Question about Home
I have an older Cielo corner tub. How do I remove the filter?
I am unable to get the filter off the side of the pool. It has so much residue in it that it comes out during my bath.
4 Suggested Answers
SOURCE: Need an owners manual for a cielo whirlpool tub
my whirpools no have flame
Posted on May 26, 2009
  • 34 Answers
SOURCE: I have the zuma whirl pool tub. the jets go on
This is an automatic feature to dry out the pipes and prevent mold. The next time you turn on the pump after leaving these tubs for a few weeks you get lots of black **** in the water and this is what this feature prevents. Sounds like the tub is working fine :)
Posted on Jun 08, 2010
packrat1948
  • 528 Answers
SOURCE: How do you change the
Buy a new filter and it will come with instructions.
Posted on Jan 31, 2011
Hot tub pump will not start back up after cleaning hot tub
When you say the pump won't start back up, do you mean the electrical side of things and there is just no power going to the pump. Or are you saying that the pump is on but not pumping water.
I am going to think you mean the pump is on but not moving water. This is common after you clean and drain your hot tub. You have what is referred to as an airlock in your hot tub line. It is easy to remove the airlock by simply opening one of the unions near the pump. This will allow the air to release and water flow to begin again.
Make sure also that you have cleaned the hot tub filters, if they are dirty and reduce water flow that could shutdown your hot tub pump as well.
If it is the electrical side of things make sure your GFCI has not tripped and maybe you just need to reset this. If it is anything further on the electrical side make sure you involve a professional.
  • open a union to release any airlocks.
  • clean your hot tub filters.
  • check to make sure your GFCI is not tripped.
Hot Tub Repair 101 What is an E6 or Error 6 Code Mean
You may have to change your hot tub filters as well and can find an assortment of filters here. The filters should be changed yearly, and cleaned monthly.
Hot Tub Filters
Jan 30, 2016 | Pool & Spa
How do I get a stuck hot tub filter out
The best way to never having your hot tub filter getting stuck is.
  1. remove the hot tub filter monthly for a cleaning
  2. Only install the filter hand tight
  3. Replace your hot tub filter yearly
If your hot tub filter is stuck the best way to remove it is
  1. Turn off the hot tub power
  2. Use a strap wrench for leverage
  3. You may have to remove the water for better access
How to Remove Stuck Hot Tub Filter
Aug 03, 2014 | Viking Spas Comp. Pool and Spa Filter...
My screen is showing F-04 AND NOT FINISHING CYCLE
f04 pressure switch not reading, likely cause is a blocked drainage filter, on the newer type bottom right hand corner behind the removable kickplate on the older type on the bottom on the drum inside the black rubber sump hose, remove the jubilee clip securing the hose to the tub to access and clean the filter
May 05, 2014 | Hotpoint Ultima WF860 Front Load Washer
I have a Jacuzzi J340 Hot Tub. I am having trouble with the heating. When the pump is on, the water circulates just fine. once the heater kicks on, it runs for about 10 seconds, then clicks to OH, and...
make sure the heating element isnt touching the casing inside the heating tube. if its an indoor tub, make sure the filtration cycles are not set to constant. constant filter cycles on an indoor tub will generate residual heat from the circ pump running 24/7, causing tub to heat past 104 degrees
Sep 15, 2013 | Jacuzzi Pool & Spa
Jets will not turn on just humms was smoke smelled like something burned.
THAT smell was probably your motor burning up. That happens quite a bit actually however, for you this means you will need a new pump. Get the pump out and look at the pump model and name then you can find the correct solution.
US PARTS CENTER
Oct 05, 2011 | Jacuzzi - Whirlpool - Corner - Gallery...
How do you change the filter in a Cielo jet tub
Jan 31, 2011 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
I have a 2000 Sovereign Hot Spring hot tub that quite heating, I checked filters they are ok, I have no air lock, The jets and light work fine. Inside the control box on the circuit board all 3 led lights...
Check for a bad heater controller board or burnt wire connection going to the heater. You can check for voltage across the white and black leads going to the heater from the heater controller board (upper left corner of the black control box
Mar 31, 2010 | Waterway 5 Hp 230 Volt 2 Speed Side...
How can i clean the pump
Remove the lower kick panel that is located directly below the door. If this is a Frigidaire model, the pump will be located in the front under the drum. Some pumps have a clean out trap with a screw on cover. Most Frigidaire models and GE models do not, however. You will need to remove the rubber hose from the inlet side of the drain pump in order to access the pump impeller. This is usually the larger of the two hoses attached to the pump. There will be some residual water inside the wash tub that you will need to drain, or be prepared to clean up when you remove the hose. An easy way to get rid of the residual water is to use a wet/dry shop vac and pull a vacuum on the drain hose at the wall. This will pull and remaining water from the tub and drain lines. Otherwise, you will need to lay down some towels.
NOTE: It is normal to have residual water in the tub and drain lines.
If you are experiencing drainage issue and cleaning does not correct the problem, you will need to replace the drain pump.
If you have any questions, please let me know. I hope this helps you.
Aug 24, 2009 | Frigidaire Affinity ATF6000F Front Load...
Home Logo
136 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
