Honeywell CM921,, i let my daughter stupidly play
Honeywell CM921,, i let my daughter stupidly play about the thermostat and now when i put it on manual (like I always have done) it doesn't go any higher than 5 degrees. I've looked through all books and on the Internet to find the answer to what she has done but can't find anything about it anywhere. Can you help? Thanks
  • Chris
    Chris Jan 01, 2018
    Jemma I’m Chris, and having same problem, how did you sort it
    New Friend:
  • 41 Answers
Have you checked for a reset button sometimes its not visible you have to use a pin and poke inside the little hole
Posted on Dec 13, 2014
I have a Honeywell CM921 thermostat. I stupidly let my young daughter play with it but shes now changed something on it and i haven't got a clue how to change it back as i don't know what the problem is TO...
Press the time button once. The display will show 'RESET PROGRAM'.
Press the or buttons to select the preferred setting (0=user program,
1=factory program) and the display will flash, indicating a change has been
made. To confirm this change press the green button.
and don't let your kid play with it again until next year when her grasp on technology exceeds the current model smart phone... LOL
Dec 13, 2014 | Heating & Cooling
Failure of my Honeywell CM61ng wireless thermostat. Replacement advice
Probably not. There are replacement models available.
The T6661B programmable room thermostat is also known as CM61.
CM61 1 day wireless programmable thermostat is replaced by CM921.
CM61 1 day wired programmable thermostat is replaced by CM901.
Oct 21, 2017 | Heating & Cooling
CM921 LCD figures breaking up
Hi There - I have a similar problem to the one described by yourself . Did anyone offer any help or assistance on this at all ?
Many thanks
M Hudson
Jul 15, 2013 | Honeywell Programmable Thermostat Heater
I have the same problem where my honeywell cm921 room thermostat never turns off the central heating. If I set my off temp really low will this solve the problem, but if its really low does this become the...
It's either because the thermo sensor is faulty or the location is wrong. Try setting the temp one degree above room temp and see if that works, if it does it's a location issue. The thermo should be close to the centre of the house, not near an outlet or the RA vent & not in a breezeway or other heatsink, at approx 1.5m above floor level.
Dec 14, 2010 | Honeywell Programmable Thermostat Heater
I have a cm921 thermostat with the correct batteries showing full charge. Yet the battery light is flashing and says battery low. Also displayed room temperature is a lot higher than the actual room...
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Feb 28, 2010 | Honeywell Programmable Thermostat Heater
Honeywell thermostat CM921, how to set the heating for a 6.30am??
if you have a programable tstat you need to go through the settings for each day and time. usually the buttton will say prgm or program sometimes it will be set try to get into the settings menue and then you can adjust times
Sep 02, 2009 | Honeywell Programmable Thermostat Heater
Honeywell CM921 Showing room temp at -24 degrees, How do I reset?
Heya this is a manufacturing fault from honeywell them selves when it comes up -24 basically it needs to be replaced there is no way around in if you get in touch with honeywell they are generally good about it also if you provide them with the date code and model code they will be greatfull as it seems they have sent out a "bad batch". you locate this by:
A) Move the slide in to the off position
B) Press and hold i for 5 seconds
C) Unit will enter settings mode
D) Press and hold the i button and the + and ¿ button together
E) The unit will hold the relay on for 5 minutes and you can view by pressing the down arrow twice for model id/date code (ww/yy)
I hope this helps
Nov 11, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
188 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
