Question about Building Materials
The wall mount that connects to the pipe broke when the chain drive began to chatter. How do I reconnect this, and should the gear drive have some give or could this be frozen.
Disconnected from the door to allow free movement of the door. Could not separate the pipe enough to reengage with the wall mount
  • 3,368 Answers
Please consider getting a service tech. You may have to unbolt the mount, align it and put it back. There is not much give in the gear drive.
Posted on Dec 14, 2014
Honda unicorn drive chain is jumping with extreme knocking sound.
Try checking the gearbox oil level and adjust the chain.
Apr 03, 2017 | 2005 Honda Unicorn
Grinding noise when accelerating
HI If your bike is chain drive, look at the chain tension, the chain could be hitting the gear box case. If you primary sprocket is worn the the chain could be jumping teeth If you have a shaft drive then inspect the universal joints and the differential oil level
Feb 02, 2014 | kawasaki Motorcycles
Gear oil for 2004 honda crf 100
Fuel and ignition Sparks per cylinder: Fuel supply system: Carburetor Ignition type: Digital CDI Funnel diameter: 0.87 inch Compression: Engine mounting: Transverse Lubrication system: Wet sump Gear box: Manual 5-speed Clutch: Wet, multiple discs, cable operated Final drive: Chain Spark plug pipe type: NGK, CR7HSA Motor oil: Synthetic, 10W/40 Starter: Kick-starter
Jan 11, 2014 | 2004 Honda CRF 100 F
Timing chain 96 maxima broke
Check your owner's manual for the recommended mileage for replacing your timing chain. Replacement for a Nissan Maxima is 60,000 miles.2 Locate the timing chain. Replace it if the automatic chain adjuster (also known as the tensioner) is damaged or worn.3 Release the pressure in the fuel system, drain the cooling system and disengage the negative battery cable. 4 Undo the upper radiator hose, engine drive belts, power steering pulley and pump with bracket, air duct, passenger front wheel and engine side and undercovers, front exhaust pipe, cylinder head front mounting bracket and head cover, rocker cover, distributor and distributor cap and spark plugs.5 Take off the intake manifold support and move the No. 1 piston at "Top Dead Center" (TDC) of the compression stroke.6 Disconnect the cylinder head front cover, water pump pulley, thermostat housing, upper and lower tensioner and slack side timing chain guide, idler sprocket bolt, camshaft sprocket bolts, sprockets, mounting caps and camshafts. 7 Disengage the cylinder head with the manifolds, idler sprocket shaft, upper timing chain, center crossmember, oil pan and strainer assembly, crankshaft pulley, engine front mount and bracket and the front timing cover. Remove the oil seal and unfasten the timing chain cover, idler and crankshaft sprockets and the oil pump drive spacer. 8 Unfasten the timing chain guide. install Your Timing Chain 1 Grease the oil seal lip with engine oil and place it in the front cover. Verify that the No. 1 piston is at "Top Dead Center" (TDC) of the compression stroke. 2 Reconnect the crankshaft sprocket (marks should point toward the engine's front), oil pump drive spacer and timing chain guide and the lower timing chain. Line up all mating marks.3 Hook up the crankshaft sprocket and pulley, lower timing chain, front cover assembly, engine mount and front mounting bracket, oil strainer and pan assembly and center crossmember.4 Reattach the upper timing chain, idler sprocket (to the back side), cylinder head assembly, idler sprocket bolt and exhaust and intake camshafts. Place the intake camshaft knock pin at 9 o'clock and the exhaust pin at noon. Connect the camshaft bearing caps and distributor brackets and secure all mounting bolts.5 Eliminate any old material from the pan and cylinder block mounting surfaces. Rub on a 3.5 to 4.5mm bead of liquid gasket over the oil pan and cylinder block.6 Attach the upper timing chain to the idler sprockets and secure the cylinder head bolts.7 Refill the cooling system. Hook up the negative battery cable and any other disconnected items. Start the engine and look for leaks.
