What is busy how do you clear it?
Goes to busy and turns off.
  • 20 Answers
Could you please be more specific with this issue?
Posted on Dec 13, 2014
Clear paper jam
1. Turn ON calculator and set the slide switch P/NP/IP switch to P position.
2. Remove the paper roll from printer.
3. Use a business card and insert into the printer slot
4. press the feed key to feed the business card to clear the paper jam
Jan 19, 2015 | Victor 1260-3 Calculator
HP Photosmart 7400 once switched on goes to printer busy but will not print
HI,
Please reinstall your drivers.You can go to control panel,add/remove programs and uninstall your printer driver.
Sep 04, 2008 | HP Office Equipment & Supplies
My sharp xe-a106 cash register is displaying an error message. it just reads "P" to the left of the "0.00" and I cannot clear it. Cannot do any other register functions. Turning...
Press the "clear" button (CL) the press the subtotal button (#/SUB). It will print out a long receipt. Make sure to run a Z after to clear all sales before.
Sep 13, 2011 | Point Of Sale Sharp Small Business...
I have a radio TK 701 H. The antenna is a homemade J with copper tubing. The power source is a Macromex transformer that has adjustable voltage. It transfers from 120 volts ac to variable volts dc,...
It's possible some of the repeaters you're hearing are using CTCSS tone squelch. The other people won't hear you unless you have the right tone selected. 15 V is too high for most radios. They're rated at 13.8, so turn you power supply down to something between 12 and 13.8.
Feb 27, 2011 | Kenwood TK-3101 Radio
Dboyatawent out of business and put royal 601sc in storage. just open a new \r\nbusiness a couple of year later and pull out my register and I have forgot what I programmed in it. want to program for new...
needs to be ram cleared if it has been sitting in storage awhile...
turn key to program while holding down journal feed button.
after all 0's appear in screen press subtotal
(note, this will clear any programming and totals in the register
Nov 06, 2010 | Casio Parts Cash Register PC Desktop
When i switch my tom tom one on, it sticks on the busy planning a route screen 'waiting for a valid gprs signal' everytime!?
it needs a hard reset,
from the off position,
hold the power down till after it starts and then goes blank, then turn it back on, it will forget all former positions and clear the ram.
Jun 10, 2010 | Tomtom One XL GPS Receiver
Have a Panasonic kx-e700m typewriter. I came back from vacation and the display reads "Machine is busy." I have tried to clear it by turning off the machine, typing "code+K" and have not been successf
hello sonya, this may or may not work, but leave power switch on, open your top cover, unplug machine and let sit for about 10-15 minutes. plug back in, close cover and see if you can type. if it still doesn't work, you're most likely looking at a "hard" failure that can only be repaired by a tech.
hth and good luck,
razors
Apr 13, 2009 | Office Equipment & Supplies
After faxing can not do another task becuase its BUSY
sounds like your printer queue is not clearing...could be that the drivers are unhappy
remove the old ones, and then get new ones here
Mar 03, 2008 | HP OfficeJet K80 All-In-One InkJet Printer
HP Business Inkjet 1200
sure..there must be something underneath in the tray or paper slots..check carefully..I use a pen light in a darkened room..the white shows clearly then.
Oct 16, 2007 | HP Inkjet 1200dn Printer
"busy" Error
check your firmware version and update if necessary. Usually you get the "busy" message when your camera is writing to the card and it's possible the card isn't quite right - a format should fix it. Alternatately you might try a different CF card to see if the problem goes away. Good luck!
Sep 14, 2005 | Canon EOS-20D Digital Camera
Computers & Internet Logo
David Payne
David Payne
