Question about KitchenAid KDTE204DWH Architect II Superba EQ KDTE204DWH 24" Fully Integrated Built-In Dishwasher with 14 Place Settings 6 Wash Cycles 5 Options 45 dBA Heat Dry Option Prowash Cycle and Energy Star Qualified in White
Can you open the door to begin wash cycle and then close which will allow you to mount flush with cabinets?
    Prodigy:
    An expert who has answered 500 questions.
  • KitchenAid Expert
  • 646 Answers
Actually, I think it is designed to do that - select your wash cycle and options with the door open, then press Start, and then close the door within 3 seconds and it should run.
Posted on Jan 20, 2015
4 Suggested Answers
  • 52 Answers
SOURCE: Which dishwashere auto resume wash cycle when door is closed?
All the tall tub dishwashers made by Whirlpool (inc. Kenmore and Kithcenaid) must have the start button pressed after adding a dish. If the start button control light is blinking, you must press start. On those models with buttons on the top of the door you must, in addition, close the door within aprox 5 seconds after pushing start. Hope this helps. Ken
Posted on May 02, 2009
  • 71 Answers
SOURCE: detergent opener does not dispense detergent
Most KitchenAid dishwashers have an adjustable upper rack, since I do not have your model number I cannot advise on specifics but if you move the upper rack to the higher position the dispenser will open a little further.
Also if you are not washing well on the upper rack you may have either a plugged spray arm or sump.
Look at the spray arms close, if the holes are plugged then it will not spray into the dispenser properly.
If you have a tall tub KitchenAid then the sump may need cleaned.
Here are instructions that might help.But not knowing your specific model these instructions may not apply
A plugged up sump can cause a multitude of problems in a dishwasher, it can make the dishwasher not clean as well as it should, make the cycle run longer, it can create noises and redeposit food.
To clean the sump follow the directions below.
- Remove the lower rack
- Remove the lower wash arm (1) by turning the nut (4) clockwise (right) lift the arm off, there is a bearing (3) (small thin plastic washer) under the arm, be sure not to loose it. Lift the tab on the back of the feed tube cap (2) and swing it to the right and lift up, this may need a bit of pressure to release it.
- Remove the 4 screws (3) from the accumulator (1), lift off the accumulator. Remove 1 screw(7) from the cover (8) this is located down inside of the sump (4) on the left front side. Lift up and remove the cover (8), watch for glass and clean out all the debris from the sump and especially around the the area of the chopper and screen (6) which will be exposed with the cover (8) off. If the screen is blocked with debris that usually means you need a new chopper. it may be broken or loose and not doing its job.
Once clean reassemble and enjoy a dishwasher that cleans the dishes again.
Posted on Feb 14, 2011
Macmarkus
  • 2605 Answers
SOURCE: The dishwasher door snaps open,
Welcome to FixYa.
I suspect based on your description...it is the door strike that is likely fatigued as is common with these machines, thus allowing the door to "pop" open. The latch doesn't hold it closed, it just activates the switches, the strike is designed to hold it closed.
It is part # 8574157 and will look like the image here...
You do not need to remove the control panel to access the strike for the door latch assembly. It is done simply by pulling up (may need a flat screwdriver or the like) on the latch and forward. The new one also simply clips in place.
**make sure to turn off the breaker/power before servicing the unit...safety first**
Let me know if you need any further assistance and I will try to help in any manner I can. Good luck,
Regards,
Macmarkus :)
Posted on Jun 08, 2011
Dishwasher starts program, then few mins in pause/start button flashes "insufficient water supply". Checked all hoses and all clear. Anyone? Thank you. Glen
As soon as the waser begins the wash cycle pause, open door record water level in sump.
Close door and continue cycle until machine faults and stops.
Open door, record water level in sump.
Compare before and after. If level is low that the flapper valve that allows the water to drain is stuck open and the water is draining into the sink as the unit is washing.
To confirm, if the washer drain hose is connect to the neck of the disposal or sink drain, observe the drain after restarting the wash cycle from the beginning. If water is trickling out from the dishwasher while it is washing then it is confirmed the drain door is not closed if equipped with that configuration.
All washers have a process and hardware to drain. Some have a sepperate drain pump
Hope thisd helpd?
Jun 29, 2017 | Dishwashers
Control lock light is on , toke door lock off once cleaned it put it back on and it worked now its on aagain and washer wont work
1 close washer door and dispenser drawer
2 select Clean washer cycle
3 Press start/ pause
The basket will rotate,then the door will unlock,lock again,then the cycle will continue
Water should come in and run a short sensing cycle about 3 minutes
4 This will determine item in the washer
a if no items are detected it will move to step 5
b if item are detected wash any control lock light will stay on door will unlock open and remove any garments
If b pessnpower to cancel f code then repeat 1,2,3
Once cycle begins allow it to finish
5 after cycle is complete leave the door a jar to allow for venting and drying of interior
Only use HE high efficiency detergent
Jul 05, 2015 | Whirlpool GHW9100L Front Load Washer
Whirlpool wfc7500vw when put into any cycle selection the door lock lights comes and stays on and the draining/unlock light flashes for a minute then the door unlocks once opened and closed the cycle...
When you first start a load, the machine does perform several self checks. One of them is the door lock test. It locks the door and checks a loop back signal from the lock. At this point, it usually tests the drain pump to make sure it cycles on and off. In my case, the Maytag unit we own actually unlocks the door and immediately locks it again right before the actual wash cycle begins. I suppose this is a double check because if the door indicates it is unlocked, the washer won't do anything (like fill up with water, or spin...anything that either floods the room and hurts somebody). The door switch should be the impetus to start the tests. If the switch is mounted to an adjustable bracket, or the bracket is loose, then maybe it is being pushed out of position when you close the door. The fact that you can open the door after it unlocks, re-close it and the machine works normally tells me there is adjustment that needs to be made. Either the the little lever or pin that actuates the switch is bent or broken, or the door needs to be adjusted on its hinges to get the pin aligned correctly. Hope this helps. Keep us posted.
