Reverse door on affinity washer ATF6700FS1 - Washing Machines
  • 32 Answers
You will have to explain what you mean by a reverse door.
Posted on Dec 14, 2014
How do i chqnge the side the door opens on a washer ATF6700FS1
Unbolt door and remove hindge, and install on other side.
Dec 13, 2014 | Washing Machines
Can rou reverse the door when stacked
Hi there. At this time the doors cannot be reversed on this modeled unit. I hope this doesn't change your plans for stacking the units!
Mar 30, 2013 | Frigidaire Affinity ATF7000E Front Load...
Model ATF6700FS1 Affinity was squeaking and tub was hard to turn; now its not turning at all.
Hi Ikolacsky - From what you are describing it sounds like the unit could possibly have a broken shock/bearing or damaged tub. A certified technician will need to accurately diagnosis the bearing and pulling system behind the drum for repairs.
Feb 09, 2013 | Frigidaire ATF6000ES Front Load Washer
Reverse door swing
Hi halej308 - Unfortunately Frigidaire front load washer doors cannot be reverse.
Sep 29, 2012 | Frigidaire Affinity ATF7000E Front Load...
Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
Sep 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
I have an Frigidaire Affinity Washer Model ATF6700FS1 got error code E41. Thinks the door is open. I tried unplugging the connectors to the door switch but nothing worked. What to do now?
Hello & Welcome to FixYa
E41 error indicates that the problem is with door lock assembly, it is displayed when the control board thinks that the door switch is open. To solve this problem you have to remove the door lock assembly and measure the resistance of the PTC. If it reads open then the door lock assembly needs replacement however, if the reading is around 1500 ohms then replacing the control board is recommended repair. Please get back to me if you have any other questions.
Kevin
Aug 01, 2011 | Frigidaire ATF6000ES Front Load Washer
Can I reverse the door on my new Frigidaire Affinity front loader?
Hi, as far as i know you can only reverse the dryer, the wiring for the door latch doesnt allow you to reverse it on this washer.
Sean
Mar 26, 2011 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire affinity washer doesn't start
Try holding the 'options' & 'select' buttons together till the door lock button comes on. This is the child lock function. You can do it again for the lock to come off. Hold down for over 3 seconds
Please reply or rate.
Dec 01, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
