My brada washing machine is leaking from the back or the bottom how do i fix it
I cleaned it I cleaned the front trap and I pulled it out and unhooked the hose and that's all I did
  • 32 Answers
So how did you remove the hose? Does it just need tightening? or is there a leak in the hose because it was brittle and you moving it has made a crack in an old hose? A new hose should be easy enough to get and fit. Do remove the power while you work on it.
Posted on Dec 14, 2014
Leaking
You would need to clean out the coin or filter trap to see if debris has clogged the drain lines.
1. Unplug the washer
2. Pull the washer out to tilt it back so you can
reach the screws below the front panel and
remove it. (You will need something to catch
the water once the hose is removed from
the bottom of washer)
3. Loosen the bolt with the sliver clamp on the
bottom of the washer. The water will begin to
come out while your loosening the clamp. (Do
not remove any GREEN clamps)
4. Once the water is out, you can stick your hand
inside the hose to clean it out.
Sep 22, 2012 | Frigidaire Affinity ATF6000F Front Load...
Why washer leak from the bottom
You would need to try to clean out the coin trap in the bottom of the unit.
1. Unplug the unit.
2. Tilt the unit up to where the front feet are in the air and the back feet are still on the ground. Please make sure the unit is propped up safely.
3. Now that the unit is propped up look inside on the bottom right hand side there is a black looking accordion thing. This is the coin trap.
4. Clean the drum out with as much water as possible and have towels ready. The next step you will have the remaining water come out.
5. At the top of the coin trap where it is attached to the drum is a silver spring with a silver screw. Loosen the screw and wiggle the coin trap down from the drum.
5. Reach inside the coin trap and clean what is inside of it out.
6. Put the unit back together following the same steps backwards
Sep 09, 2012 | Frigidaire ATF6000ES Front Load Washer
Where is the lint trap on the front loader
There is no lint trap. There is a coin catcher on the pump. The design of the wash action on a front loader is such there is less lint than on standard machines. One of the bennies of the design.
Eric
May 20, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore front load won't drain
Try this, on the access panel below the door(panel that goes across the front of the washer) remove the attaching screws at the bottom corners and pull the panel off, you should see a round,white plastic cap with finger hold bar across the middle of it, unscrew the cap by turning it counter clockwise, pull it towards you to open the trap,clean the filter trap out completely and reverse the order you took it apart to put it back togrether, try running the machine as normal. Good luck and Happy Holidays!
Dec 24, 2009 | Kenmore 46462 Front Load Washer
LOCATION OF LINT TRAP?
Remove 3 screws from the bottom front panel and drop it down. The pump will be in front of you on the bottom.
Mar 27, 2009 | Kenmore Elite 45986 Front Load Washer
Leaking
Hi. Mike here. Two "most likely" causes. (1) You simply have a leak at the lower right "cleanout trap". Remove the little white plastic "pull-out" assy. Check the black seal that looks like a little "tire". Is anything caught in it, or wrapped around it, or has it become deformed? Also, check that white plastic (2") washer, in front of it, is not warped (due to overtightening). Unscrew the "knob" (handle) part, all the way out, and separate all 4 parts. Clean knob, washer, tire (seal), and trap assy. Slip washer, then tire, onto knob's threaded "shaft". Flat side of washer goes against knob. Screw knob, washer and tire into trap assy, but only one or two turns. Then, slip entire assy back into machine's recess - and turn Clockwise to tighten. Only tighten hand tight (and I don't mean Macho tight!)
(2) If that doesn't fix, you may very well be using WAY too much detergent. These machines use only 2 or 3 (Max!) Tablespoons of HE liquid detergent. I've seen cases where folks were using 1/2 cup of liquid (or powder) and even more. That causes so much foaming that there have been overflows, from the lower right corner, even though nothing was wrong with the machine. To remedy, run a load empty, with NO detergent.
Good luck, and God bless.
Mar 06, 2009 | Malber WD1000 Front Load Washer/Dryer
Washing machhine takes water and then switches of
check for a weak circuit breaker...we need 15 amps alone...onthejob
Jan 30, 2009 | LG WD-14124RD Front Load Washer / Dryer
Ge front load washer does not spin or drain
Unscrew the botom front panel,behind that you will see a lint trap,with the power off,and unplugged,place lot of towels on floor at this trap,unscrew slowly,as water will exscape,trap will pull out with plug,clean trap,,,,,,,,,,,,,,,,,,,,,,,trap is about 1.5 inches round,it located at bottom right side of my machine,,,,,,,,,good luck
Nov 16, 2008 | GE WSXH208A Front Load Washer
ERROR CODE E20
Just fixed mine, only I did not have to take it all a part. Just tip it over and reached in thru the opening in the bottom. Took the clamp loose with a phillips screwdriver and pulled the rubber off that contains the filter. Stuck my hand in the opening and pushed up on the filter from the bottom on the rubber container. Out came the filter and I cleaned it and pushed back down inside until it was past the lip that held it in place. Works great, took about 10 mins., not bad for a woman, huh. Thanks for the info, could not have done without your diagram and information.
Jun 26, 2008 | Frigidaire Affinity ATF7000E Front Load...
Washing Machines Logo
145 people viewed this question
Top Washing Machines Experts