Kindest regards, Carl
Aug 15, 2014 | Washing Machines
I dont have a stop buttom
You're start/pause button should pause the cycle, cancell should completely cancell. After pressing the Start/Pause within a cycle, the door lock may require time to unlock as indicated by the lock light on the panel.
Apr 11, 2014 | Frigidaire Affinity ATF7000E Front Load...
How do you install an Ikea kitchen cabinet door hinge?
The new Ikea Sektion door hinges mount in 2 holes that are horizontal. The dimensions for the hole placement are 62 mm up from the outside bottom of the cabinet where the bottom edge of the door will be. The first hole is 20 mm in from the front edge and the second hole is 33 mm from the first hole or 53 mm from the front edge. The holes can be drilled with a 3/16" bit to a depth of 9/16". After the holes are drilled, the plastic plugs on the back of the hinge mounting plate are pushed into the holes with the orientation triangle "arrow" stamped on the front of the mounting plate pointing toward the cabinet opening. After the mounting plate is flush with the surface, the two wood screws are tightened in the plastic plugs to expand the plugs and secure the mounting plate. The door hinge mounted to the door is then clipped onto the mounting plate by first engaging the "hooks" near the door end of the hinge then snapping the back end of the hinge into the clip at the rear of the mounting plate. The location of the door once mounted can be adjusted by turning the three screws on the hinge. The front screw moves the door right and left when closed. The center screw (recessed in the hinge) moves the door up and down. The back screw moves the door closer or farther from the cabinet when closed. The hinges "snap" the door closed, so if the door is too close to the cabinet the hinges can't snap it closed and the door remains ajar. The trick is to adjust the inner screw to move the door farther from the cabinet until it snaps closed. The snap can be strong, and the little bumper plastic disks you can stick to the door to soften the bump work to some extent. The best solution is to install one soft-close Utrusta piston per door. The piston clicks onto the hinge and slowly closes the door the last bit without a bang.
Jan 31, 2013 | Hardware & Accessories
I have no way to connect to the granite counter top. Can it be mounted to the side cabinets?
Need prefix for model number. Need complete model number. I believe that the numbers that you have given are stock numbers from your user manual. Kenmore can be several different manufacturers. Some brands have kits to mount unit from the sides using brackets at the top. If stainless steel tub, look for removable plastic caps on the right and left sides of unit. These holes would be used for installing bolts into cabinet. If plastic tub and no kits are available holes can be drilled into sides to secure unit to cabinet. As long as heads of bolts(screws) are flush to allow door closing, unit will not leak because of tub(door gasket.
Feb 15, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
The rubber seal between the opening and the drum gathers dirt and stinks. Do I need to have this rubber seal replaced or just clean it after each wash with a damp cloth?
Here's what I recommend when asked:
Wipe the seal down liberally with a 50/50 bleach water solution. Pour the remainder into the tob, and add one cup of straight bleach. Fill the dispenser cups with bleach. Run the hottest, longest cycle with the hottest rinse cycle (for us, it is the "sanitary cycle"). After this cycle runs, run a normal cycle to flush out any remaining bleach residue. Here's the important part: leave the door open between loads. This allows the washer to dry out, preventing the formation of the mold, which causes the smelly odors. If you begin to see mold again, wipe it down with a disinfectant solution and continue to leave the door open.
Best regards, --W/D--
Jan 27, 2011 | Washing Machines
How do I get rid of the black stuff in the door seal?
Use a bleach and water solution 50/50 and apply liberally. Place 1 cup of bleach in the washer tub, and fill all of the dispenser cups with bleach. Run the hottest wash-rinse cycle that you have; for us, it is the sanitary cycle. Follow that cycle with a normal cycle to flush out any residual bleach. Leave the door cracked open when the washer is not in use. The moisture that stays in the washer is one of the most common reasons for mold to begin growing in the washer. Allowing it to air dry helps keep it from happening.
Jan 23, 2011 | Kenmore HE2 Plus Front Load Washer
Item: Whirlpool Ultra Dishwasher Age: 3 yrs Problem: Not enough water to effectively wash the dishes. State: When the dishwasher is started, the fill valve opens as normal. Only about 1/2 the amount of...
Larry,
The float is generally for overflow conditions and will interrupt power to the fill valve solenoid.
If you are not filling completely in the time allowed by the timer, it is most likely a flow restriction in the water supply. Barring other obvious restrictions, the fill valve has filter screens on the inlet side of the fill valve, which is generally the cause of your symptoms. Be careful if you attempt to clean the screens, as the fill valves are very sensitive to debris, and can become stuck open if sediment gets past the screen. I usually replace the fill valve to avoid future problems.
Hope this helps.
Oct 30, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
GBC Shredmaster 5260X - door is closed by light indicates otherwise
This shredder has a magnet built into the door. If you open the door you'll see a metal strip on top right side of shredder. Either the magnet is not getting close enough to activate the reed switch or the hinges have came loose allowing a door sag condition. Also, if the shredder isnt that old, just contact GBC for some warranty work at 800-790-7787
Oct 03, 2008 | Office Equipment & Supplies
KitchenAid KDTE204DWH Architect II Superba EQ KDTE204DWH 24" Fully Integrated Built-In Dishwasher with 14 Place Settings 6 Wash Cycles 5 Options 45 dBA Heat Dry Option Prowash Cycle and Energy Star Qualified in White Logo
85 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
