Question about Cell Phones
My connection port does not connect
When i connect with the wire from the connection port it will not load but i can charge the phone from the computer, i cannot transfer files from my phone t a computer thru the connection port
    Sergeant:
  • 399 Answers
Looks like your cable/wire is strictly a charging cable. You need a sync cable or a dual cable (charge+sync) to synchronize your phone with your computer and transfer files between them.
Posted on Dec 18, 2014
My nokia 1112 is not admitting charge, changed the battery abnd the charger but not working
Since You have changed the charger and the battery and the phone still does not charge then It means the charging/connection port of the phone is bad. And the best solution is to replace the port of the phone. To replace the port is quite simple. First You can charge the battery in another phone temporarily while You get the connection port of the phone fixed. To replace the connection/charging port, please follow the steps below:
  1. First remove the back cover and battery.
  2. Unclip the front cover then remove the four circled screws
  3. You can now remove the LCD frame. Another ribbon connector (circled) needs to be disconnected. This attaches like a plug and socket. Simply lever it up, away from the phone, to unplug it. The LCD is now free.
  4. Then You take out the 4 screws that are around the phone,
  5. That should release the panel of the phone out,
  6. Disconnect the connection port of the phone and replace it with a new one,
  7. Then You reverse the process to reassemble the television back together.
  8. Hope this helped. Thank You for using FixYa!!!
Jan 26, 2011 | Nokia 1112 Cellular Phone
Garman 225w won't start, stops after "loading
The micro usb port is at the back. Connect Vehicle Power Cable to the nüvi and connect the other end to your computer, your nüvi does not operate as a GPS unit - it goes into some sort of charging mode. However, if you FIRST turn on the nüvi in the battery mode then go into the test mode (press the battery icon for about 8-9 seconds) from the main screen, THEN PLUG in the USB cable, and finally exit the test screen, your nüvi will restart (reboot) and it will operate just like it was plugged into the cradle connection in your vehicle.
This mode will charge the battery
AND operate as a GPS.
It works with my computer USB cable, my cell phone charger and my car charger for my cell phone.
Don't forget to turn off the nüvi before unplugging.
Jan 08, 2011 | Garmin nuvi 255W GPS Receiver
I have a samsung rant and the charger port that is connected to the charger wont charger. How do i fix it?
there are 2 possible reasons for the problem u mentioned..
  • either ur phone charger port or its internal connection is defected
  • or ur charger circuit or wire orits pin is the problem
you can find it by connecting ur phone with system using usb data cable..if it charges then ur charger kit is to replaced..else u must service ur phone
May 24, 2010 | Samsung Rant Cell Phone
Power/data socket rattles Phone will not charge
The charge ports do break loose. If you know somebody who knows how to solder very well they can reattach it. Some times the copper PC board traces pull up with the legs of the mini USB port and need to be connected with some fine wire. This should be no problem for a decent electronice tech. Your other option is to find another phone in which to charge the battery. The battery is a BR50 and I charge them off the phone with two tiny alligator clips attached to the leads of an old charger. These are about 800mAh so a dead battery will take an hour or so to charge. The voltage of a fully charged 3.7 Volt Lithium Ion battery under no load should be about 4.05 volts. You can check with a volt meter. Removing the main board to access the charge port will require a T5 (Torx bit) screwdriver. Lift off the battery cover pry the plastic piece off the bottom and remove the screws. Then carefully pry the two flex cable connectors off from under the board. Lift it out and resolder the charge port. Repost if you are having any troubles.
Aug 20, 2009 | Motorola Mobility RAZR V3
Phone not charging unless i hold it in my hand and squeeze the charger. Same thing happens with a new charger
Try to reduce the length of wire of your cell's charger.Cut the wire of your charger and reduce its length.Reconnect both wires the same way they were connected before and please make sure wires wont touch each other.Set your phone at charge and see if its charging,if not then connect the wires again but differently.
If you have the same problem with other chargers too then the problem is with your charging port.You'll have to take your cell to cell phone repairer.
Thank you!
Feb 17, 2009 | Samsung SYNC SGH-A707 Cellular Phone
Sgh-g600 download port on phone
It is only one port on the phone what You call as charging port.
You must have some older Samsung wire this is why it is not fit in to the phone.The old and the new wire the connector look very similar but the are not a same.You need to get some new wire for the G600 phoneI hope this help Julius
Jan 20, 2009 | Samsung SGH-G600 Cellular Phone
Hands free headset for durabrand cordless phone
he should change the hand free port if it is not connected to the charging port but if it is connected with the charging port he should change the charging port and the problem will be solved that's my solution.
Jan 11, 2008 | Lands Phones
Charging port connector
You can get it fixed at a place in Los Angeles Tel: 323-651-5555
Nov 18, 2007 | Samsung SGH-d807 Cellular Phone
Audiovox SMT 5600 will not charge
If your battery goes COMPLETELY dead, which it will do if phone is not turned OFF and not used for a long period of time, you will need to JUMP START it using you OEM SMT-5600 AC charger. Other AC chargers will not work for this purpose and neither will a USB port.
You can JUMP START the battery using a USB port by cutting off a USB cable to expost the red and black power USB PORT power pins 1 and 4. Remove your SMT-5600 battery and while the modified USB cable is plugged into your USB PORT, hold the BLACK wire to the negative (-) terminal and the RED wire to the positive (+) terminal for about a minute. Replace the battery in the phone and connect the phone to a USB PORT using a standard USB cable. The SMT-5600 charging light may not register for a while, but will eventually light amber to show it is charging, assuming your phone is recoginzed by your computer.
Note some mini USB cables DONOT carry the USB power leads through to the phone, only data. If you have a very thin USB cable, be suspicious the power leads are not being carried in the cable.
Since the USB PORT power is limited to 100ma it cannot hurt the battery, but will insert enough current into a totally flat batter to cause the battery to register a voltage large enough to alllow USB PORT charging, typically 3.7VDC.
Nov 18, 2006 | Audiovox SMT5600
Cell Phones Logo
44 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
