Question about Whirlpool Dishwashers
My whirlpool adp2304 powered off and did not fully drain at the end of a programme. It now doesn't even power on. No lights at all. Is there a fail safe mode or reset?
    New Friend:
    Problem Solver:
  • 8 Answers
Then it is a costly repair. The pump was damaged, and leaked water onto the electric motor causing it to be bad. Therefore it is cheaper to cut your losses and get a new dish washer. I have had three to meet their untimely end, due to broken glass getting into the pump, breaking it and destroying the electric motor. You can fix it, but the repair costs are almost as much as a new one, if you count in the cost of parts, labor and fees.
Posted on Dec 16, 2014
Vec010s
Most likely that is the issue.
May 17, 2013 | JUMP START SYSTEM
Door remains locked and machine doesn't start running
Did you check and see if the child lock is active?
Mar 25, 2017 | Zanussi FJ1254W Front Load Washer
Battery fully charged, bike turned on after, but on 2nd try after couple of hours, no power
Based on what you've said here I would say that either the battery is incapable of maintaining a charge or something is draining the battery. To test to see if something is draining it, disconnect the positive cable and put an ameter between the cable and the battery to see what current is being 'used' when the ignition switch is off. It should read ZERO amps. If there is current flowing then something is draining the battery - pull fuses to find the culprit. If the drain shows ZERO amps then it's possible the battery is tired and needs to be replaced. Motorcycle batteries don't usually last more than a few years.
I hope this helped. Sorry for any typos.
Scott
Nov 15, 2011 | Motorcycles
Hi, We have a G638 plus and have it connected to the cold water tap. When we press start, it fills the machine with water and once the machine has been filled, the program doesn't start and after 2-3...
Hi
Intake/Drain light flashing means an issue while draining. You would need to check for air gap on the dishwasher, it may be clogged. It prevents dishwasher from draining, sometimes the drain flow is restricted due to gunk. Cleaning or bypassing the air gap will resolve the issue. If this doesn't resolve the issue then it is due to seized (or stuck) drain pump. Disconnect the power to the dishwasher or turn off the breaker to the dishwasher. Tip machine on its back; remove screws that hold the bottom tray on. Remove the hoses to the main motor, remove electrical connections & remove motor (single screw holds motor, it is on the outside back of the machine). Try to rotate the motor (use WD40 is necessary). If you cannot rotate it, then motor will be required. If the error still appears then cancel the error message, turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs. Switch the appliance off and then back on again. Hope this helps... Please post back if you need more information.
Daniel
Aug 16, 2011 | Miele 24 in. G638 Plus Free-standing...
My dishwasher doesn`t drain. there is water at the bottom at te end of every wash... what`s wrong? how can i fix it?
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 06, 2011 | Whirlpool Dishwashers
Hello! Have had combined washer/dryer V4380XOGB for past 15 years. Used only infrequently over the years (this is our holiday home). Washing programme works perfectly, but after using the drying programme...
You might have already done what follows - you do not mention a filter- but just in case ->
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 18, 2011 | Neff V4380X0 Front Load Washer / Dryer
No dash lights, power locks don't work, fuel gadge doesn't work, radio doesn't work.
all these circuits share some common fuses, check fuse #6 ( 10 amp ), fuse # 11 ( 15 amp ) & fuse #12 ( 10 amp ) all in the inside fuse box at the left end of the dash.....good luck
Jun 20, 2011 | 2000 Mitsubishi Diamante
My Whirlpool Quiet Partner II will not drain at the end of the final cycle.
Hi
Daniel
Jun 16, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
131 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
