Question about Sony Audio Players & Recorders
Sony Amp STR-DN1030 stuck in network update loop
Failed network update, unable to get it back to use/default powers off then on, tries to update, fails, Did a reset and per Sony Instructions, all settings reset, still stuck in network loop. Was advised needs to go back to Sony no big deal has warranty but surely there must be on field fix for this. Cheers
  • Sony Master
  • 3,368 Answers
By the time you figure it out you will have more time in it then it is worth and the warranty has an expatriation date. If you fail to fix it you void the warranty as well.
Posted on Dec 14, 2014
Testimonial: "All well and good. I cant believe that this problem needs to go Back for a fix, In this day and age you can push a heap of buttons in a certain way things happen. I guess It is what it is. Thanks"
Sony STR-DG710 center speaker makes no sound. Connections are good.
Sometimes these units have the ability to switch the speaker off and on. Look up the speaker settings in the manual.
As each channel in the unit will be separately driven the power amp for the center channel could have failed, but I think it's unlikely unless you have had problems with the sound on it before, or connected it wrongly causing a fault.
Dec 16, 2016 | Sony STR-DG710 Receiver
What would cause new fuse to blow when powering on (Sony STR-DN1030 Receiver).
Look in the circuit board area where the power cord mates with it for capacitors that have bulging tops (instead of the flat tops that are normal). If you see even one, you need to replace all the large capacitors othe power supply section (normally around 5 or 6).
Dec 08, 2014 | Sony STR-DN1030 7.2-Ch. Wi-Fi Network A/V...
HP mediasmart EX470
Hello it depends on your current operating system.This could have happend after the update from MS yesterday.
It looks like a failed update.
Here is a link if you are running server 2008:
http://serverfault.com/questions/362759/server-2008-stuck-in-reboot-loop-configuring-updates-stage-3-of-3
Good luck
Nov 13, 2012 | HP MediaSmart Server EX470 (GG795AA)
PS3 + UPDATE = bad for me
Sounds like your stuck in a firmware update loop.
See what happens when you boot the PS3 with the hard drive out.
Do you still get the same menu on screen?
Jun 19, 2009 | Sony Playstation 3 (PS3) Console
Carried out an update, but now stuck in loop
Procedure for Entering Safe mode when PS3 is caught in update loop:
When you first turn on the PS3, it will not allow you to go into Safe mode. You must prepare it for this.
link for flash drive prep:
http://www.us.playstation.com/Support/SystemUpdates/PS3/pc_update.html#update_PC
(This will not work for the drive that currently is caught in the update loop. You must take the hard drive out of the PS3 and temporarily replace it with another 2.5” SATA drive. Note: temp drive may need to be initialized… Connect drive to pc, right click on My Computer and select Manage… Then select disk Management… you will then be presented with a dialogue box that will assist in initializing the disk.. However, only initialize it… Do Not Format it!(waste of time) Once the disk is initialized disconnect it from external enclosure or shut down computer and remove disk)
From the top:
1.) Plug in PS3 and flip switch in back of PS3 to on. Red LED in front of PS3 should light up. Also, plug in Controller at this point.
2.) Hold finger to I/O button on front of PS3 – Green LED lights up
a. You will hear one beep, then another single beep, then a final beep and the PS3 will power off again and Red LED will be on
3.) Hold finger to I/O button on front of PS3 – Green LED lights up
a. You will hear one beep, then another single beep, then two beeps
4.) As soon as you hear the two beeps, hold PS button on Controller
a. You will then be presented with an options screen
i. Restart System -- leads back to update loop
ii. Restore Default Settings --
iii. Restore File System -- leads back to update loop (8002F14E)
iv. Rebuild Database --
v. Restore PS3 System --
vi. System Update -- will cause error
5.) You will then remove the temporary SATA drive from the PS3 and replace it with the hard drive that is caught in the update loo
6.) I am currently stuck attempting to Restore Default Settings and Im sure it will end in error, but i have to try all possible solutions.
Jun 16, 2009 | Sony Playstation 3 (PS3) Console
PC gets stuck in a sound loop, monitor goes black.
It ended up being the video card. I got it replaced and the new one is fine.
Dec 03, 2008 | Computers & Internet
Restarting problem or looping
update your phone via sony update service. your problem would get solved
Aug 15, 2007 | Sony Ericsson P990i Smartphone
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
