Question about Samsung HW-D551 Soundbar & Subwoofer
Connect a samsung sound bar to yamaha rx 465 receiver
How do I hook up a Yamaha RX-V377 receiver to a Samsung HW-H450 soundbar?
Not sure why you would want to set things up this way, but you have to set the audio output in the receiver hdmi setup menu to tv. This will allow the receiver to pass audio info out of the hdmi jack. By default, this is turned off.
Jan 29, 2015 | Yamaha RX-V377 Receiver 5.1 Channels, 70...
I dont know how to connect the wii to my rx-465 receiver.
The Wii AV cable should have a red/white pair of Audio Output jacks on it.
Check out pg. 8 of the Wii manual: http://www.nintendo.com/consumer/downloads/WiiOpMn_setup.pdf
Connect the red/white RCA plugs from the AV cable to a line level audio input on your receiver. If you use AUX IN, then select AUX IN on the INPUT selector switch. You should then hear the sound from the Wii through your receiver/home theater system.
Mar 11, 2010 | Yamaha RX-V463 Receiver
Connection Problem with HDTV, Receiver, DVR, and DVD
check the setup menu to direct your inputs from the hdmis. its all in the setup menu. good luck
Feb 10, 2010 | Yamaha RX-V463 Receiver
I need to hook up a yamaha 465 receiver
It has two HDMI inputs and one HDMI monitor output for the TV, so assuming all your devices are HDMI-capable, YES.
http://www.crutchfield.com/p_022RXV463/Yamaha-RX-V463.html?tp=179&tab=features_and_specs
Nov 28, 2009 | Yamaha RX-V463 Receiver
I have a Yamaha RX-V863 receiver connected to a
Do you have all 5+1 speakers connected? You need to go to the Setup menu of yamaha and set which speakers you have and which you don't. For example if you don't have the Center speaker connected, receiver will redirect and mix the sound to the other speakers.
Blue-ray film over HDMI should automatically output via all your configured speakers (nothing to be configured).
Nov 26, 2009 | Yamaha RX-V863 Receiver
With Cable connected to the rx-465 input, I'm not getting HDMI output to a Samsung plasma TV. With DVD HDMI input I get HDMI output to the TV. Any suggestions on what I'm missing. Thanks, Greg
is the cable connection hdmi? is the unit capable of upconversion to hdmi, if you use a component connection? probably not. if it is capable of upconversion, check your input menu settings
Nov 03, 2009 | Yamaha RX-V463 Receiver
I would like to hook up my components without having to turn on the receiver to watch tv from DVR or Cable if possible. I have Scientific Atlanta Explorer 8300 HD Cable DVR w/HDMI out, Samsung TV w/HDMI ,...
You should not lose any picture quality from the DVD player. I am currently having the similar setup with PS3 as the Blu-ray DVD player with HDMI and a Samsung DVD as regular player with component cable to a Samsung LCD TV. Remember the quality on Blu-ray is better than normal DVD so don't expect more than what it is.
Oct 07, 2009 | Yamaha RX-V463 Receiver
RX-v465
Unfortunately the RX-V463's HDMI output is version 1.2 or 1.1. In simple terms, It is useless! Not to blame yamaha or any other manufacturer but the firmware was riddled with problems; just like what you describe. There is no fix for your model for the video issue, however, the optical issue is solveable. The receiver should play 5.1- 6.1 7channel stereo etc. in optical or coaxial mode. If you have the ability to switch to coaxial, do so. it's sound is warmer anyway. Secondly, check your settings thru the receivers "GUI" or "Menu" in Manual setup for audio. Thirdly, check your samsungs "Native" resolution, chances are it will only do 720p or 1080i and; if your TV is 50" or smaller, the human eye cannot see the difference between 720p and 1080p anyway, provided you use good cables. I am a professional in the industry and still avoid using HDMI whenever possible!
Just make sure you set your BluRay and TV to the same resolution. If your choices are 720p or 1080i use 720p it's cleaner 1080i is equal to 540p, which is just a hair over std DVD video. If you still have problems and need more help, post a comment and I will help some more. Hope this helps
Jun 11, 2009 | Yamaha RX-V463 Receiver
Samsung HW-D551 Soundbar & Subwoofer Logo
79 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
