Question about Panasonic Televison & Video
Picture showing lines and small squares with a sticky movement
Checked aligne leads
    Top Expert:
  • Panasonic Master
  • 75,581 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Posted on Dec 14, 2014
How do I change the language on me Nextbook 9 from Spanish to English
If you click (on the main screen) in the top right corner on the (6) little squares. Then slide through the pages on the first tab. Do this until you see a picture icon of a grey square, outlines in blue with blue lines and dots on it. The first line will be slightly farther to the right than the second and the bottom (third) bar will be almost completely across the box. Select that. Then on the left hand side look slightly farther down the mid ways. you will see a choice that has a picture icon that looks like a sticky note with "A" on it and beside it will say "Idioma y entrada". Select that. at the top on the right select "Idioma" Then scrol and select "English(United States)". Unless you are in the UK, Select "English" UK
Jan 07, 2017 | Cell Phones
Have a casadei fox200 trying to recalabrate one of the fences but dnt have a manual for it need help
On all panel saws, alignment is accomplished by loosening the fasteners on one side, then clamping a long rigid straight edge to both sides in at least two positions on each side, then tightening the fasteners. A drywall T-Square sitting on the straight edge may be useful in aligning the vertical track rails perpendicular to the fences. A blade in the saw should just touch the drywall T-Square when it is raised an lowered both while the T-Square is restrained from horizontal movement.
Sep 29, 2014 | Saws
HI, MY TV PCL5415R, HAVE SOUND BUT NO PICTURES SHOW ONLY BIG BLACK SQUARE
Set would seem to be either in PIP (picture in picture multiple mode) or the black box might be the TEXT feature which is found in the closed caption menu.
Nov 04, 2012 | Samsung PCL5415R TV
The screen on My Canon Power Shot SX 120 IS camera will not show any images when I turn it on. It simply shows black, if I take a picture, the picture will record on the memory card but it is also just a...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Nov 18, 2010 | Canon PowerShot SX100 IS Digital Camera
When the screen is dark there are lines that run back and forth across the screen which is only noticable when pitcure is dark immage.
the screen bias needs to be turned down-ehind the front cover which is behind the grille there is a small black square about 3 inch square 6 little knobs sticking out 3 say in small letters screen and 3 say focus, don't adjust the focus just the screen for the coresponding color that shows up when picture is dark.best way to do this is darken the room and put it on video input with no signal if lines are white slowly
adjust 1 color after the other counterclockwise untill
lines disappear if only 1 color shows then only adjust the knob with the matching color. this is a very fine adjustment, to much will make your auto focus stop working. check it after you are done
Jun 20, 2010 | Sony KP-51HW40 51" Rear Projection...
SONY BLUE RAY ONLY SHOWS IN SMALL SQUARE. THE
Have you gone through your TV's menus? You may have to change screen resolution from within the TV's settings to get a full screen presentation.
Dec 29, 2009 | Sony BDP-S350 Blu-Ray Player
Infocus X2 projector shows picture in black and white only...
that little glass square broke off of the colorwheel, and it needs to be replaced. that yellow/gray line is from the light tunnel collapsing. both parts can be purchased and replaced by you. if you don't feel comfortable doing it, you can send it in to an authorized service center. try av solutions. they're pretty good. you can purchase infocus parts from them, too.
Oct 27, 2009 | InFocus Office Equipment & Supplies
Samsung HDTV 1080I-Model#HCP4363W-Convergence Problem
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 21, 2009 | Samsung HC-P4752W 47" Rear Projection...
Poor picture quality on Toshiba Regza 32AV555DB LCD TV
i had the same problem! i just changed my scart leads to some quality gold ones, this made the picture a lot crisper . hope this helps :0)
Dec 14, 2008 | Toshiba REGZA 32WLG66 32 in. Television
Sounds don't align with lip movement
if you are saying that your tv has no sound to match the lips movements then you will have to get a tech to repair your tv the problem is in the audio circuit could be a cap or the audio output ic.if you are saying that the tv has sound but it is not syncronizing with the lip movements have your tech check the sync circuit it is possible that the operating voltage is too small to allow the sync circuit to operate.good luck my friend.
Jun 15, 2007 | Westinghouse SK-26H240S Television
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
