My Technics SL dv290 display doesn't light up anymore the whole stereo works just the light How can I solve this please
  • 3,382 Answers
It depends on the display. It may be a backlight LCD, that is probably a bulb. If it is a VF or LED you need to get it serviced.
Posted on Dec 14, 2014
5 Suggested Answers
SOURCE: stereo does'nt stay on you turn it on and it just
problem with amplifier contact dealer,i have the samne problem with mine,its shows F61 on the diplay and when i check my user manual it states there is a problem with the amplifier
Posted on Jan 03, 2010
  • 1527 Answers
SOURCE: Technics SA-DV290 Amp. Sound cuts out as volume is increased
hello it sound like the output ic may be in trouble you may have just dry joint on the ic which just resolder it . or there could be a capacitor leaking or they may have swelled up in which you will have to replace. it's best to do some visual checks first i'e look for any burnt parts any capacitor with bulging tops
regards
shaun
Posted on Apr 05, 2010
  • 196 Answers
SOURCE: can anyone help need the
Ty going to www.technics.com for manuals and instructions . jackie
Posted on Jul 28, 2010
  • 63 Answers
SOURCE: how do i connect technics turntable model SL-QD33
Have a look on the back input panel of the sc-dv290. Check for a "PHONO" input. If there is no phono input it will not play turntable. If there is: then plug it the turntable in and switch the SC-DV290 to PHONO mode.
Another way would be to purchase a "phono preamplifier" from ebay: Hook the turntable into the phono preamplifier, and the preamplifer into the SC-DV290 AUX input.
Posted on Feb 26, 2011
How do i connect technics turntable model SL-QD33 to technics stereo model SC-DV290 and what do i need to switch to on stereo to play records.
Feb 26, 2011 | Technics SC-DV290 System
Hello there, I have a problem with my Technics SC-DV290 System. The problem i have is that when i go to turn it on it buzzes and it cuts out after a second or two and there is no display on the stereo...
ok. there is a MAJOR problem with the power wiring. i suggest not turning it on again until either you have fixed it or a trained professional has.
Jan 24, 2011 | Technics SC-DV290 System
I am looking for the unlock code for the DVD player for my Technics SL 290
Problem for Technics SC-DV290 System I am looking for the unlock code for the DVD
Jan 21, 2010 | Technics SC-DV290 System
Technics dv290 system
i once had a panasonic dvd player which displayed the same code H02 and used the same drive mechanism as your player. this turned out to be a worn spindle motor and once replaced, all worked fine. you may well have the same fault. hope this helps?
Sep 06, 2009 | Technics SC-DV290 System
How do I switch off demo on a sl-dv170 technics?
got the sc-dv290 model, not sure but I'd asume they are all the same
PRESS AND HOLD [-DEMO] until "NO DEMO" is displayed
Feb 15, 2009 | Technics SC-DV290 System
Technics sl-dv250
The part required is likely to be the optical assembly which will cost more than $100 easily. This part should be available from any Panasonic parts supplier, but the cost is more that I would recommend. Check around to see if yuo can replace the unit for around that cost. In the meantime, I'll try to locate the exact part number and cost.
Dan
Jan 12, 2009 | Technics SC-DV290 System
Technics ho2 no play error
u need a new motor in yr dvd player i had same problem so had new motor fitted cost 50 pound works now
Sep 20, 2007 | Technics SC-DV290 System
52 people viewed this question
 Grubhead
Grubhead
