Question about Refrigerators
Got a swan freezer SR 5150B1. Defrosted it and now the green panel light won't light up. And me old Swan freezer won't freeze. Can it be saved???
  • Refrigerators Master
  • 3,368 Answers
Did you plug it back in, turn it on and set the thermostat. Yes it can be repaired but at a price. Check with your local repair people and see what they say.
Posted on Dec 14, 2014
  • 97 Answers
SOURCE: Freezer not freezing solid. Pulled off back
Your not going into defrost, the fridge cycles into defrost every 8-10hrs for approx 20mins....problem could be multile items, the defrost time, defrost thermostat, or the defrost heater, will need a meter to ohm heater and thermostat...thermostat will be a closed circuit when it gets below 22degrees. ohm the heater out...if both check ok, will be a timer issue. Can do a simpler check....in the fridge section near controls there is a smal hole with a gear on the inside....that is your defrost timer. take a falt tip screwdriver and turn that gear until it clicks, this will put the fridge into defrost...if everything on the heater side is ok you will hear a sizzle from the ice melting
Posted on Jun 09, 2009
Sea Breeze
  • 4654 Answers
SOURCE: WATER LEAKING IN MY FRIDGE
OK I will try to help but I see the date of your post is close to 2 weeks ago. Sea Breeze
Posted on Jul 19, 2009
  • 93 Answers
SOURCE: swan fridge freezer-freezer dones,nt get down to temperature
There is a damper door that opens and closes when you move the thermostat. I would bet the door is functioning incorrectly. All the cooling of a refrig comes from the freezer and gets blown into the refrigerator compartment. If that damper door is open too far it will have constant freezer air blowing in....and if it's not open enough obviously the refrig will not get cool. Look at the upper left corner of your refrigerator, the center rear wall of the refrig or just feel around for a vent will cool air blowing out of it......Then take it apart and see if anything is broken.
Posted on Sep 13, 2009
jumptrout51
  • 3361 Answers
SOURCE: Freezer section not freezing
If you only had ice buildup in one section of the evaporator you have a weak/inefficient compressor.
You need a new compressor or a new refrigerator.
Posted on Sep 21, 2009
  • 3600 Answers
SOURCE: i have just purchased a swan fride freezer ,i left
call the company you bought it from if it's new they should do a service call for free. Could be defective or oil in the capillary tube but somethings not right shut it down and unplug and make the call it won't cost anything and they can tell you what to check and if it does not work then they will come out and fix it for you. If you can't get to them and need it right away let me know and I will try to help but doing anything could void any warranty you might have. Hope this helps and thanks for using fix-ya.
Posted on Jan 19, 2010
Can you tell me if I can get a replacement door seal for a swan SR 5035 freezer
Go on line and do a Google search for "appliance parts", lots of sites carry this part.
Sep 06, 2016 | Swan Refrigerators
\my fridge freezer has not refrozen after I defrosted it the fridge light is on
You say the fridge is making a 'working' noise, by which i assume the compressor is running, if so is it very hot (almost untouchable) to the touch? if so you can rule out the thermostat as this is obviously sending power to the compressor. You didnt happen to use a sharp object to remove the ice from the freezer did you? if so it is possible that you have punctured the evaporator and in so doing let all the refrigerant escape.
Sep 20, 2014 | Swan SR11020CN Retro Fridge Freezer in...
Swan sr 5078 not cold but motor running fine very hot at the back
Sounds like youve lost all your refrigerant, compressor will just keep running till it reaches the set temp. turn it off & call a repairman or buy a new one.
Nov 15, 2013 | Swan SR5045 Refrigerator
Swan 2030b won't complete the cycle
This being an error ,I think was answered earlier, please have your inlet and drain filter and valve cleaned, check for good water flow pressure.
Mar 23, 2013 | Washing Machines
I need a manual for swan steam generator iron item si4030n
http://www.swan-brand.co.uk/swan-2200w-steam-generator-iron-1.html see Documentation http://www.swan-brand.co.uk/media/swan/ib/SI4030N.pdf
Jun 15, 2012 | Irons
Manual user sr 5070 samsung
My freeze sr 5070 is not cooling .how to check.
Jul 29, 2011 | Swan SR5070 (4.27 cu. ft.) Refrigerator
I am looking for the instruction manual to my lost freezer SWAN SR5030
If you lost the freezer, why do you need the manual?
Swan is a UK company that does not have a website for their freezers. The UK help center phone number for Swan is: SWAN helpline: 0845 610 4118
email: sales@swan-brand.co.uk
Also, isn't a freezer a little large and hard to loose?
Feb 01, 2011 | Freezers
Getting it wired right
the tip is red and the ring should be green and the othe wires should be on the sleeve.
Aug 21, 2008 | Shure 450 Series II Professional...
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
