Question about T-Mobile Cell Phones
T-MOBWHAT IS APN?
S/N:HT849GZ69798
I have a zte z832 unlocked cricket phone and I put my life wireless SIM card from the lifeline free phones in the phone and need to set the APN ..does anyone know the APN to set to this phone?
  • type it in exactly as it appears below.
  • APN: wholesale
  • APN type: default,mm,supl
  • Proxy: not set
  • Port: not set
  • Username: not set
  • Password: not set
  • Server: not set
  • MMSC: http://wholesale.
    mmsmvno.com
    /mms/wapenc
  • MMS Proxy: not set
  • MMC: 310
  • MNC: 260
  • Authentication type: not set
  • APN Protocol: IPv4
  • APN roaming protocol: IPv4
  • APN enable/disable: APN enabled
  • Bearer: unspecified
  • MVNO type: none
  • MVNO value: not set
Press the Menu key and save. Reboot your phone and test your data connection by opening a web page.
Oct 20, 2017 | ZTE Cell Phones
Tip
Apple iPhone 3G/3GS Vodafone APN Settings
iPhone: How to set up the APN setting for Vodafone
The APN defines the network path for all data services i.e. internet & e-mail.
To edit the APN go to Settings > General > Network > Cellular Data Network
Cellular Data:
APN – internet
Username – web
Password – web
MMS:
APN – wap.vodafone.co.uk
Username – wap
Password – wap
MMSC – http://mms.vodafone.co.uk/servlets/mms/
MMS Proxy – 212.183.137.12
You are now ready to use your iPhone to browse the internet & send MMS picture messages.
N.B Please ensure you have a data bundle attached to your account or you may incur additional charges on your account.
on Dec 01, 2009 | Cell Phones
Settings for apn are blank. what is my apn code
Hi Edward,
Here are the steps..
Internet Setup
Step 1: Enter Settings
Step 2: Select Wireless & Networks
Step 3: Select More...
Step 4: Select Mobile Networks
Step 5: Ensure Data Enabled is checked (enabled).
Step 6: Select Access Point Names
Step 7: Create a new APN (Select Menu, followed by New APN). Enter WIND Data as the name for the new APN. Under the headings APN enter internet.windmobile.ca (leave all other fields blank).
Step 8: Save the APN settings by selecting menu and then save.
Picture Messaging (MMS)
Step 7: Create a new APN (Select Menu, followed by New APN). Enter WIND MMS as the name for the new APN. Under the following information in the listed headings:
  • APN: mms.windmobile.ca
  • MMSC:http://mms.windmobile.ca
  • MMS Proxy: 74.115.197.70
  • MMS Port: 8080
  • MCC: 302
  • MNC: 490
  • APN Type: mms
  • Leave all other fields blank.
Android 2.1 to 2.3
Internet setup
Step 3: Select Mobile Networks
Step 4: Ensure Data Enabled is checked (enabled).
Step 5: Select Access Point Names
Step 6: Create a new APN (Access Point). Enter any name you would like to call your internet connection and the access point as internet.windmobile.ca (leave all other fields blank).
Picture Messaging (MMS) setup
Step 6: Create a new APN (Select Menu, followed by New APN). Enter WIND MMS as the name for the new APN. Under the following information in the listed headings:
  • MMSC: http://mms.windmobile.ca
  • MMS Port: 8080
  • MCC: 302
  • MNC: 490
  • APN Type: mms
May 10, 2016 | HTC 7 Surround T8788 Windows 7 Wm 3.8"...
Please my LG G4 dont have APN settings. How can I download it
Hi Yewande, Without knowing your internet provider I can't help you but you can find it by googling (APN settings for) + YOUR INTERNET PROVIDER.....CHEERS..
Apr 25, 2016 | LG G4
How can I make apn settings?
NET10 operates on either the T-mobile network or AT&T network here are the APN setting for both carriers:
Net10 AT&T APN service
If the one you are running on is AT&T, please enter the following values on the APN:
APN: tfdata
MMSC: http://mms-tf.net
MMS proxy: mms3.tracfone.com
MMS port: 80
Any fields not noted above should be left blank
Net10 T-Mobile APN service
If on the other hand your net 10 service is based on T-Mobile network, use these values instead:
APN: wap.tracfone
MMSC: http://mms.tracfone.com
MMS proxy: Leave in blank
MMS port: 8080
To set the APN go to Settings>More>Mobile networks>Access Point Names>Menu>New
Feb 10, 2016 | Net10 ZTE Merit Z990G Prepaid Cell Phone
HOW DO I GET SINGAL?
