Question about Ouellet 5000-Watt Utility/Garage Space Heater
Just purchased this heater, the fan comes on but the heat is next to nothing. I checked the voltage at the elements and is is 235v the amperage on L1 and L2 is 20.8a. If I pull the fan wire off the relay, the elements get cherry red in about one minute. If I re-hook the fan up the elements seems to go black, but the ampergae and voltage remain the same. I tried jumpering T1 and T2, still the same. Need to get an answer to this issue, thanks
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
First off, 20.8 amps is approximately the amperage draw on a single element furnace (nominally 5 kw.) So if you have 3 or 4 elements, (15 or 20 kw capacity) the problem is the remaining elements are not being enrgized. Look to see if there is a W1 and W2 and even possibly a W3 terminal on the terminal strip. If so, and its not a heat pump, there should be thermostat wires on all three, indicating three stages of heat. To energize those properly, the thermostat should be a multi-stage heating thermostat providing W1 and W2 at the minimum. If you do not have a multi stage thermostat, and there are no wires on W2 and W3, jumper W1, W2 and W3 together and the furnace will come on at full capacity with the single stage thermostat.
If you DO in fact have wires on the additional W terminals, you more than likely have a heat sequencer that is not energizing the 2nd and possibly the third stage of heat. A three element furnace is typically called a 15kw furnace and the three elements should draw approximately 19 to 20 amps each. So when each stage draws in, the clamp on amprobe on the main incoming wires will correspondingly increase with each stage.
Also, some 15 and 20 kw furnaces require two circuits to supply the elements, and I have been on calls before where the second breaker was not turned on, and in one case, the second circuit wasn't even wired in from the electrical panel box.
DO NOT pull the wire off the fan while the heaters are energized as they will rapidly cycle on an overtemp device. Some actually have a "one time" thermal link that once melted render the respective element inoperable until that thermal link is replaced. They will melt very easily. An energized element MUST have airflow across it !!!
Posted on Dec 16, 2014
Testimonial: "This is a shop heater, 20a 240v dual element the only terminals available are L1 L2 (power) and T1 T2 (thermostat) quite the answer but not much of it applies to this issue."
  • tractorman44
    tractorman44 Dec 16, 2014
    The problem with a lot of the questions is that they themselves leave a lot to be desired. We cannot guess what it is you are having a problem with. A model number does nothing to speak of as far as giving information unless you are conferring with brand specific service techs. Your response provided more insight to your problem than the original question you posted.
Goodman a.c. ck361a has new fan motor and capacitor. Comes on runs great 10 min and fan shuts off but compressor on
Its probably drawing high amperage causing the motor to overheat. It may have the wrong size capacitor or weak capacitor. Or it is the wrong HP (horse power) or RPM. If you had a clamp on amp meter you can check the amperage by clamping around the L1 (normally the black) wire. Then check the amps that the motor is rated for (labeled on motor and box it came in). The amperage should be lower than it is rated for. Example... Amp meter reads 1.2a clamped around the L1 wire (left side of contactor) and motor rated at 1.5
If L1 is greater than 1.5a it will over heat. The new motor should be rated the same as the old HP, RPM & VOLTAGE.
Jun 11, 2015 | Goodman Heating & Cooling
How do I test heating elements and identify leads
The heating elements can be tested for continuity using a voltage meter. Continuity is "continueness". If no continuity, then you need to replace the elements. They are sold based on the voltage and amperage of the water heater. That information is available on the information tag on the side of the tank.
Feb 20, 2015 | Water Heaters
My 30000w fan forced ouelette heater runs but does not heat
Did you ever get this issue resolved?
I just purchased a Ouellett 5000w heater, it runs fine, but does not seem to get very hot at all. I checked and the voltage and current are correct. If I pull the fan wire off, the elements get red hot within one minite, as soon as I re-hook the fan up the elements start to cool. yet the voltage and amperage are still correct (20.5a 240v)
Mar 07, 2014 | Ouellet Heating & Cooling
One of the heating elements doesn't work
Might be. Only putting a multimeter will confirm this.
