My printer is jammed extremely solid. I cannot pull out the many pieces of paper out whatsoever. Is there anyway to unscrew the inside or get some tad bit of room just to initiate removal of the sever
I have tried to remove from the front and back but it wont budge ..
  • sahoo_sanjay Dec 25, 2014
    Hi Lisa Mena, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Stylus CX9400 Photo Printer: paper jammed inside printer...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
May 18, 2010 | Epson Stylus CX9400 Photo Printer
Jammed paper deeper inside of machine
Try removing the fuser to check inside of it and behind it for paper scraps. (Note: the fuser gets extremely hot, so make sure your printer is unplugged and cool before touching the fuser!)
Jun 06, 2008 | Brother MFC 9700 All-In-One Laser Printer
Everytime i try to print or copy it keeps saying paper jam and theres no jam i can see i put just one piece of paper and its not running through
lift the printer and shake to check if it sounds like a piece broken inside.. turn the printer off take the power brick out from the back.. manually pull the cartridge to extreme right then center.. check if cartridge is aligned correctly.. if nothing of this works.. contact dell for replacement under warranty.. if out of warranty.. inkjet printers cannot be repaired if broken.. u can buy a dell v313 of same quality for $59 with warranty..
Dec 30, 2009 | Dell Photo 964 All-In-One InkJet Printer
HOW DO I REMOVE JAMMED PAPER
Please turn the printer Off and then ON , till you see the error message of " Paper Jam" check all the flags on paper path, specially on Fuser Assembly.
Turn printer OFF, pull all trays out gently,
Disconnect cables to network or PC. turn printer ON,
check the message gets repeated - paper Jam,
Conclusion : There is some bit and piece of paper activating flags,
take all toners out gently and transfer Drum, look into printer, and
lift the paper path under the toners, push the door a little bit and unscrew the paper path and can see a piece of paper on right side..
Pull the paper out and screw bach. put every thing back in their original status.
Now the printer will work and there will not be any papers..
Jul 31, 2009 | HP Color LaserJet 2600n Printer
Printer jam
Title:
How do I clear paper jams?
Description:
If a paper jam occurs, the Paper LED will flash as shown below.
c_panel_cover_open.gif Caution
    After you have used the printer, some parts inside the printer are extremely hot. When you open the front cover or face-up output tray of the printer, never touch the shaded parts shown below.
  1. Remove the paper tray from the printer.
  1. Pull the jammed paper up and out of the printer.
  1. Open the front cover.
  1. Pull out the drum unit and toner cartridge assembly slowly. The jammed paper will be pulled out with the drum unit and toner cartridge assembly.
c_hl20_03221.gif Caution
    To prevent damage to the printer caused by static electricity, do not touch the electrodes shown below.
  1. Open the back cover.
  1. Pull the tab toward you to open the rear chute cover.
  1. Pull the jammed paper out of the fuser unit. If the jammed paper cannot be pulled out easily, push down the tab with one hand as you gently pull the paper out with other.
  1. Close the back cover.
  1. Push the lock lever down and take the toner cartridge out of the drum unit. Take out the jammed paper if there is any inside the drum unit.
  1. Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
c_hl20_025121.gif Caution
    To avoid print quality problems, DO NOT touch the shaded part shown in the illustration.
    If you accidentaly touch the shaded part, wipe the surface with a dry lint-free soft cloth.
  1. Put the drum unit and toner cartridge assembly back in the printer.
  1. Put the paper tray firmly back in the printer.
  1. Close the front cover.
    Make sure that the Paper LED is now off and the printer is ready.
Apr 05, 2009 | Brother HL-2040 Laser Printer
Paper jam
go over these steps:
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Mar 27, 2009 | HP LaserJet 5mp Printer
Misfeeds paper pulls to the right--says paper jam-no jam
there could be a paper jam or some paper still inside.
alternative :
Mar 17, 2009 | Lexmark X3350 All-In-One InkJet Printer
Can't find printer jam inside printer
the small piece of paper is definately inside.or while pulling the paper out you have disturbed the allignment of the gears.clean the gears of the paper feeder.
Aug 16, 2008 | Samsung CLP-510 Laser Printer
Printer jams
Have you checked the paper path for anything which might be lodged there? A small crumpled piece of paper, paper clip, or even some broken piece of plastic from inside the printer itself. Are the rubber rollers extremely dirty/covered with paper dust? Depending on the design of the printer, one set of rollers may be spring loaded, and if the spring is broken, disconnected etc, the tension on the roller of course goes away. Anything like this will prevent proper paper movement through the printer
May 29, 2007 | HP OfficeJet G85 All-In-One InkJet Printer
13 people viewed this question
k24674
jasbo
jasbo
