Question about RCA Scenium PHD50300 50 in. Plasma Television
Vertical line on screen
There is a vertical black line in the lower lefthand part of the screen that extends about halfway the length of the screen. The line is about an inch wide and has a thinner white line in it. How can I get rid of this line?
Re: vertical line on screen
It sounds like you have a bad cable coming off of your Plasma Screen that goes into one of the buffer boards or a bad buffer board (Hopefully the latter which is easily replaced but most likely not!) I have run into the same problem and there is an IC made into the cable that goes out and would be very difficult to repair if it is even possible.
Posted on Jan 26, 2008
0 characters
3 Points
How do I remove three vertical colored lines from my Television. One vertical line is green another is red and the final one is blue.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
May 24, 2015 | Panasonic Viera Tc-p50u50 Hd Plasma Full...
How do you fix samsung ps50a457p1dxxu has black verticle line down centre of screen
A vertical line could indicate a faulty lower scan (long skinny boards along the bottom of the set) board, a faulty lower scan connection to the screen or a bad screen altogether!
Jun 08, 2014 | Samsung Flat Panel Televisions
Hi, I have an Insignia 50 in plasma television that all of a sudden went to nothing but vertical lines, then popped a cuople of times and went black. Sound is still ok.Enybody have an answer for me as to...
this is a buffer issue.
do the line go through the menu if you display the menu when the lines are visible?
do the lines go from the top to the bottom of the screen or stop halfway there?
do the lines change colors?
if the lines go over the menu and all the way down to the bottom of the screen, then its a buffer issue, top and bottom buffer.
hopefully it's just halfway then you only have to replace the top buffer, less money to spend.
Nov 24, 2013 | Insignia Flat Panel Televisions
I have two sets of black horizontal lines going across my Sony Bravia KDL-52Z5100. If you make the picture smaller the lines extend into the black area that is not part of the picture. After the TV warms...
Take care in solving the problem...
Aug 06, 2011 | Flat Panel Televisions
My kdl46z4100 has vertical black line on the screen
Unless it is spot on dead center of the set, you need to replace the LCD panel. In these models, the suspected TCON (time control) board might do the trick, but I've yet to have success with that board fixing a vertical line issue.
Hopefully you are still under manufacturer's warranty or have some kind of extended warranty, 'cause the price of that panel exceeds $1,500.00.
You could give a shout to Sony customer relations in the event you don't have a way to get the part paid for. Sony may ask that you pay for an estimate, in return for covering the part for you.
Jan 22, 2010 | Sony Bravia KDL-46Z4100 46 in. LCD HDTV
Vertical lines/black squares all throughout this 50" TV. Is it worth fixing?
I have 5 vertical black bars coming down halfway on the screen. Also 1 black square that appears on the lower half corner of the screen. What can I do to get them off? Please respond or call me @(510)938-6237 Shon Thanx!!!
Dec 27, 2009 | Mitsubishi PD-5010 50 in. Plasma...
Black line in centr of Screen
sounds like a bad panel, try reseating any cables you can on the buffers . the buffers would be on the lower edge right where the black line appears. unfortunately Vizio does not supply panels.
Jul 28, 2009 | Flat Panel Televisions
Vertical white line down centre of Soniq PT42SH plasma TV.
One of your "X" buffer boards is defective. In Panasonic plasma tv's they are located at the bootom of the set and connect directly to the plasma diplay panel via a thin ribbon cable. The board you want to replace will be directly in line with the discolored vertival line in the picture. The part number is on the circuit board and usualy starts with "tnp..." or "txp..."
Jun 01, 2009 | Flat Panel Televisions
Vertical line on side of LCD TV
Modern televisions have screens divided into sections. Each section controls all the rows in its area, and it is controlled by its own video separate video driver. If you are missing a line in a section, then a problem has occurred with the driver board in that area. It will be pretty expensive to fix, I hope your warranty has not just expired!
Jan 08, 2009 | Flat Panel Televisions
Vertical black line down centre of screen
I have same problem. Toshiba 42' hl196 purchased 4/07 line appeared 1 year and 9 months researched on Toshiba thread. Bad LCD screen. Repair cost more than tv-have to replace lcd screen. I didn't get the extended warranty. If still under warranty get hold of toshiba. Lot of people having same problem. Should get aclass action lawsuit started selling defective LCD screens. Kathy in Cleveland,OH
Dec 15, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
RCA Scenium PHD50300 50 in. Plasma Television Logo
387 people viewed this question
Top RCA Flat Panel Televisions Experts
Dave Naylor
Dave Naylor
Are you a RCA Flat Panel Television Expert? Answer questions, earn points and help others