1st check for voltage. Is there voltage at that element? Then check for amperage draw? If proper voltage is present, and No current draw, bad element. If no voltage is present, you will not get a current/amperage draw, therefore the element is not necessarily bad. Check for reasons the element is not getting voltage. Bad Contactor is most likely reason when the latter is the problem.
Dec 21, 2013 | Saunacore Ultimate 5Kw 250 Cubic Ft Home...
How to check the heater element how much voltage should there be to it
Hello, welcome to FixYa.
If you check voltage to the heater you should find 120vac. This can be done with an ammeter as well for amperage draw placed on L1 in the junction box at the bottom of the dishwasher...you need only to remove the lower toe panel/kick plate.
If the heater is drawing amperage it is obviously O.K. The quickest and most effective way to do this is starting a diagnostic cycle. (I should mention if the heating circuit was open the "clean" light on the control panel would flash until resolved)
To do so is (should be) as follows...
HEATED DRY - NORMAL, HEATED DRY - NORMAL, HEATED DRY - NORMAL
This diagnostic cycle may take approx. 15-20 minutes to complete, if you let it proceed through to completion or you can push "cancel" after checking amperage for the heater...unless the heater itself is at fault or a wire has vibrated loose from the heater...those are steps to follow.
Let me know how you make out, please keep me informed if you need further assistance or anything is unclear. Please take a moment to rate me assistance and a short testimony is appreciated as well.
Thank you for choosing FixYa and good luck.
Regards,
Macmarkus :)
May 28, 2011 | Whirlpool 24 in. DU1055XTPS Stainless...
The oven won't heat on bake
Hi,You have inspected both the baking and broiler heating elements, and you still can't find a problem with your range/oven parts? Inspect the connections between the heating element and the terminal. You could have a badly connected electric wire, or a burned out electric wire. Range/Oven parts must deal with both voltage and extreme heat, so it's a common problem to have a burned wire from time to time. This is a simple fix and if you check this problem in your initial run of troubleshooting, you may save yourself unnecessary purchases of range/oven parts, etc.
Also Voltage Check can be the problem.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
L1 to Neutral and L2 to Neutral, both should be 120 volts.
If OK
Unplug the unit and check the wires at the terminal strip in the machine to make sure none are loose or burned out
If OK
Check the power at the terminal strip.
Be careful as 240 volts is lethal !!!
May 25, 2011 | Magic Chef 31000 Gas Kitchen Range
Model PT 268 heater doesn't work at all but seems to have voltage
Yes it would seem that the thermostat or the knob would be the problem...when checking for voltage you need to check for 220v across the two terminals for the heating element. You will have 120 feeding back and forth all over the place but the fan and element will only work if they have 220... so you can have voltage and it still not work...
heatman101
Apr 23, 2010 | Patton Electric Patton PUH680-U Electric...
Is 30a sufficient for a 80 gallon electric hw heater
The wattage of the heating elements will determine the amperage you need. Take the total wattage of all the elements and divide it by the voltage you are using (probably 220). That will give you the amperage. Example: 4400 watts divided by 220 volts equals 20 amps.
Sep 17, 2009 | Water Heaters
Spitfire controls Clock/Timer on Oven
all a relay is a on off switch. 120v goes into L2in and into a control relay post where it sits sits until 12V energizes the relay coil thus producing an electromagnetic effect which draws the relay contact to a closed position thus placing the 120v from L2in to the 120v L2 out post this voltage then goes on to the oven heating element.
Circuit board voltages which are 16V are derived from L1 which comes in as 120v goes through a step down transformer and gets converted to 16 vac, the voltage then goes through a bridge rectifier which turns the voltage to DC the
DC voltage is routed to the various electronic components, op-amp, microprocessor, etc.
Sep 02, 2009 | Kenmore 24 in. 17462 / 17464 / 17469...
Ouellet 5000-Watt Utility/Garage Space Heater Logo
109 people viewed this question
Top Ouellet Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you an Ouellet Heating and Cooling Expert? Answer questions, earn points and help others
