Question about Konica Minolta Minolta Di450 Di470 Di550 Copier Mt Toner 502a 8936-902
Remove c-24 error - Konica Minolta Minolta Di450 Di470 Di550 Copier Mt Toner 502a 8936-902
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 115 Answers
Unplug wait a minute (that is 60 seconds) and then plug in & turn back on
Posted on Dec 14, 2014
How do I fix a fault code error 004-363 on my Xerox WorkCentre 24?
That error signifies a black drum motor failure. Try remove black drum and swap with another color and see if error follows the drum. If not it's either a bad drum motor or mcu board.
Jun 26, 2015 | Xerox Office Equipment & Supplies
Error code 24:08
Hi There,
The most common reason for General Error 24:08;
Hand Feed Mode is ON. (only time this error is shown)
The printer expects the card to be fed from the manual card feed slot at the front of the printer.
If the card is 'manually' fed from the rear of the printer (with the rear card hopper removed), then this error message will be displayed.
Hope this helps,
Kind Regards,
MC.
May 06, 2014 | Magicard Office Equipment & Supplies
Magiccard Rio printer is giving error code 24:24
Error code 24:24 means that the sensors need to be replaced. This requires sending the printer back to MagiCard for them to replace the sensors.
Mar 01, 2013 | Magicard Rio Card Printer
Registry promlems in my computer
Code 24This device is not present, is not working properly, or does not have all its drivers installed. (Code 24)Cause
The device is installed incorrectly. The problem could be a hardware failure, or a new driver might be needed.
Devices stay in this state if they have been prepared for removal. After you remove the device, this error disappears.
Recommended resolution
Remove the device, and this error should be resolved THIS MAY BE WHAT U NEED IF NOT THEN SORRY
Sep 07, 2012 | Microsoft Windows XP Professional x64...
Rio pro error code 24:04
Hi Magicard Rio Pro message:
"General Error : Contact technical support, quoting error 24:04".
Somebody help me?
Jun 28, 2012 | Magicard Rio ID 2 Card Printer
Washer will not start. We are getting error code F-24. The manual does not give specific information on that code. Our washer is a fairly new product.
Hi
Error F-24 error code indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F). This error appears when temperature sensor fails. It could also appear due to a failed electronic control or due to a wiring failure. Unplug the washer and remove the service panel, check the resistance of temperature sensor using a volt/ohm meter. Take out the screws at the bottom of the panel and then pull it out and down to remove it from the washer. With the panel removed, remove the wires off of the temperature sensor at the bottom front of the washer tub. Temperature sensor should give reading of about 10K ohms (10,000 ohms) of resistance (RX10 or RX1) at room temperature. If the resistance reading of sensor is fine then it is due to a wiring failure or a bad control board. Hope this helps... Please post back if you need more information.
Daniel
Jan 10, 2011 | Kenmore HE2 Plus Front Load Washer
Code F 24 what does it mean The washer dose not allow me to do anything when I push start. All the areas light up and flash with code F 24
The F24 error code indicates a problem with the water temperature sensor. code meanings should be under lower cover, remove panal.
Jul 13, 2010 | Kenmore HE2 Plus Front Load Washer
What does f-24 mean?
inside the machine should be repairmans instructions. this includes explanations for all the error codes.
you will have to remove the front access panel
May 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Where do I find the error codes?
if this is a counter top you should be able to remove the cover by removing the screws on the back, be aware that a lot of manufacturers use safety bits. about $24. once removed the tech sheet on top should have the codes and solutions
May 18, 2009 | Microwave Ovens
F 24 error code
f24 error code has to do with the water temp sensor,turn the washer off set the washer to cold only and start the washer for a reg. cycle this will confirm the problem,also you can check your water hoses are ok and remove the back panel to check the water pump that everything is tight,let me know how you do,mike
Oct 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Konica Minolta Minolta Di450 Di470 Di550 Copier Mt Toner 502a 8936-902 Logo
73 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
