Visions cookware could go directly from freezer to hot oven to stove-top to the microwave oven to table to fridge to the broiler to the dishwasher, etc. Extreme temperature changes did not affect the very durable cookware, While many folks mistake Visions cookware for Pyrex bake-ware, they are not the same. Visions cookware was never issued in the forms (square pans, rectangle baking pans, loaf pans, pie pans, etc that clear glass Pyrex baking pans had been produced in for decades. In any case, Visions glass-ceramic cookware could go direct from the freezer to the hot oven - there would be NO DAMAGE to the cookware in such a practice. Visions glass-ceramic cookware also has markings to indicate usage. The majority of Visions cookware were of the "stove pot" design - stove top was intended from the start. However it is practical to let the food defrost first, or adjust the cooking time in order to create a better thoroughly cooked dish.
Yes, Visions cookware can be used in the oven! One caveat is that the pot lids are Pyrex which means that the pot lids can not be placed under the broiler (who does that anyway?), or under direct heat, or while hot on wet surfaces. The pot lids were meant to be pot lids - just like other Pyrex glass pot lids on most cookware.
Apr 17, 2014 | CorningWare Microwave Ovens
There are soapsuds in the bottom of the dishwasher when the cycle is done
This sounds like the dishwasher got the wrong type of soap. It is a real problem to get the wrong soap rinsed out..follow the directions given by the repairman..it may take 5 or 6 cycles... The jet dry is just an extra in this issue...it will be okay when the soap is fully rinsed out.
Feb 02, 2013 | KitchenAid Architect? II K SERIES KUDK03IT...
The child lock is on and I can't remember what buttons to use to turn it off......
Press and hold the 'Heated Dry' button for 4 seconds. it should turn off. If that does not work let me know.
Apr 25, 2010 | KitchenAid KUDS01IJ - Multiple Color...
Cancel light and rinse only light keep blinking and wont start
Hopefully you have resolved your issue. I have not heard of the cancel light flashing issue. I have had problems with the clean light flashing seven times over and over and the control panel will not operate. Here is the solution to that. Maybe it will work for your issue as well.
Open dishwasher door,
Push Hi Temp Scrub button,
Push Saver Dry button,
Push Hi Temp Scrub button again,
Push Saver Dry button again,
All lights on control panel will come on.
Close dishwasher door,
Push Baked on Cookware or Normal Button.
Dishwasher should start and complete cycle.
It is good if you have kids that play video games. Their fingers are used to pushing buttons quickly. I guess this resets the control board. The service guy let me have this info as I used to deliver appliances and work on them somewhat.Hope this helps.
Good Luck,
Tom
Nov 26, 2008 | KitchenAid 24 in. KUDS01FLSS Built-In...
Kitchen Aid diswasher controls don't work
The Button is part of a switch control (all the buttons are individual switches) - take the switch block out of the door and test the button (switch)for circuit continuity, if it is OK, then the timer control may be the problem. My machine had progressive failures through the various cycles until most do not work and it wa the timer that was failing bit by bit.
Dec 20, 2006 | KitchenAid 24 in. KUDI02FRSS Stainless...
Dishwashers Logo
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
