Question about Tablets & eReaders
How can I get ispq on the surface tablet - Tablets & eReaders
Returning tablet. How do I erase everything and restore factory reset???
hi Deanna.
this is all i could find.
  1. Power off your Tablet.
  2. Press and hold Volume up and Power button at the same time until you boot into the Android system recovery. ...
  3. Choose Wipe data/Factory Reset with your volume keys and then press the power button to confirm.
More items...
Perform a factory reset on Android Device - VisiHow
visihow.com/Perform_a_factory_reset_on_Android_Device
How do you reset a Windows tablet?Reset from within WindowsPlug in your Surface so you don't run out of power during the refresh.Swipe in from the right edge of the screen, and select Settings > Change PC settings.Select Update and recovery > Recovery.Under Remove everything and reinstall Windows, select Get started > Next.More items...Refresh or reset Surface RT or Surface 2 - Microsoft Supporthttps://support.microsoft.com/en-us/help/.../surface-refresh-or-reset-surface-rt-or-surface...Search for: How do you reset a Windows tablet?
How do you do a hard reset on a Samsung tablet?Method 1: From StartupWith the device off, press and hold the "Volume Up", "Home", and "Power" buttons.Release the buttons when you see the recovery screen and the Samsung logo.Use the volume buttons to navigate the menu and select "wipe data / factory reset". ...On the next screen, press "Volume Up" to continue.Samsung Galaxy Tab 4: Steps For Hard Reset - Technipageshttps://www.technipages.com/galaxy-tab-4-hard-resetSearch for: How do you do a hard reset on a Samsung tablet?
How do you restore a Galaxy tablet to factory settings?In fact, consider finding support before you start the following process:Start the Settings app, found in the Apps Menu.Choose Privacy.Choose Factory Data Reset.Touch the Reset Tablet button.Touch the Erase Everything button to confirm. All the information you've set or stored on the Samsung Galaxy Tab is purged.How to Reset the Samsung Galaxy Tab to Factory Settings - dummieswww.dummies.com/...galaxy.../how-to-reset-the-samsung-galaxy-tab-to-factory-settings/Search for: How do you restore a Galaxy tablet to factory settings?
if none of the above work go to this link might help you out more.
tablet factory reset Google Search
Nov 22, 2017 | Tablets & eReaders
Dont f9999 know my password is anyone please going to help?
What is your question? Did you forget your password to open your Surface? If so, please follow the directions in this link.
Microsoft Surface Tablets
Feb 14, 2015 | Microsoft Surface 2 with 32GB
How to add Netflix app to surface 2 tablet
If you have a Surface RT you can only go through the Windows Store and search for "Netflix", then install it. You can also always just to go www.netflix.com from your device and log in to enjoy your Netflix.
If you don't have the RT version, you can just download the Netflix application from www.netflix.com and run it to install.
Happy Netflixing!
Feb 10, 2015 | Microsoft Surface 2 with 32GB
How do I get sky go to work on my Microsoft surface tablet
As far as I can tell Sky Go is not yet supported by Microsoft Surface Tablets running Windows 8.1. They haven't developed an App for the Windows Store yet as far as I know.
Oct 23, 2014 | Microsoft Surface RT
Is it possible to transfer pictures from a memory card to the surface rt tablet
Use either microSD card (Surface has a slot for this card), or SD card with USB adapter. This way it is easy to transfer pictures .
Oct 14, 2014 | Microsoft Surface RT
MS surface will not turn on
1. Assume battery has sufficient charge
2. Assume no physical damage to unit, liquid, dropping etc
3. When turned 'on' can an updated OS be installed?
4. Any other faults or problems noticed?
5. Remove all peripherals and reboot
6. Go to this link: www.microsoft.com/surface/en-gb/support/warranty-service-and-recovery/surface-wont-turn-on
Good luck.
Sep 01, 2014 | Microsoft Surface RT
I have the Surface 2 and have encountered two big issues. One is that they don't have any apps I want besides basic Windows ones and two is that the form of the tablet always gets changed around when i try...
Check your manual or search on Microsoft forum to see how you can stop the change. Unfortunately with the apps, this is dependant on Microsoft releasing software/apps that work on the tablet.
Dec 09, 2013 | Microsoft Surface Pro
Tablets & eReaders Logo
44 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
