Question about Electronics - Others
I have cablevision the cable box and it doesn't want to change channel it just stays at channel 12. and when i turn the power off like disconnet it, a box pops up saying if the problem continu
I tried disconnecting the tv from the wall and the cable at least 20 times and it doesnt fix it
  • 70 Answers
SOURCE: cable hookup and av hookup
Connect your TV to AV1 and you SAT/Cable Decoder to AV2.
on the video select the AV2 channel and it will record whatever is connected to AV2. The AV channel selected it is the input the one not selected is the output.
Some PPV Movie channels are copy protected with some service providers. But most channels are recordable.
The aerial lead coming in your house connects to the SAT/Cable Decoder 1st, then connect the output socket on that to the Video/DVD then the output on that to the TV. As long as the leads you use have different ends on you CANNOT plug them into the wrong socket. As the the aerial passes through each device, the device adds its own RF channel to the feed, so you should be able to tune both a SAT/Cable and a Video/DVD channel onto the TV set aside from using AV/Scart.
Posted on Jan 03, 2008
SOURCE: Tivo won't change my TV Channels anymore with direct cable
I re-did the guided setup in the Tivo under Messages & Settings/Restart-Reset System/Restart menu section in Tivo. Once I did that, it cleared this issue, even though I didn't have to change any of my settings thru this guided setup. I tried a reset alone first, but that did not fix it. Only this fixed it. We had lost both power and cable during a recent tree fall in a storm, and when both were restored, this problem started. I have a cable coax directly in the back of the TV (no cable box/IR etc) and the system is on a home wireless network. I actually have 2 identical Tivo's in the house set up the same way but only one had this problem. The other worked no different after the outage.
Posted on Oct 13, 2008
  • 57 Answers
SOURCE: Insignia TV no audio on non HD channels via HDMI cable.
have you tried to change the audio settings to HDMI on tv? when u have HDMI hookd up u have to change the audio to HDMI also
Posted on May 31, 2009
SOURCE: My television continues to display the phrase
Go to Menu - then channel - then memory channel - let the tv reconfigure the channels. You might need to unplug tv (the light to tv might still be on - press the on button to release the juice). Then plug tv back in. I did this and it worked.
Posted on Dec 16, 2010
SOURCE: Sony Trinitron XBR 36 in
after 4 or 5 yrs EHT ( transformer that supplies voltage to CRT TUBE - TV TUBE ) becomes weak - then 1 of the indication is exactly as you have described .....after few seconds picture comes slowly & immediately (after few seconds). it gets off only red light blinks............ .......so solution is EHT ( also called as flyback transformer ) should be replaced....... {{ few details about EHT---- its size will be around 3inch X 2inch X 2inch ---it will have 2 or 3 knobs to adjust focus , brightness ------ at bottom around 10 pins will be there ------- from EHT 1 thick red colour cable goes to CRT TUBE --------- on EHT its part number will be there }} -------- so if user is a technical person having idea about components ( resistors, transistors, diodes, etc ) , having tools like multimeter ( to check components) , soldering iron, soldering lead, flux, desoldering wig ( for removing components), etc also little experience in servicing field( compulsory) ----------------- then user can remove EHT from main board ---- take to electronic shop ----- buy same type EHT --------- fix to mainboard ( knobs on EHT should be adjusted according to picture --- after switching TV --- this adjustment is very important ) ----------iam from bangalore ..since it is very risky job i suggest to contact TV service engineer ------- because they are highly experienced & can fix this component very easily. ------------ [[ sometimes along with EHT another component called transistor ( big in size - situated close to EHT - it will have 3pins - its size will be 1inch X 1/2 inch X 1/2 cm --approximately ---- black in colour ----- fixed to aluminium metal ) --- will also gets deffective --- so this component also should be checked ]] ---- in your case this transistor is good ... because when this component gets deffective then TV won't get '' ON '' .............so in your case only EHT should be replaced.........100% it works normally .....GUARANTEE....... vishnuswamy_4.jpg
Posted on Jul 25, 2011
Is there any way to get my tv channel back on 4 with no remote?
Try after amke a factory reset to your tV. Normally, aits remote control is needed to make it channel-4.
Apr 29, 2012 | Televison & Video
New 37 in. tv conn. to cable not hdtv i have approx a 4" black band on each side and 2" band top & bottom is this a setting issue or because i don't have the hdtv box?
According to all the tech sheets I can see, this unit has no Tuner. If your using the cable box to change channels it probably doesn't support HDTV, except maybe for the individual channels. You might be able to access your TV's on-screen menu to change the way programs are displayed.
Sep 10, 2011 | Westinghouse LVM-37w1 37 in. HD-Ready LCD...
I accidently pressed the channel button on my remote instead of the volume button. I now have no picture or sound. I tried returning to the previous channel but it keeps saying " channel not...