Move to a known good location or another phone.
Dec 13, 2014 | T-Mobile G1 Android HTC Google Smartphone...
Samsung s4 I deleted the apn on accident how can I get them back
Every carrier uses its own APN Settings to get its 3G/4G LTE network working on an Android smartphone or tablet device. Now, these APN settings are usually "downloaded" automatically to your phone when you insert a SIM card. BUT, there are times where the APN are not selected automatically OR when the APN settings are not downloaded.
In those instances, your 3G/4G LTE data will not work but that can easily be fixed.
Step 1. First, browse your Settings menu and find the "Access Point Names" menu. This is usually under "Mobile Network Settings" or "More Mobile Networks" or "Mobile Networks" under Settings menu depending on the Android device used.
Step 2. Once you are in the APN Settings menu, first thing you should check it that the APN is on the correct one. If the correct APN is not checked (sometimes this happens), simply check ON the correct APN for your carrier. That will make your 3G/4G LTE data working right away.
Step 3. There are also times where the wrong APN is listed or there's simply no APNs listed. In these rare cases, you can simply add a new APN, hit the "+" button. 25264381-evzu5111kn4ie1titkzzffdn-4-2.jpg
Step 4. For APN setting, the "Name" can be anything. "APN" setting is the most important, usually you only have to fill this out for your phone to work.
Step 6. Hit "Save" when done.
Step 7. Next, make sure to select the new APN Setting you have saved. Within 5-30 seconds, your phone should start picking up 3G or 4G LTE signals and your data should be working again on the phon 25264381-evzu5111kn4ie1titkzzffdn-4-14.jpg
Nov 01, 2014 | Cell Phones
Need apn settings for at&t straight talk Samsung galaxy discover.model sgh730g at&t4.0.1.1 when first got phone it showed. 4g.phone it blacked out called straight talk they had me changed the apn settings...
Straight Talk AT&T APN Name ATT 4G LTE APN tfdata Proxy proxy.mobile.att.net Port Username Password Server MMSC http://mmsc.mobile.att.net MMS Proxy proxy.mobile.att.net MMS Port MCC MNC Authentication Type PAP APN Type default,mms,supl,hipri APN Protocol IPv4
Sep 11, 2017 | Cell Phones
Di ako makapagfb using myphone Q19i...paano po b dapat gawin para makakonekta ako gamit ko ung cp n un? ty.
APN Settings for Globe, Smart, Sun, WeRoam Cellular
The following settings are applicable to Smart, Globe and Sun Cellular for their APN settings (Access Point Name). The settings should work with majority of smartphones in the market.
Postpaid APN: internet.globe.com.ph
Prepaid APN: http.globe.com.ph
APN Settings for Smart Bro
Postpaid APN: smartbro
Prepaid APN: smartbro
APN Settings for Smart Buddy, Smart Gold
APN: internet
APN Settings for Sun Cellular
Prepaid
APN (static): minternet
Authentication: PAP
IP address: dynamic
Postpaid
APN (static): fbband or minternet
Authentication: PAP
IP address: dynamic
APN Settings for PLDT WeRoam
Postpaid: WEROAMPLANor internet
Note: If you’re using a variety of postpaid or prepaid SIM cards in one dongle, make sure to create a Setting Profile for each SIM card so it’s easier to set the APN when switching SIM cards.
Leave all other settings blank or as is.
Mar 05, 2014 | Computers & Internet
I just want to ask,how to connect 3g in the phillippines via globe network?hope you can help me
You need to set the APN settings. Go to Settings->Wireless & Networks->Mobile Networks->Access Point Names, click the menu and "New APN" Please try the settings below:
Name: Globe Internet APN: http.globe.com.ph APN Type: default
Note: No need to set the other fields while creating the new APN.
Select the newly created APN. To connect to the internet, tap on "Mobile Network". It will then connect using the newly created APN.
This works on my HTC Wildfire. Hope this helps.
Mar 08, 2011 | HTC Desire Cell Phone
Cell Phones Logo
62 people viewed this question
Top T-Mobile Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
Computer Repairing
Computer Repairing
ismael castillo
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
