Bought online...doesnt boot all the way up say insert bootable disc...what does that mean and or what kind of disc do I need??? Aspire 5250-0639
  • 366 Answers
Sounds like the Hard drive doesnt have a operating system installed (seller may have wiped or replaced the harddrive), or the hard drive is damaged or missing(removed), - you would need a install dvd for windows or a bootable or installer dvd for linux . and replace the harddrive if it is damaged or missing
the Bootable disk its talking about
is its next attempt at starting a operating system from a cd,dvd or usb source after trying for a harddrive startup- but failing to find an operating system
Posted on Dec 13, 2014
pgh_pa_guy
  • 2992 Answers
SOURCE: Can't boot my Acer Aspire One
"Booting" is the process of starting up the computer's operating system (Windows). Settings in the mainboard memory (the BIOS) give the order in which devices are searched for the operating system. The usual order is hard drive first, then the CD drive, and finally over a network.
That clear-as-mud message means the mainboard tried to boot over a network connection and it didn't work. It's telling you to check your network cable or to put in a CD it can boot from.
There are two reasons this is happening. Either the system's BIOS settings have "network" as the first boot device, or (more likely) the operating system wasn't found on the hard drive and the BIOS went looking for a network connection. If the computer used to boot normally and you didn't change the BIOS settings, then something has happened to the hard drive to make it unbootable.
You can check the BIOS settings by pressing the "DELETE" key when you turn the computer on and the Acer logo screen appears. This starts the BIOS setup mode. If the boot order is correct with network boot as the last choice, there is a hardware cause. You might have picked up a virus or worm which has corrupted the disk. The hard drive or the mainboard may have gone bad.
If you have a recovery CD or DVD set, you can try restoring your system. You say it's brand-new, so you might try taking the computer back to the retailer to see if their technical support people can help. Or you can contact Acer to set up service for the computer.
Hope this helps you understand what's happening and that you get the trouble straightened out quickly!
Posted on Feb 07, 2009
SOURCE: Acer Aspire One Insert boot disk
well u really cant put in a disc, you said you have the aspire one that means it doesn,t have a disc drive . Thats the way it was made
Posted on Jul 10, 2009
leecom72
  • 4806 Answers
SOURCE: acer aspire one
Its possible the computer is trying to boot from another device, as the computer starts up hit the F12 key, this should bring up boot options, select HDD if it's in the list.
If not hit F2 as it starts and enter the BIOS, look for the boot option and set the HDD as the first boot device, hit F10, save the changes and exit.
The computer will restart and hopefully boot into the operating system
Please post back if you need anymore assistance.
Regards.
Posted on Aug 06, 2009
  • 5 Answers
SOURCE: Acer aspire one mini notebook. NTLDR is missing..
If you don't have documents, pictures, etc on the hard drive that you need to backup, try running system recovery by doing the following (not sure if this works on the version with a solid state drive):
1. Turn on the computer
2. Press and hold Alt + F10
3. Click on Restore System to Factory Default
4. Ensure the netbook is plugged into AC power instead of running off the battery and click OK
* This will return your netbook to the condition it was in from the manufacturer.
Posted on Oct 13, 2009
SOURCE: my acer aspire one says no bootable device
This sounds awful, but a friend just had the same problem - no bootable device. He had dropped it, hitting keyboard first. Now he thumped it on the opposite side and IT WORKED! Must have been a loose connector
Posted on Jan 16, 2010
What is a bootable device for zg8 ?
it meens it can not find hdd or can not find its windows to boot up.
so its asking for its windows disc.
Apr 26, 2014 | Acer Aspire One Netbook 8.9" Notebook
Aspire one keep saying no bootable device insert boot disk and press any key and I don't have a disk slot
You hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Nov 19, 2012 | Computers & Internet
Netbook aspire one D255 atom N455 wont boot up
You need to get a copy of Kaspersky's rescue disk and install it on a bootable flash drive.
Kaspersky rescue disk on Flash Drive instructions:
http://support.kaspersky.com/faq/?qid=208286083
Aug 29, 2012 | Acer Computers & Internet
When i turn on the acer aspire one D255E it says chack cable connections no bootable device insert boot disk and press any key
it could be that the BIOS is set to boot from cd/dvd instead of boot from hard disk. if so, resetting the BIOS to default values might clear the problem. if not then check that you have not left another disc in the optical drive rather than a bootable operating system disc.
another possibility might be that, internally the hard disk drive is not properly docked into its sata port.
Nov 07, 2011 | Acer Aspire One Netbook 8.9" Notebook
"No bootable device -- insert boot disk and press
Try this :
What is WinToFlash
There may come a day that optical drives are as hard to find as 5.25 floppy drives are today.
WinToFlash starts a wizard that will help pull over the contents of a windows installation CD or DVD and prep the USB drive to become a bootable replacement for the optical drive. It can also do this with your LiveCD.
You don't have to worry about scratches on the disc or misplacing your original media discs once you transfer their contents to the flash drive. The optical drive is quickly becoming a thing of the past, especially in office environments, as media is shifted to the cloud.
Take note: you have to select usb flash disk in your boot priority, how? just enter your bios then search for boot priorities.
DOWNLOAD
good luck....
Jun 06, 2011 | Acer Aspire One PC Notebook
My e-machine w3410 gives me a disk boot error insert disk and hit enter what does that mean
You probably have a non-bootable disc in the CD drive - when the computer powers up, your BIOS's first boot device is probably the CD drive and since it has a non-bootable disc in it, it can't boot. Remove the disc and re-boot your computer.
Dec 22, 2010 | E-Machines eMachines Desktop PC
My acer one net book just says no bootable device insert boot disc press any key
if ur OS is good, i mean not formatted or u just formatted the system. check ur bios, boot devices, put ur cd/dvd drive on top then save and exit and restart.
Dec 06, 2010 | Acer Aspire One Netbook 8.9" Notebook
Unable to install XP OS to MSI lap top
insert a bootable xp cd into the cd drive and hit enter continuosly...it ll ask to hit any key to continue from cd...hit any screen and follow the onscreen instructions...
if it doesnt works, try this....
u can log in to the setup by pressing del key or F2(depends upon make and model) and change the drive booting order...change the first booting device as CD/DVD and second booting device to HDD...
now it ll prompt you to hit any key to start from CD/DVD....
Make sure you have inserted a bootable XP CD in CD drive....Bootable XP CD's can be created only from another bootable XP cd by taking an image from that cd and writing it back to the cd...you can use NERO Copy disc option for this purpose...it ll create an iso image and you can use only this to write into the disc...
Mar 29, 2010 | MSI Crystal M677 Notebook
Well got same problem as above when try to boot an error message comes up and says no bootable devices insert boot disk and press enter but it says my hard drive is not installed tried the start up f8 but...
This error means that the hard drive is either not connected properly or has failed. To fix it check and make sure the hard drive is connected properly and tight. If it is unfortunately that means the hard drive needs to be replaced.
Feb 26, 2010 | Acer Aspire 5315 Notebook
Jul 10, 2009 | Acer Aspire One PC Notebook
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
