Thetv wont turn on
Has there problems with this tv
  • tnmy2000 Dec 13, 2014
    Hi Linda , I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
THETV WONT POWER ON
Check your power supply for proper operation. Look for burnt resistors, bad diodes, leaking or bulging capacitors. If time permits check as many of the parts that you can on that board.
If you check out ebay for that tv set, often you will find parts listings for the set at a much better price.
Aug 27, 2015 | Sansui HDLCD3210 32 in. LCD TV
Phillips 52pfl5704d turns on screen blinks, no video
The replacement board could be defective. Your TV worked fine until there was a power loss so its time to troubleshoot to find out how the power loss affected the original board in theTV. There could have been a power surge.
Dec 12, 2013 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Our picture has gone purple and turq
Try degaussing the TV. Unplug it from the wall and let it cool completely - at least one hour. Then plug it in and turn it on. (TheTV will only do this when it is cold.)
Aug 04, 2013 | Samsung Televison & Video
IT TAKES A while to have screen on theTV
If I understand your (very brief) problem correctly, the problem is that when you turn on your TV or DVD player, it takes a while to show anything. If the time is less than a minute for a dvd player, or less than ten seconds for turning the TV on itself, then this actually isn't a problem. Modern TVs and various other tech often take several seconds to turn on, and that may be the only 'problem' you're experiencing. It's an unfortunate fact of modern life. Things take a little while to start up sometimes. If the time for the TV is in excess of about thirty seconds, or the time for a DVD/Bluray/whatever player is more than five minutes... Well, then it could be a problem, but I'm afraid I'd need more information than you've provided.
Oct 08, 2012 | Televison & Video
Remote worked once
Universal remotes?wll turn your TV on some even do sound colour etc.But thay will not let you into theTVs menu you will need the original remote for your tv.
Aug 17, 2012 | Goodmans Televison & Video
Sansui hord rock 21inch eye ctv remot not working
The infrared sensor inside theTV might be faulty. Replace it. This component can be located just behind the infrared window at the front panel of the TV. You have to disassembe the TV to access it.
The component will look someshat like these.
May 08, 2012 | Televison & Video
No picture
The main problem is from theTV menu.I would recommend you press,menu,then settings,then display settings,and last tv screen. After, you'll get options on how you want to make your screen look like.Example:wide screen, Automatic, etc.
May 31, 2010 | GE 32GT740 32" TV
My tv seems to be stuck on one channel. changed batteries no luck wont change even with the buttons on thetv.
Mine did the same, you will probably need a software update ! contact where you bought it and a guy usualy turns up within 24 hours hooks it up to his lap top and hey presto,, I was told it was a common fault with early samsungs (as I have one !) Just for information I wouldn't buy another samsung if they where free, they are slow and the picture break up is horrendous
Feb 27, 2010 | Televison & Video
Tv wont turn on get audio then tv shuts off timer lite blinking
If TV stays in stand by with audio but no video, then common faults are the ballast board, or a fault on digital board.
If the led stays blinking , and tv turns off then the TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Dec 21, 2008 | Mitsubishi WD-62531 Projection Television
TV wont power on!
you need to be sure ,if at the shop they also did replace some resistors ,that may are bad too. try to turn on thetv with out te module if the tv works . then you'll know if the probem its just something bad on that board. please keep me inform. thanks
Jun 12, 2007 | JVC AV-48WP30 48" Rear Projection...
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
