Question about Garland Kitchen Appliances - Others
Error call for service flat cook only?
I haveleveld the plattern set the reed switches and problem corrects itself only to occur again in 4 days to a week,ido the same procedure as earlier mentioned and it works again for a few days and error occurs again
  • 46 Answers
SOURCE: Error occurred. Call servoce person. C7980
Waste toner reservoir overflow problem (when the total number of copies is less than 100 thousand sheets) You need a new pcu
Posted on Jun 12, 2009
pineworks
  • 4041 Answers
SOURCE: service error 6000
Hi there it is ink error.
You can try to reset the cartages this may do it Please call back let us know if it worked for you, PLEASE.
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click “Power” button. Green led should be on
  3. While holding the Power button, release the Resume Button.
  4. Without releasing the Power Button, click “Resume” button for two times and release Both Buttons.
  5. Click “Resume” for four times then soon click “Power” button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 26, 2010
espressonist
  • 1711 Answers
SOURCE: get "error 8" often and machine freezes up. after
We have here the istructions for your problem<br /> <a href="http://www.fixya.com/support/r5713182-jura_capresso_impressa_f9_malfunction_8">http://www.fixya.com/support/r5713182-jura_capresso_impressa_f9_malfunction_8</a><br /> <br /> Thank you for using FIXya
Posted on Aug 30, 2010
SOURCE: Brother MFC 8460N error cc3-003-00031c0e
1.Uninstall all of MFL Pro
2.Delete HKEY_CURRENT_USER\Software\Brother\ControlCenter
3.Delete HKEY_LOCAL_MACHINE\SOFTWARE\brother\ControlCenter 4.Reinstall MFL Pro
Posted on Sep 01, 2010
SOURCE: Error code "E2" of Gorenje K357
E2 - reporting a problem with the sensor of the evaporator in the refrigerator / in isolation 10_9_2011_3_02_24_pm.jpg
Posted on Oct 09, 2011
I keep getting a speed error message when I start the belt
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Precor Error LS, Speed Sensor Signal Missing Probable Cause 1. Intermittent or open connection of the speed sensor (reed switch) wiring.
2. Reed switch is defective or has intermittent connection.
3. Drive motor brushes are bad.
4. Lower PCA is bad.
Corrective Action
  1. Inspect the speed sensor (reed switch) wiring for damage or poor connection to the lower PCA. Replace damaged wiring or reset connection as necessary.
  2. Using an ohm meter, test the reed switch while rotating the drive pulley. The reed switch will close when the magnet passes in front of it.
  3. Inspect the drive motor brushes and replace if necessary.
  4. Test unit with a known good lower PCA. Replace lower PCA if necessary.
Precor Error Code LS
Dec 08, 2014 | Precor Exercise & Fitness
Feed button error
Check if you have pressed well the plattern
Jun 20, 2014 | Royal Alpha 1000ML Cash Register
Error code LS
Corrective Action
Mar 26, 2014 | Precor Exercise & Fitness
Precor L5 error
Corrective Action
Dec 19, 2013 | Precor C954i Commercial Treadmill
Sony Bravia KDL46HX820 powers off and throws 4 blink and pause error
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
Jun 09, 2017 | Sony KDL Televison & Video
ProForm 675 elliptical is very hard to peddle
use the next steps:
Step 1
Use your flathead screwdriver to pry off the plate on the left side of the elliptical trainer.
Step 2
Look for the magnet and reed switch. These elements will be roughly the same size, and the reed switch should have a series of wires connected to it.
Step 3
Loosen the screw in the reed switch using your screwdriver. Move the reed switch by hand until it sits 1/8 inch from the magnet, then re-tighten the screw.
Step 4
Test the unit to see if the display and heart rate monitor are working properly. If not, move the reed switch slightly so it is closer or farther from the magnet, then try the machine again. Once you've found the correct location for the switch, tighten the screw to hold the reed switch in place.
Step 5
Replace the cover plate by snapping it into position by hand
8_1_2012_1_02_58_pm.gifGod bless you
Jul 31, 2012 | Exercise & Fitness
Precor treadmill error L5
Corrective Action
Feb 25, 2012 | Precor 935 Premium Series Treadmill
After 10 seconds running my horizon fitness (quantum ii) , it stop suddently with the E1 code error, what can 1 do to fix-it
The E1 error code is the reed switch signal is not making it to the motor controler. Or that the controler is bad.
Unplug the treadmill and hook it back up, remove the motor hood and check the motor controler for a red light, it should remian lit without flashing, showing the unit has power. When you press the speed buttons, the light should start flashing, then the drive motor should start driving the walk belt. Watch the red light to see if it stops flashing when the belt stops. It should. Does the treadmill read speed and distance before it quits? If so, it most likley is a heavy draw on the drive motor causing too much restistance, which shuts the controler down.
Hope this helps.
Matt
Dec 09, 2010 | Horizon Fitness Merit Fitness 725T...
I'm having an error on my kyocera ecosys FS 1118MFP. The message is "Error Occurred. Power switch turn off and on again Cf2ff". Please can you help?
this is
Controller system error
swith of and swith on the printer it will work .If this error occurs again even after the
power switch is turned off and then on
again, please replace
PWB
Jan 14, 2009 | Kyocera FS-1118MFP Laser Printer
Kitchen Appliances - Others Logo
Top Garland Kitchen Appliances - Others Experts
Paul Carew
Angel Joseph Jr.
Angel Joseph Jr.
Tom Chichester
Are you a Garland Kitchen Appliances - Other Expert? Answer questions, earn points and help others
