How do i chqnge the side the door opens on a washer ATF6700FS1
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 215 Answers
Unbolt door and remove hindge, and install on other side.
Posted on Dec 14, 2014
Reverse door on affinity washer ATF6700FS1
You will have to explain what you mean by a reverse door.
Dec 13, 2014 | Washing Machines
The door won't lock how do I fix it
I appreciate your inquiry, Gordon Smith!
From my understanding the door will not lock on your Frigidaire dryer, ATF6700FS1. You could have a potential problem with either the door latch assembly or door strike. I would open the door to see if you can locate any visible cracks or damages to either component. One or both may need to be replaced and I would recommend reaching out to a professional technician for a proper diagnosis and repair. This will help to avoid any unnecessary part purchases. -Matt
Nov 08, 2014 | Frigidaire Dryers
My frigidare (ATF6700FS1) reads error 23 it will not spin
Failure of the drain pump relay or associated circuit. IF the board is examined for any loose joints to the drain pump and confirmed then the solution is a replacement of the control board.
Jan 17, 2013 | Frigidaire ATF6000ES Front Load Washer
I have an Frigidaire Affinity Washer Model ATF6700FS1 got error code E41. Thinks the door is open. I tried unplugging the connectors to the door switch but nothing worked. What to do now?
Hello & Welcome to FixYa
E41 error indicates that the problem is with door lock assembly, it is displayed when the control board thinks that the door switch is open. To solve this problem you have to remove the door lock assembly and measure the resistance of the PTC. If it reads open then the door lock assembly needs replacement however, if the reading is around 1500 ohms then replacing the control board is recommended repair. Please get back to me if you have any other questions.
Kevin
Aug 01, 2011 | Frigidaire ATF6000ES Front Load Washer
Need to replace the heater core
This can be a real challenge. The heater core may be under the dashboard. Check under the hood where the heater hoses go into the cabin. If there are bolts there , you be lucky and it may be possible to chqnge it from the firewall side.
Sep 04, 2010 | 1991 Oldsmobile Cutlass Ciera
Can you change the way the door opens on the neptune washer
Yes you can reverse the door on your washer.
Open the door, remove the screw in the middle of both hinges, (carefull not to drop them inside). Lift the door straight up and "wiggle" the door hinge straight out of the slot.
On the opposite side of the opening you will find two inserts, remove them and install them into the slots you removed the door from. Now the fun part... remove the hinges from your door side.
Make sure you note how they attach, now intall them on the other side of the door,EXACTLY, the way they were first installed. Do one at at time. After you have them on the other side and you put the other screws back in the side you removed the hinge from, lift the door and slide the hinge into the bottom and top slots of the washer opening. Secure the hinge with screws removed in the beginning making sure the door is closing properly and locking.
Apr 10, 2009 | Maytag Neptune MAH6500A Front Load Washer
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