Oct 14, 2011 | 1996 Nissan Maxima
How to replace a waterpump on a 2001 olds alero 2.4 cam
Water pump is driven by timing chain idler and is mounted on the rear of the timing chain housing. Disconnect the neg. battery cable. Drain cooling system. Disconnect oxygen sensor connector.
Remove upper exhaust manifould heat sheild. Remove exhaust manifold brace. Remove lower exhaust manifold heat sheild. Loosen manifold to exhaust manifold spring loaded nuts. Remove radiator outlet pipe to water pump coverbolts. Disconnect exhaust pipe from manifold.
Pull down on the exhaust pipe to disconnect it from exhaust manifold bolts. Disconnect outlet pipe from oil pan and transaxle. If equipped with manual tranaxle, remove exhaust maifold brace. Leave lower radiator hose attached and pull down on radiator out look pipe to disengauge from water pump. Leave outlet pipe hanging.
Lower vehicle. Remove exhaustmanifold to cylinder head nuts. Remove exhaust manifold to cylinder head nuts. Remove manifould. Remove timing chain front cover. Remove timing chain tensioner. Remove bolts bolts securing water pump cover to cylinder block. Remove water pump to timing chain housing nuts. Remove water pump attaching nuts. Remove water pump and cover assembly. Separate componets as necessary.
WHEN INSTALLING WATER PUMP MAKE SURE YOU FOLLOW THE TIGHTENING SEQUENCES THAT AFFECT SEALING. My frist one I messed up and broke the pump so becarful.
Installation
If cover was separated from body during removal, join this componets with a new gasket and hand tighten bolts. Apply bearing grease to splines of water pump drive. Set body and assemble into position.
Install and hand tighten bolts securing cover to cylinder block. Install and hand tighten bolts securing cover to cylinder block. Installand hand tighten nuts securing body to timing chain housing. Lubracate outlet pipe "O" ring with antifreeze. (I use RTV) Connect outlet pipe. Install and hand tighten bolts. Tighten bolts and nuts to specification in the following sequence. I'll ad the torque spec. at the end but this is where if you tighten out of order something will break.
pump assembly to timing chain housing nuts.
pump cover to pump body bolts
pump cover to cylinder block bolts (Bottom Bolt First)
outlet pipe to cover bolts
To complete installation reverse removel procedure.
Torque specs are 19 in. or 26mm all except water pump cover bolts which are 124 in or 14Nm
I never torque the bolts just make sure there done in the right order.
Oct 19, 2010 | Oldsmobile Alero Cars & Trucks
How do you remove toyota timeing chain
Timing Chain and Gears Removal & Installation To Remove:
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Drain cooling system.
  3. Remove the upper front fender apron insulator.
  4. Remove the upper radiator support insulator.
  5. Remove the right front wheel and tire assembly.
  6. Remove the right lower splash shield.
  7. Remove the drive belt and alternator.
  8. Remove the air switching valve (XRS)
  9. Remove the power steering oil pressure switch connector.
  10. Remove the 2 power steering mounting nuts and through bolts. Remove the steering pump from the engine. Secure the steering pump to the cowl toy_car_15_wood_block_on_jack.gif
  11. Raise and support the engine with floor a jack. toy_car_18_eng_rh_mntng_inslt_blts.gif
  13. Remove the 2 nuts, 2 clips and the cylinder head shield (except XRS).
  14. Remove the 4 ignition coils.
  15. Remove the 2 ventilation hoses from the cylinder head valve cover.
  16. Remove the 9 bolts, 2 seal washers, 2 nuts, cylinder head cover and gasket (except XRS). XRS toy_car_18_eng_cylndr_hd_cvr_blts_2zz-g.gif
  17. Remove the 4 bolts and the cylinder head shield (XRS).
  18. Remove the 2 nuts, bolt and remove the ventilation hose from the ventilation pipe (XRS). XRS toy_car_18_eng_cylndr_hd_cvr_ventl_hs-pp.gif
