Question about Consew 206RB
Threading the bobbin is not smooth and even and tends to get hung up when sewing, how do I get it to work properly ?
Rewinding it
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 11 Answers
Please post the brand and model of your machine, and a picture of the area where you insert the bobbin.
Posted on Dec 16, 2014
I'm having trouble properly threading my Elna 1010. Could you please help? The bobbin thread keeps bunching up and breaking
bunching of thread under the material is an indication of insufficient tension of the needle thread
increase the needle tension until the threads meet at the center of the materialbeing sewn
Jul 26, 2016 | Elna Sewing Machines
Thread does not wound evenly on spool. Therefore when sewing it goes crazy with the thread on underside of fabric and then jams. What can I do to keep thread going on the spool evenly?
Your talking about the bobbin? If so your not threading it properly to feed the bobbin while winding. Sounds like you don't have the proper tension from proper threading.
Oct 28, 2014 | Simplicity Liberty SA1600 Mechanical...
Bobbin not winding tightly
Consult your owner's manual. Possibly, you are not threading the bobbin winder correctly. The thread does go through a tensioner somewhere along the way that creates tension on the thread.
Janome MEMORY CRAFT 9700 Instruction Book Threading For Bobbin Winding
Or perhaps the tensioner is not working properly.
If neither is problem, then you can always pick up a stand-alone bobbin winder (Amazon, JoAnn's, etc) for ~$30. One brand is called Sidewinder. These bobbin winders are marvelous because you can wind bobbins without unthreading your machine. It also saves wear and tear on your machine.
Or take your machine for service.
Mar 28, 2012 | Janome Memorycraft 9700 Computerized...
Stitch tension problem - bobbin thread lies flat or bunches. If you increase the needle thread tension there is no improvement - even at the highest needle thread tension the bobbin thread is a mess. Any...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 16, 2011 | Consew 7360R-1 Mechanical Sewing Machine
When threading Singer 57817 sewing machine, it won't pick up the
take out the bobbin, pull some thread from it. is it coming smooth without effort?
if yes, keep some thread outside and put back the bobbin and try again.
if thread is not coming out smooth, then check if something is stuck in the bobbin.
May 30, 2009 | Singer 57817 Computerized Sewing Machine
I am trying to do letter embroidery on my Futura 350 and I keep getting constant error messages about thread breaking even when there is no visible sign of that. Also, the bobbin thread side is bunching...
Check out your threading with "Machine setup" Tutorial under Help submenu and whether the thread tension control on the front panel is set to "E".
P.S. The error message about thread breakage appears not only when the thread is really broken but if the sewing speed is not changing smoothly (for example if design is not optimised).
Oct 06, 2008 | Singer CE-200 Quantum Futura Computerized...
Tread getting hung up in the shuttle
HI!
In most cases when thread is nesting, bunching, ect..it is a result of top threading. Be sure that you have the thread through the proper threading guides,most importantly, the "take-up lever" (that is the silver hook that moves up and doen in time with the needle). This should resolve the problem regardless of the machine.
Bonnie
Sep 26, 2008 | Sewing Machines
Kenmore 158.19141 help!!
Hello. The 158.19141 is probably the best Kenmore sewing machine around. I use two of this same model in my sewing/alterations business and they have been totally dependable. (I also have 3 vintage Kenmore computerized machines) but the 158.19141 is my favorite model. The problem sounds as though there is dust/dirt/lint in some of the parts in the machine. Take off the feedplate, vacuum and or use a lint brush to loosen any threads and lint. Take out the bobbin case and bobbin: inspect for lint and dust. Take out the bobbin shuttle (which tends to make the threads bunch if it has lint build up). Clean or vacuum, PUT A DROP OF OIL ON THE CENTER PIN, and replace.
Oil the machine regularly. If it has sat around for months without use, it may tend to get sluggish.
Make sure your feeddogs are UP. Use an appropriate size needle for your fabric and make sure it is set properly. The flat side of the needle has to be facing to the north of the machine; and make sure the needle is inserted entirely up and tightly into the needlebar.
Threading the machine properly and inserting the bobbin correctly is usually the answer to most frustrations with a machine. Good luck...and lucky you to have the Kenmore 158.1914 model.
Sep 24, 2008 | Kenmore 744-08BH Mechanical Sewing Machine
Janome Memory Craft 9500 Troubleshooting
Have you tried a new needle?
If re-threading, changing the brand of thread, etc. does not work, then it's likely your machine is out of time. Search for sewing machine timing or take it for service.
May 24, 2017 | Janome Memory Craft 9500 Computerized...
Consew 206RB Logo
95 people viewed this question
Top Consew Sewing Machines Experts
Michael Galve
Michael Galve
Shehu Pro
Shehu Pro
Irene Tulloch
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
