I have a lg titan inverter 9000 and it won't work because of error ch61. What does it mean? How can I solve it?
    Problem Solver:
  • 7 Answers
It normally means that the external unit is overheating,but if the unit doesn't work at all then it sounds strange, i would advise in both cases to get the technical service center in to check it out, if you have a gas leak , it will run a while then stop, but if you havent got the gear to check it out get the service center in.
Posted on Dec 15, 2014
3 Suggested Answers
SOURCE: CH61 LG AC not working
not cooling
Posted on Jan 06, 2011
  • 414 Answers
SOURCE: my air conditioner has just
Not enough air being drawn over the outside condenser unit. This could be for a number of reasons. The unit may be covered, restricted, or blocked. The condensor fan may be inoperable on the unit. Without a model number I would first check the outdoor fan for proper operation, and contactor and run capacitor. It sounds as though the compressor is coming on and going into thermal overload.
Posted on Feb 13, 2011
LG Inverter V model LMN096HVT air conditioner multi unit has error code 9. How can I fix this myself?
  1. How to fix lg with code CH05 - Fixya
    www.fixya.com/support/t12722126-fix_lg_code_ch05May 8, 2012 - Question about LG Air Conditioners. 2 Answers ... Hi, i've just moved into a house with a LG ART COOL C24AWR N80 inverter unit in it. Have just .... LG Inverter V model LMN096HVT air conditioner multi unit has error code 9.
Jul 12, 2015 | LG LMN096HVT WaMounted Mini Split Indoor...
Why does my microwave stop working and flash F-9
Since this an LG microwave, an F9 error when the inverter module fails. Unfortunately, other parts could cause the inverter to read as a failure. A bad magnetron, relay 2 or door switches or the connections between the various parts could be bad. Since the microwave is starting, the switches are the least likely culprit. However, it's hard to determine if the inverter or the magnetron is bad without replacing one part. Then the other if the first repair doesn't solve the problem.
I hope this helps.
Mar 19, 2013 | LG Microwave Ovens
Cant unlock lg titan touch phone
Hello:::
defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Jan 17, 2013 | Bose Lg G2X With Google Unlocked Android...
My air conditioner has just stopped working with error code CH61 what does this mean?
Feb 13, 2011 | LG Heating & Cooling
Lg out door unit shows a CH23 error.What could the problem be? Could this mean that the PC unit has gone. Thanks Joe
Inverter dc voltage low. Check dc voltage of capacitors 300 Vdc for 1Ph and 600 Vdc for 3Ph. If OK change outdoor inverter PCB. Helpful?
Jan 04, 2011 | LG Heating & Cooling
Hi, I ve got a aircon LSZ244VM4 inverter and fault code is CH 61.Iam out of warranty 1 yr and the unit has already been replaced 1 time when it was in warranty.So what should i do now and what does CH61...
Ch-61.Condenser coil over 65°C. Check coil and filters are clean and free from debris, and airflow is OK. Check system pressures for non-condesables
Clean coil & filter. If non condensable gas, remove gas and flush out the system. Vacuum and recharge.
Jan 01, 2011 | LG Heating & Cooling
My LG Artcool isn't working keeps flashin ch 61
CH61 means Condenser coil temp high due to non cleaning of condenser/over charged gas/non condensable gas.
Clean your condenser coil. If still problem rests, due to non condensable gas also there will be high temp. kHnce remove the gas, flush out the system and vacumize and then do gas charging.
Dec 10, 2010 | LG Heating & Cooling
Error oC on epson dfx 9000
09 : FAN1 driver error
0A : FAN2 driver error
0B : FAN3 driver error
0C : FAN4 driver error
Jan 11, 2008 | Epson DFX-9000 Matrix Printer
Heating & Cooling Logo
79 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
