Question about Eforcity 3X SCREEN PROTECTOR For HTC Dream T-Mobile G1
HOW TO EDIT ACCESS POINT ?
S/N:HT849GZ69798
HOW DO I GET SINGAL?
Move to a known good location or another phone.
Dec 13, 2014 | T-Mobile G1 Android HTC Google Smartphone...
How to activate gprs and mms settings of samsung GT-S3353
How to configure manually Samsung GT-S3353 Chat GPRS, MMS, Wi-Fi and browser settings
  • On your phone 'Menu' go to 'Settings'
  • Select 'Network'
  • On Network, select 'Connections'
  • You will be prompted by 'The menu manages connection profile. Incorrect configuration will prevent online connection.' message, just click 'Yes' to Continue.
  • On 'Connections' you can see all the list of Access points including Wi-Fi hotspots you connected.
  • Example: myGlobe Connect, myGlobe MMS, myGlobe Inet, Smart Internet, Sun GPRS, Smart MMS and FreePublic Wifi etc.
  • You can select which access point you want to edit manually, just point and click 'Options' then 'Edit'
  • If you want to create new access point for your network you can do it manually with your Samsung GT-S3353 Chat, just click 'Options' then select 'Create'
Apr 25, 2012 | Samsung S3650 Corby / S3650 Genio Touch...
Sir i am not able to use opera mini or any browser which are based on java application. i am using bsnl gprs. so what should i do. can uyou please give me mannual settings. i am using nokia 7210 supernova
Go to Menu > Settings > Configuration Settings > Personal Configuration Settings
Add new 'Access point' and 'Web'
Now edit the Access point, choose its name (you can put any name)
Now fill the APN bsnlnet
No need to fill the proxy or port or username or password, the most important thing here is the APN
set this access point as the default access ooint
Now try browsing in opera mini
Aug 15, 2011 | Opera Software Mini
Nokia 6300,plz can you open my gprs?
call you service provider and ask them to send you the internet settings then install the settings which they sent. then ask thme what is the access point name. when they say the access point name write in the following place settings -> connectivity-> packet data-> access point ->edit active access point . after writing in to it restart your phone then start using gprs. Have a nice day
Jun 19, 2011 | Nokia Cell Phones
How two use g p r s
If you need to add a GPRS connection to your phone, obtain the access point name and settings (including username and password if required) from your wireless service provider and add these settings to your phone by following next steps: Press HOME > MENU, and tap on Settings. Tap Wireless controls > Mobile network settings > Access Point Names. On the APNs screen, press MENU and then tap New APN. In the Edit access point screen, enter the APN settings. Tap the APN setting item to edit it. Press MENU and then tap Save to save the settings to your phone. This way you will connect using a GPRS connection.
Feb 14, 2011 | HTC Hero Smartphone
Setting up an access point to have same settings as the router?
It seems like it is the issue with the router's firmware. Upgrade or reflash the router's firmware. This will definately solve the issue
Jul 24, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
Cant gain access to the management URL for wireless router
you can do all over again...look for the reset button (hole) at the back. You might need a paper clip or a pointed one to push it. Hold it for about ten seconds and it resets to factory default.
Aug 16, 2009 | Computers & Internet
Cannot browse the internet i should subscribe to
Here is the procedure for subscribing to packet data:
Menu--settings--connectivity--packet data--packet data settings--edit active access point--packet data access point. Once you are at this point you will be required to type in a name for your access point: Type in "Internet" and then save your settings and exit back to standby screen.
You should now be able to browse the internet.
Best wishes,
Graemevm
May 01, 2009 | Nokia 2680 Slide Cell Phone
No association with access point
hi
is the access point WEP enabled? or is it public? as long as you are able to detect the access point, try and edit your profile to which you can connect.
if it is a WEP enabled access point, you should have a passphrase key to access it.
if its public...
try and use this...
http://www.makayama.com/EasyWifiRadar.zip
hope this helps
Jan 28, 2008 | Linksys PCMCIA Network Card PCMPC100...
Eforcity 3X SCREEN PROTECTOR For HTC Dream T-Mobile G1 Logo
32 people viewed this question
Top Eforcity Cell Phones Experts
Ken Scott
Level 1 Expert
Computer Repairing
Computer Repairing
Are you an Eforcity Cell Phone Expert? Answer questions, earn points and help others
