Question about Cell Phones
My tablet started closing all apps to it inculding the launcher then shut off. Now when i turn the power on it pulls up the welcome screen and stuck there and does nothin else. What is wrong with it and how can i fix it
Why has launcher stopped working?
launcher stopped working Tablets & eReaders Questions ...
www.fixya.com > Forum > Tags > launcher stopped working
Tablets & eReaders launcher stopped working questions and answers. Ask your ... is not working. Error message 'Unfortunately, Launcher has stopped'. Tried to ...
Unfortunately, Launcher has stopped - Android Forums at ...
forums.androidcentral.com/.../357082-unfortunately-launcher-has-stopp...
Jan 26, 2014 - 22 posts - ‎17 authors
... up my tablet I get a message "Unfortunately, Launcher has stopped" ... or Korean and then help me to solve the launcher stop working error ...
[Q] Unfortunately Launcher has stopped and o... ' Asus Transformer ...
forum.xda-developers.com/showthread.php?t=2069137
Dec 27, 2012 - 9 posts - ‎2 authors
Third-Generation Kindle Fire HD Gets Bootloader Unlock Tool ... Currently stuck with a "Unfortunately, Launcher has stopped" on my ... It has been working very well since then, but in the last days, ... I do have a build.prop editor installed on my tablet, but since I can't launch app, I don't know how to do it.
Error 'Launcher Has Stopped Working' ' Android Tablet Forum
Dec 12, 2015 | Tablets & eReaders
When i turn it on i get a message that says unfortunately,launcher has stoped wont let me do anything else
You need to do a FULL reset.
1. Power off unit
2. Hold down POWER and Vol - (or Vol+ if Vol - doesn't work) until Android reset screen appears.
3. Scroll down to factory reset and select it.
4. Agree to reset
Unit will reset itself and start over like it was brand new and you will lose everything that was installed. Most likely you have a corrupt operating system and this may help. However, many android apps will not work on that tablet as its an older tablet that does not have an upgraded OS available.
Good luck
May 25, 2015 | Ematic 7" Touch Screen Tablet
How can start tablet when the launcher has stopped?
Unfortunatly, your launcher is corrupt. The only answer I can see will be a complete restore to factory defaults. Your apps should reload once you sign back on to the app store, be sure to use your original signon and password combination. I had to do this once and everything seemed to follow up.
Good Luck.
Dean
Mar 06, 2015 | Mach Speed TRIO Stealth G2 10.1" 16 GB...
What can I do, Asus tablet says "launcher has stopped" and will not do anything?
Always try a reboot first. If that fails go into settings, go to apps, then might have to go to system apps, see if you can start it from there. If it starts and stops, could be another app is interfering or you got too much installed and are low in memory. You can try to install a startup manager app and make sure to turn off all unnecessary apps from auto starting. If that fails, you can then try to reset to factory defaults and start all over. Just reinstall your apps one at a time and make sure system is stable after each install.
Jan 03, 2015 | ASUS 16GB MeMO Pad 7" Tablet Cherry Pink
When playing games on my Kindle Fire 7" HD, the apps unexpectedly close and return to home screen
When was the last time the tablet was turned off (not just put into sleep mode)?
To turn off the tablet, hold the power button for two or three seconds, then tap "shut down" when asked if you want to shut down your Kindle.
After the device has completely turned off, press the power button to restart.
Please reply with more information if this did not fix your problem!
See the following page for more information:
Quick Fix Slow or Frozen Screen
Dec 23, 2014 | Tablets & eReaders
A13 tablet launcher not working due to density
I just did something exactly like this on my phone. Here's what I did for solving it.
NOTE: you will need access to a PC with internet connection and your problem Device must have access to the internet. You also need access to the PLAY store on both the PC and the problem device. From what I understand from reading your explanation this should not be a problem.
1 - Start your Device as normal and when you get the force close message go to the Report option.2 - Once on the report screen (accept the terms and conditions if they appear) you should be able to pull down the notifications bar.3. On the PC go to the play store (you must log in with the same account as the one in your problem device)4. Search for a different Launcher and install it through the play store on your PC. (I used Zeam Launcher for resolving my issue but I did this on a phone so it might not be available for a tablet. You can search for Launcher and find one that way)
5. The new launcher should automatically start downloading and installing on your problem device. You should be able to see this happening on the notification bar.
6. Once finished, just go back to the main screen. You should get the option of what launcher to use. Select the newly installed launcher. (do no use the default option).
7. Once in the new launcher, go to the density changer application and change it back to the original density.
8. Reboot your tablet and it should now work correctly.
NOTE #2: I did this on a phone. I've never owned a tablet so I'm not 100% sure this will work for you.
Hope this helps solve your problem.
Jan 01, 2013 | Generic A13-MID 1.2GHz 512MB 4GB 7"...
Cell Phones Logo
37 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
