Question about Weather Channel WS-9007TWC-IT Wireless Temperature Station
Why does the outside temp of my kw9007 weather station read -42c when i only live in pembrokeshire and it's nokit that cold!?
Barolo AU9 weather station. I replaced batteries in the outside temp unit. how do I activate it to show outside temp on the main inside unit
  • Remove batteries from both units
  • Install batteries in outside transmitter and wait for it to initialize and begin sending data
  • Install batteries in inside receiver and observe temperature reading
Sep 22, 2017 | Measuring Tools & Sensors
ACCU-TEMP WEATHER STATION, MODEL IW007A. IS THERE A MANUAL FOR THIS DEVICE?
Let's find out. Google (ACCU-TEMP)(IW007A)(manual) without parens.
Oct 27, 2016 | Measuring Tools & Sensors
The indoor temp on my acurite model 02086 weather stn. constantely reads 26c how do I get it to read the correct indoor temp?
The manual of unit will tell you how to change reading from Centigrade to Fahrenheit. Read it carefully for details.
Oct 02, 2016 | Measuring Tools & Sensors
OUTSIDE TEMP SENDING UNIT GOT WET AND WILL NOT CONNECT TO CLOCK. HOW CAN I FIX OR HOW CAN I REPLACE?
[PDF]WS-8117 ATOMIC CLOCK WITH OUTDOOR WIRELESS ...
https://www.lacrossetechnology.com/products/.../misc/8117-manual.pdf
NOTE: Do not set the clock until the outdoor temperature is displayed. .... The unit will still try and receive the signal every day despite it being manually set. ..... sunlight, extreme cold and wet/moist conditions as these will lead to rapid changes ... Beforesending the atomic clock in for repairs, contact La Crosse Technology.
La Crosse Technology Top Solutions
https://www.lacrossetechnology.com/support/top_solutions.php
A: Complete a restart for display with the temperature/humidity sensor: ... to rest for 15 minutes can result in failure to connect with the outdoor sensor or missing ... Products set outside of these time zones will not search for a WWVB signal as it is ... locate the Clock or Weather Display near an outside wall and point the unit in ...
Common issues weather stations: Click Here
www.weather-station-products.co.uk/faqs/common-issues-weather-stations
Under £30 £30-£75 £75-£125 From £125 Birdhouses/Feeders Outdoor Clocks ... I'mnot getting any outdoor readings from my outdoor sensor, what do I do? This willcure 90% of all sensor connection problems, important you must ... is the airtemperature, to get this reading you need to place the unit away from direct sun.
Replacement Temperature Sensor ' AcuRite
www.acurite.com > All products
Dec 16, 2015 | Audio Players & Recorders
I've put the batteries into both stations and still am only getting my room temp nothing else.Do I need to install the one outside before I'll get a reading of the outside temp?
first you must make sure the station inside and the station outside are on the same Channel. then look for the reset button on both the one outside is probably in the battery house as well as the station selector switch. after resetting both they should be able to talk to each other again.
Oct 08, 2014 | Measuring Tools & Sensors
Outside temp
Remove all batteries. Reinstall batteries (or new ones) in the outside unit. Install batteries in the console. DO NOT TOUCH ANYTHING! Wait until the outside temperature displays on the console. Make any adjustments necessary.
Nov 05, 2013 | Davis Instruments Davis Vantage Vue...
Have a Nexxtech weather station. How to I change temp reading from fare height to celsius?
Has anyone fixed this? I have the same problem. The outside unit is in C but the indoors one in F and I can't work out how to change it
Oct 24, 2013 | ATOMIC Measuring Tools & Sensors
Temp light flashing after starting.outside temp.-17
Extreme cold weather is causing coolant to contract and fluid level is reading low level ... After starting with the engine warm the temp light should go off due to expansion of the coolant ... Solution: Add a small amount of coolant to compensate for cold weather contraction. Good luck!
Nov 24, 2010 | 2004 Volkswagen Jetta
My oregon scientific indoor outdoor weather station with atomic clock just stopped picking up the outdoor readings, it won't switch to that channel any longer. tried removing and reinstalling the battery,...
I had the same problem, Since the outside temp wouldn't read, I figured it was the outside unit batteries. Went through half a dozen AAA batteries and wouldn't read. It was the indoor unit. Had the same bats I installed 3 years ago. DUH! Replaced the AAA, and all was well. When the inside batteries die out, it has just enough juice to read indoor temp, but not enought to sense exterior signal.
Oct 20, 2010 | Oregon Scientific Wireless IndoorOutdoor...
Weather Channel WS-9007TWC-IT Wireless Temperature Station Logo
42 people viewed this question
Top Weather Channel Measuring Tools & Sensors Experts
john h
Andrew Taylor
Andrew Taylor
Are you a Weather Channel Measuring Tool and Sensor Expert? Answer questions, earn points and help others
