The fuse box is labeled clearly.
the operators guide covers this. (get one)?
it's marked a Turn.
marked the cover.
all auto stores on earth sell this fuse its a STANDARD ATC fuse.
If replacing the fuse doesn't fix it, check the flasher unit. Not sure on the '95, but it's most often plugged into the fuse panel where you find the blinker fuse, typically aluminum and shaped like a C-battery or a black plastic cube shape. If you don't find it there, my advice is go to the parts store, buy a replacement and look under the dash for one that looks like the replacement and swap it out. Hope that helps.
That fuse box is located under the dash between the steering column and drivers door.
