Question about Liebherr Refrigerators
How do I remove an ice maker on Liebherr wf1051
Don't know how?
  • 531 Answers
SOURCE: Blue substance in Liebherr ice maker cubes
flush the water on till it get clean
Posted on Mar 31, 2009
SOURCE: blue ice from ice maker
I have this problem too. Seems to be a couple of blue paper washers in the unit that the water filters through and they break up. Ive had this issue go on for more than a year now with Liebherr trying over and over not to claim responsibility. Ive sent them the blue washers and photos and all to get analyzed and they simply do not call me back. Their service center didnt even know there were 2 blue washers in the unit. Seems to be a mess. In any case I still have a very large amount of blue paper dust in my ice and its unuseable. Any solutions?
Posted on Dec 16, 2009
  • 50 Answers
SOURCE: I have a new Liebherr refrigerator. It says to
not familiar with brand but you will pop a cover off the icemakerfront and either push dial to start or jumper it some how. some models cant be jump started but i assume if you must bleed it then it has to have a way to start the icemaker.
Posted on Aug 01, 2010
ZJLimited
  • 17970 Answers
SOURCE: Liebherr bio fresh fridge/freezer model
This ice maker can be cycled manually to help determine the problem. To cycle this ice maker, pull the front cover off of the ice maker. You will now have access to the module which has some test terminals marked on it (I'm sending you a picture). Using a well insulated jumper, place it between T-H and the ice maker should start to cycle.
Be careful this is a hot (live) check. If the ice maker starts, after about 5 seconds remove the jumper. It will take a few minutes for it to break the ice free and if it cycles completely and refills the ice maker will need to be replaced. This indicates it's not starting on its own. If it just stops on the ice, the mold heater may be open. You should be able to feel the bottom of the ice maker to see if it's getting warm but be careful, if you touch the mold heater, it can be very hot. If the mold heater is not hot, again the ice maker will need to be replaced. If the ice maker never cycles with the jumper, there may not be any voltage getting to the ice maker. Some voltage checks will need to be made and a technician will be needed to make these checks.
Hope this helps.
Posted on Nov 15, 2010
imufo2
  • 3773 Answers
SOURCE: I have a liebherr refregirator
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Posted on Aug 04, 2011
Liebherr ice maker not making ice. Switched on but nothing happening
Hello Irene Booth,
There are several things you can do to check the suitability of your freezer settings ... (eg: if you put a small container of water in the freezer...
Is it mostly frozen in about 45 minutes??
Things that would aid in trouble shooting...
Liebherr nomenclature: model number...???
New... or new to you?
Had previously worked... Never worked.
General observations... Frost forming in back of freezer area
Doors square and fitting properly...
Gasket in full contact (visibly) all the way around the freezer door/drawer... and is in good condition
- (can physically check by pulling a dollar around the gasket).
If the Ice Maker has EVER worked ... We can skip the basics of checking the water supply is hooked up and TURNED ON.
If you can fit your fingers in the ice tray to feel for water or ice in
the tray ... that would also be helpful.
Finally... for new models... check that all packing tape & materials around the ice-maker have been remove.
Although your model appears to be a TWIST TRAY type of ice-maker... there is still a sweep or fill bar that is supposed to check the fill level of your ice bin.
A single chip of ice can hold that from moving freely... your ice maker will not work ... !!
Hope this helps
Carnac the Magnificent
Jan 04, 2017 | Liebherr Refrigerators
Replace ice tray
the complete ice maker will need to be removed from freezer because the thermistor comes on the new tray that you will replace.
Aug 30, 2014 | Liebherr Freezers
Where is the water filter for Liebherr CI1650 located?
There isn't a water filter. You should install an inline filter to the water line that comes in to feed the ice maker.
Jun 18, 2014 | Liebherr CI1650 30" Built-in...
I have a Liebherr free standing french door frig (two freezer drawers). The plastic component that shapes the ice cubes has fallen out of the ice maker into the ice receptacle below. I don't know how to...
I don't know about this ice maker, but you could always check the Owner's Manual (either the one that came with fridge, or an online copy) for re-attachment info. That's something basic that the manual may very well cover.
Sep 18, 2013 | Liebherr CS2062 Bottom Freezer French Door...
Ice maker is not making ice
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Oct 15, 2010 | Liebherr European Right Hinge Fully...
The ice maker appears not to be working can not
heatman101
May 31, 2010 | Liebherr KIKNV3056 Bottom Freezer...
I have a liebherr freezer with ice maker. ice maker broken
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Apr 17, 2010 | Freezers
Refrigerators Logo
Top Liebherr Refrigerators Experts
Charles T Nevin
Charles T Nevin
Shehu Pro
Shehu Pro
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
