Question about Ipcw Ford F150 / F250 Ld 1999 2000 2001 2002 2003 Fog Lights Projector W/ Halo Clear-1 Pair
How do you change a door code to a 2002 ford f150
  • 28 Answers
I believe your factory code is located on the RAP module (i think its a white or grey box) located under the dash on the driver side above the emergency brake area for the 02 model. There will be a five digit code on the module. The tag with the code might not be visible and you may have to unbolt the module to see it. There also might be a card in the glove box.
1. Enter the factory set code
2. Press the 1/2 key within 5 seconds of doing step 1
3. Enter your personal 5 digit code within 5 seconds of step 2
Setting your personal code does not erase the factory code. You can use either your code or the factory code to unlock the door.
Posted on Dec 14, 2014
How do I find keyless entry code 2002 f150
usually there is a card with the owners manual with a defult code on it if not then you will have to go to a ford dealer and they should be able to get the defult code by the vin number
Feb 24, 2015 | Ford F-150 Cars & Trucks
How to change fuel pump fuse 2002 ford f150
go to 2002 ford f150 owners manual and download it free from ford then go inside the manual to road side emergencies the fuse diagrams for the passenger and power distribution box are there and so is the fuse location also check for fuel inertia switch in case you got hit and press the reset button in and the car will start again
Feb 17, 2015 | 2002 Ford F150 Regular Cab
My 2002 Ford f150
May be an idle air motor doing this.
Apr 27, 2014 | 2002 Ford F150 Regular Cab
Engine misfire first 1000 rpm, engine flooding out, check engine light is on but flashes when in motion, scanner shows system too lean bank 1 and 2. shows multiple cylinder fault codes.. (FORD F-150...
my 2002 ford f150 4.2 would not hold idle so we changed the fuel pump and fuel filter and relay now the truck starts holds idle runs good at low rpm but when i stomp it it runs then stalls and picks up again.
Dec 05, 2010 | 2002 Ford F150 Regular Cab
2002 ford f150 xl 4.6 litre code p0316
Do you have another code in addition to this ?
The P0316 DTC is Misfire Detected On Startup (First 1000 Revolutions), which usually has another code set in addition to the P0316 code.
Nov 15, 2010 | 2002 Ford F150 Regular Cab
How to change the lock code on the door
The owners manual has directions on changing or adding a personal code.
If you are talking about the factory code, the only way to do this, is to replace the CSM ( Central Security Module, mid 2000 MY and older it was called a RAP - Remote Antitheft Personality )
A RAP and CSM are not 1 for 1 pin compatible, so if you go to a junk yard for a new CSM, make sure the build date on the truck is 2-OCT-2000 or newer ( up to a 2004 Heritage or Lightning, not the new body style 2004 ).
The CSM is up behind the dash on the driver's side.
The CSM is the white color box center of this picture, that is the parking brake on the left side of the picture.
If you did not get an owners manual with your truck ( purchased used ), you can download one from Ford :
https://www.fleet.ford.com/maintenance/owners_manuals/default.asp
The setting a Personal Code for the door keypad starts on page 111 in the 2002 owners manual.
Oct 25, 2010 | 2002 Ford F150 Regular Cab
2002 ford f150 4.2 is not starting has feul pressure ,spark on wires yet wont start
i would start off by scanning computer for codes,thses codes can help in the diagnoses, the next thing if there are no codes is to check for injector pulse at the injector.
May 12, 2010 | 2002 Ford F150 Regular Cab
Program a new fob to my 2002 f150 supercrew lariat 5.4L remote lock/start system
if it is a ford remote or ford factory alarm remote cycle the key from off to run(usually 8 times) untill you hear door locks activate. at this exact time key needs to be in the on position.touch unlock or lock on all remotes being programmed and make sure door locks respond to remotes. then turn key off ending programming mode.then try your fobs they should work
Nov 06, 2009 | 2002 Ford F150 Regular Cab
Replace Passenger Side Mirror on 2002 Ford F-150
On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you'll need to manipulate the panel and disconnect the door handle linkage from the door handle and disconnect the wiring for your controls. Then you can access the bolts that secure the mirror onto the door
Mar 27, 2009 | 2002 Ford F150 Regular Cab
Trouble code
please add the engine size in order to answer your question
Jun 03, 2008 | 2002 Ford F150 Regular Cab
Ipcw Ford F150 / F250 Ld 1999 2000 2001 2002 2003 Fog Lights Projector W/ Halo Clear-1 Pair Logo
62 people viewed this question
Top Ipcw Office Equipment & Supplies Experts
Robert McCall
Robert McCall
 Russ Hill
Russ Hill
Joel C.
Joel C.
Are you an Ipcw Office Equipment and Supply Expert? Answer questions, earn points and help others
