Question about Smeg Ovens
Oven door not closing properly smeg spa42016 - Smeg Ovens
  • 417 Answers
SOURCE: Smeg oven door off hinges
Try www.smegtech.com/site/smeg/pdf_libretti/914772524-GB.pdf section8
Posted on Oct 19, 2008
SOURCE: Whirlpool self cleaning oven, Super capacity 465, door will not close
I had the same FSE error which the whirpool web site advises that you will need to schedule a service appt to fix. Instead I leaded against the door while initiating the cleaning cycle and the door locks and oven cleans fine.
Posted on Dec 02, 2008
barkencoa
  • 3463 Answers
SOURCE: main oven door
This comment applies to most electric ovens that have drop down doors with hinges at the bottom.
The hinges are not adjustable, and in every case the problem is caused by one or both hinge springs being weak.
The only solution, is to replace both oven door hinges together.
Posted on Jan 10, 2009
SOURCE: Manual for Smeg SpA42016
SpA 42016 is Smeg's postcode in Italy! Model number will be on same lable. Mod:
Posted on Apr 10, 2010
barkencoa
  • 3463 Answers
SOURCE: oven door not closing properly
If it is a drop down door with hinges on the bootom of the oven door, then it is likely to be weak door hinge springs, the usual solution is to replace both hinges.
If it is a swing open door, then the problem is related to a worn or broken door catch, or worn striker pin.
Posted on Apr 13, 2010
Will these doors interchange, on these models
doubt it but measure both and see if they are close
Apr 21, 2015 | Smeg Ovens
Smeg SE250XUK only oven light works, no fan no heat please help
door switch defective,,try to open close again & again
Feb 12, 2015 | Smeg Ovens
My oven is an AEG. The oven in your video is a Smeg. I need to remove the door to clean the oven and then replace it.
Open the door to the first stop, or what is called the "vent" location. This will be about 3 inches open. Lift up on the door and pull up and out. Set the door to the side and keep the arms on the bottom in the same position, do not let them close. Clean the door, when done and set the door back in the slots the same, open the door all the way, and close it. Done. Hope this helps Fix Ya up.
Jun 15, 2011 | AEG Ovens
Smeg spa42016 user manual
apparently the model number has changed that's why there are no manuals online.
go to www.applico.co.nz and search for SU61MFX, the instruction manual is there.
Dec 09, 2010 | Ovens
My smeg oven light stays on the fan does not work and the oven does not heat up. This has happened straight after I took the door off to clean.
Yes, I have had the same problem. The light in the bottom oven stayed on and the oven did not work after taking off the oven door SOLUTION: I didn't put the oven doo back on properly. Take it off and try again!
Dec 08, 2010 | Smeg Ovens
Smoke come up from bottom of 3-month new smeg oven SA702X when try to heat up
Hi.
Smoke coming from the oven is not normal. Ensure that the smoke is not vapour coming from the food inside the oven.
If there is vapour coming from the hinge area, then ensure that door and hinges are installed properly.
If you get smoke from the oven, try cleaning the oven cavity, follow the instructions on manual to clean the oven.
If after cleaning the oven, there is still smoke coming from the bottom side, then call Smeg and have the oven replaced. There is one or two years warranty on the appliance.
Smeg support and service phone number is listed in the oven manual.
Regards.
Mar 09, 2010 | Smeg Ovens
Jun 14, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Replaced hinge on smeg double oven but now oven doesn't heat
I have the SMEG F170-5 and had this problem after cleaning and replacing the door. It wouldn't heat unless I banged it shut. This action made the internal switch trigger, so I had to remove the oven (4 screws, slide out) and remove the right side panel (4 screws). The switch is actuated by the right hinge strut and it must have become bent slightly. I bent it a bit towards the door so that it would just a little bit more likely to make the switch trigger with the door closed and it now works fine.
Jun 12, 2009 | Smeg S351X/5 Electric Single Oven
Put back smeg oven door
http://www.smeg-service.co.uk/support/index.php?a=3
Here is a link to the pdf file that you can download from the internet for instructions about your door.
Just copy and paste the link into your browser window and click.
Jun 25, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Ovens Logo
51 people viewed this question
Top Smeg Ovens Experts
ashburton
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
