Question about Optoma GT750-XL - DLP projector - 3D 60403 4:3 Projection Screen - manu
An Optoma GT750-XL ,
I installed a new lamp given from optoma due to the old one used up, but once installed i get the error code ( GREEN BLINKING LIGHT ) and no fan noise. i tried finding the error code and do not know what it is or how to fix it
  • 138 Answers
GREEN BLINKING LIGHT stand for power on warming or power off cooling.
Posted on Dec 18, 2014
SOURCE: dvd10 optoma projector makes a loud noise
Hi, I'm not sure if it's the same problem I had..
I had it on picture mute, for maybe 15 mins, which may not have been a good idea. While it was muted, it made a sparking sound, and then a very loud grinding noise. When turned off, the lound noise stops, and the fan continues as usual for about a minute. As soon as it's turned back on, the grinding noise is back. But the logo seemed to display ok.
I took it in for repairs, and they said they needed to replace the color wheel to fix the problem.
optoma dv10 mode
Posted on Nov 03, 2008
  • 4 Answers
SOURCE: Optoma EP755 new lamp when power standby button
you need to reset the lamp timer, usually done by holding some buttons while turning on
Posted on Mar 10, 2009
  • 5 Answers
SOURCE: optoma ep719
There is a stuffed 10v 3300uf capacitor on the power board. You need to replace it.
Bellow you can check in the picture where the capacitor is located.
Notice that in this picture I have already took the bad capacitor out and replaced with two small cords to reach the bottom and test the new capacitor.
To reach this place is not fast, several layers of plastic and metal must be removed, but is not a hard task to take the capacitor out and replace it for another.
It works just great! Now it is back on track with awesome image.
Posted on Oct 03, 2009
  • 5 Answers
SOURCE: Optoma 719, can't get lamp and fan to turn on.
SOURCE: Optoma EP719 lamp does not come on
I have the same problem. The 10V 3200uf capacitor is bulged. Can't find one on the web. Where did you get yours?
Posted on Apr 18, 2010
Lamp fault
Look at the ballast module. It controls the lamp operation.
Dec 05, 2013 | Optoma GT750-XL - DLP projector - 3D...
Optoma gt750
Just use a different power supply cord fixed mine hope this helps
Aug 26, 2012 | Optoma Office Equipment & Supplies
Optoma HD20 DLP Projecto problem
this is not an hd20..... nor is it the right kind of capacitor that an hd20 needs...........
Aug 21, 2012 | Optoma HD20 DLP Projector
My optoma ep771 projector, which i can't easily access right now since it's installed in our art gallery (very tall) ceiling. i think the bulb is out but i'm not sure. the light flashing situation is...
By what you have told me, the lamp possibly may have blown, so check if the product is still under warranty as you may be able to claim another lamp at no cost what-so-ever! It is however a definite code to tell you something is wrong! Hope this helps ;) ZKhan
Apr 20, 2011 | Optoma EP771 DLP Projector
Hello. I have optoma ep716 with problem: 1. When I power it on the green blinking for 20-30 seconds and after this stays green. Due to manual it's meaning that projector on however lamp does not provide...
hi,
Do one one thing. check the lamp of your projector. For removing the lamp see the bellow picture.
also check the lamp colling fan. If it is faulty this fault can occur.
1. Use a screwdriver to remove the screw from the cover.(1)
2.Push up and remove the cover.(2)
3. Remove the 2 screws from the lamp module.(3)
4.Pull out the lamp module. (4)
ok
Feb 16, 2011 | Optoma (BL-FU180A) Projector Lamp for...
Where do i find the ballast unit, both inside my projector and for sale?
In the optoma hd-81 there is a lamp unit housing.It goes faulty the lamp unit housing .There is no ballast in the hd-81 projector.There is lens ,the lamp unit housing and the circuit board.In most of the cases the lamp unit housing goes faulty.In that case the lamp housing needs to be replaced.It can be replaced and replacement lamp is also available. -------------------- Buying original lamp is always advisable.But there is compatible lamp also available.The original lamp housing is costly and compatible housing is bit cheaper.In some rare cases the compatible lamp does not work.But the compatible lamps also are good. To buy original lamp.Click this link directly:--- http://www.partstore.com/Part/Optoma+Technology+Inc/Optoma/HD81/Optoma+Technology+Inc/Optoma/BLFS300B/New.aspx ------------ this is link for compatible cheaper lamp.Click this link:-- http://www.partstore.com/Part/Optoma+Technology+Inc/Optoma/HD81/DNGO/DNGO/BLFS300BRL/New.aspx --------------- The procedure to replace the lamp:--- to get this procedure.Please click on the link below:--- http://www.partstore.com/Part/Optoma+Technology+Inc/Optoma/HD81/DNGO/DNGO/BLFS300BRL/New.aspx ------------ this link is for the user manual of optoma hd-81 and the procedure to replace lamp is mentioned on page number 59.Please read the instructions before replacing lamp.----------- This will help.Thanks.Helpmech.
Feb 03, 2011 | Optoma HD81 DLP Projector
My Optoma HD72 projector operates for about 1 minute and then shuts off. I kept my old bulb around "just in case", I've replaced the bulb with the old one and have the same problem.
The problem is not over-heating. The Optoma HD72 has a known problem that Optoma won't advertise. The lamp driver is faulty. They simply have to replace the lamp driver. I purchased a spare lamp with my original purchase. I had the exact same experience as you at around 1200 hours on the lamp in ECO mode. I used the spare lamp. Same thing happened at about 1200 hours. I had a friend at Optoma. he confided to me the problem. I sent it in and they replaced the lamp driver at no charge. I got another 800 hours out of the first lamp and am now using my second lamp and have about 600 hours on it. The pic quality is so good with this projector (used Digital Video Essentials to calibrate) that I'll just order a bare lamp or two and use the existing lamp housings when I need a new bulb.
Apr 12, 2010 | Optoma H30 Multimedia Projector
Optoma Projector power LED is blinking green,funs are not working, lamp not function, how can i solve this problem
i'd say power supply issue, but the led is blinking green. this means that it thinks it's in warmup/standby mode. but if nothing's running, the main board might be bad and needs to be replaced.
Dec 02, 2009 | Optoma HD65 DLP Projector
Optoma EP772 lamp will not start...
try going direct connection dvd to projector .is your dvd upconverting to 1080p or just 1080i?let me know.
Aug 16, 2009 | Optoma HD70 DLP Projector
Optoma ep716
Go to the onscreen menu and check lamp settings. Disable auto shut-off.
Nov 09, 2008 | Optoma EP716 Multimedia Projector
Optoma GT750-XL - DLP projector - 3D 60403 4:3 Projection Screen - manu Logo
249 people viewed this question
Top Optoma Office Equipment & Supplies Experts
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