Not familiar with your model, but the problem sounds generic. I am guessing your set is hooked to a cable tv box, and that is where you need to change channels. I also guess that when you changed channels on your TV you probably moved from channel 3 to either channel 2 or 4 and the cable tv box is not sending to those channels so you lose picture and sound. Now, more guessing, you try to put the channel back to 3 on your TV, but still nothing happens. OK, if close so far, there are a couple of things to try. First, be really sure you are actually going back to the same channel you started with. Assuming you don't actually have the signal coming in on an auxiliary line-in and that you had it coming in on a channel, you may need to reset the presets on the television so that it recognizes the one important channel the cable tv box is sending out -- just follow your television menu to select or set channels. There is one more possible easy problem ... I have seen this one happen, after getting the channel correct and reset, if it still doesn't work, you mght need to turn the set off and wait one minute, then turn it back on WHILE the cable box is ON. This can cause the set to RE-Latch onto the cable box signal. It really doesn't sound like something is truly broken or needs replacement, sounds more like a user error. If your set is still under warranty, just call the Panasonic hotline (find it in Google, and they may be able to walk you through exact instructions for your model). Hope this helps.
Aug 29, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
I have a Sharp Aquos 52" LC-52LE810UN. I turned the tv on and assuming that my cablevision box is working, what do I do in settings or other aspect of the tv to make the 1080i work. I have another box...
Actually the cablevision box determines the 1080i. Once it is set on that box the television simply displays it. The cablevision box will have to be connected to the television with component cables or one hdmi cable in order for you to be able to choose 1080i on it. Usually there are resolution numbers on the side of the cable box that tell you if it's on 480, 720, or 1080. There is a red light next to the one the cable box is displaying. If this is not the right kind of cable box for that then you will need to get another one from Cablevision or just eliminate the box entirely and run the cable straight to the television. Yes you can do that and use the television's digital tuner for a beautiful, crisp picture. After removing the cable box and screwing the coax cable onto the back of the television you will have to press the input button and scroll up to TV and press enter (use a Sharp remote). Then press menu and scoll over to setup and down to CH setup. Then scroll to CH search and begin searching for the available channels. You will now use a Sharp remote to change channels.
Jul 06, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
CTS 4200 4 channel CROWN power amp I changed 2 output transistors on channel 1 they were both bad but I am still seeing a fault on channel 1. I tried changing the relay for that channel but the relay...
Try changing the emitter resistors near the parts you've replaced. Also when you change out transistors it's a good idea to change them ALL out..The "supposedly good" ones may be badly stressed.
If the output line to the spkr relay has more than a volt on it the amp will stay in Protect
Jun 24, 2011 | Crown CTS4200 4-Channel Amplifier
I only get 3 channels--and none of them I want! Does this TV only work with a cable attached? Which doesn't make it portable!
If you live in the US and the TV doesn't have the newer ATSC (digital) tuner, you're lucky to get 3 channels! The only analog broadcasts left in the US are "low power" & "translator" stations. The old NTSC analog tuners in TV's from just a few years back have little to tune since broadcasters have been moved and changed from analog to digital as directed by the FCC in 2009.
I hope this helps & good luck. Please rate my reply. Thank you.
Jun 01, 2011 | Axion Televison & Video
Get dish network to work with hp SR5505F COMPAQ PRESARIO COMPUTER
You can not change channels on Satellite with your TV tuner card. The satellite box decodes the sat signal (it is sent encrypted) you can run S-Video/RCA/HDMI depending on the video card input, but you will be required to change the channel on the Dish box. The TV card can only change channels on broadcast (over the air) channels, you can attach an antenna and it will use the NTSC tuner to change analog channels (if they are still available) and the ATSC tuner to change digital/HD broadcast channels. This card (from your description can ONLY deal with broadcast TV, You will need a TV card with a QAM tuner for unscrambled digital cable. There is no solution for directly interfacing with Satellite on a PC or Mac (DirectTV or Dish) the signal from the satellite is encrypted and requires (at least for DirectTV, a fairly complicated decryption setup to function, this is handled by the tuner box/card combination. Sorry your setup will not support changing the channel on the PC, you may be able to find some kind of software that can utilize an IR transmitter to change the channels on your satellite box, similar to the way a Tivo or other DVR can talk to cable boxes, but that is the best you will be able to do as far as channel changing.
Jan 09, 2010 | HP Computers & Internet
May 31, 2009 | Insignia LCDTV26 26 in. Television
Why is there a long delay changing channels on my new Sanyo HDTV?
Are you connected to a cable box from your cable TV service Provider and use this device to select the channel you want to view? I have an HDTV which has the QAM tuning feature. Changing channels was instant until I accepted an offer from Cablevision for a 1 year rent free box and remote combo. The tuning box is a digital & analog Scientific Atlanta Explorer 4200 HD with a card slot for your subscription specs. This bypasses the tuner in your TV and the TV functions as a monitor.
If this is similar to what you have and you don't care about the channel/current program on screen display that appears for several seconds before the channel selection completes, perhaps the cable co. can adjust your box to supress this display if it will speed up the channel selection.
There is another annoying problem with this box. If you have a fraction of a second ac power interruption which might not even cause your computer to reboot, the cable box goes into a reinitialization that could take 5 minutes or longer. In my opinion, it is not worth the $6.50 per month charge we will receive when the year is up.
Aug 05, 2008 | Televison & Video
New Insignia 19 inch when hooked up to Optimum Cablevision does NOT get any cable channels..JUST basic channels...OLDER TVS all get the Cablevision full spectrum of chanels. Does it require a BOX to work...
yes, the premium channels are in a band width only reachable with a cable box. The standard or what would be over the airwave channels are available without a "box" in the basic cable tier.
Mar 16, 2008 | Televison & Video
Electronics - Others Logo
528 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