  19. Remove the Ventilation pipe and gasket (XRS).
  20. Remove the 9 bolts, wire harness protector. Remove the cylinder head cover and gasket (XRS).
  21. Remove the O-ring from the cylinder head cover (XRS)
  22. Turn the crankshaft pulley and align its groove with timing mark "0" on the timing chain cover. toy_car_18_eng_tmng_mark.gif
  23. Ensure that the marks on the camshaft timing sprockets are in straight line on the timing chain cover surface as shown. toy_car_18_eng_tmng_point_marks.gif
  24. If not turn the crankshaft 1 revolution (360°) and align the marks as above.
  25. Remove the crankshaft pulley toy_car_18_eng_rmv_crnk_sft_pos_snsr_blts.gif
  26. Remove the 2 mounting bolts and remove the crankshaft position sensor.
  27. Remove the mounting bolt, nut and the drive belt tensioner.
  28. Remove the right engine mount bracket.
  29. Remove the front exhaust pipe (XRS).
  30. Remove the Exhaust manifold brace (XRS).
  31. Remove the Exhaust manifold (XRS) toy_car_18_eng_tmng_chn_tnsnr_blts.gif
  32. Remove the 2 mounting nuts and remove the chain tensioner.
  33. Remove the water pump. Except XRS toy_car_18_eng_tmng_chn_cvr_blts_1zz-fe.gif
  34. Remove the 11 mounting bolts and nut (except XRS).
  35. Remove the 12 bolts (XRS).
  36. Remove the stud bolt.
  37. Remove the timing chain cover and 2 gaskets.
  38. Remove the crank sensor plate.
  39. Remove the timing chain tensioner slipper mounting bolt. Remove the tensioner slipper. toy_car_18_eng_tmng_chn_sprkt.gif
    Note: If the crankshaft timing sprocket cannot be removed by hand, use 2 screwdrivers. Position shop rags as shown to prevent damage.
  40. Remove the timing chain and crankshaft timing sprocket.
  41. Remove the 2 chain vibration damper mounting bolts. Remove the vibration damper toy_car_18_eng_tmng_cntrl_assy.gif
  42. Hold the camshaft hexagonal section with a wrench. Remove the sprocket mounting bolt.
  43. Remove the valve timing controller assembly and timing sprocket.
Note: Be careful not to damage the cylinder head and valve lifter with the wrench.
Do not disassemble the valve timing controller assembly.
Oct 19, 2010 | 2005 Toyota Corolla
Chain is slipping and jumping gears
okay lets ask why it broke did it get jammed?was it worn?is your front crankset or rear gearset loose with play in it?does the chain make a clicking while pedalling hard? first and last require a replacement chain because it broke for a reason.if your drive gears are loose then you will have to adjust/repair them also checking adjustment on the derailuers should be checked.
hope this helps
Jul 13, 2010 | Mongoose Cycling
Doors will not lock or unlock. Where are the fuses?
The answer was sent to FixYa by rstelter.
The initial indication of the door problem was a chattering noise when a cleaning cycle was initiated. The cleaning cycle was then aborted and the door remained locked.
Here is the fix.
I restarted the cleaning cycle and when a chatter began I 'jiggled' the door until it opened. I removed the door lock mechanism (4 screws and two connectors) and found that the motor driven cam actuator cycle stopped in the locked position, a high point on the cam. I could not rotate the mechanism because of motor gearing, so I used a drill to remove the rivet heads from the motor mount, which also opens the motor.
The top half of the motor contains the motor and a small transfer gear. The bottom half attaches to the cam through gearing. I rotated the cam drive to the full open position and rotated the gearing to match. I reassembled the motor by attaching it with two 1-1/4" x 1/8" screws and lock nuts. After reassembly the oven works as new.
The main cam bearing is a shallow raised section of plastic riding in a hole in the thin steel frame of the mechanism, and the edge of the bearing is rounded. I did not inspect closely, but I believe there is a potential for binding, which may have stalled the motor in the locked position. Jiggling the door while the mechanism chattered may have relieved the binding enough to release the door.
I was quoted $129.00 just to have an Amana technician look at the problem in 'about a week'. I'm sure they would have replaced the latch with a new assembly (another week and another visit).
Dec 16, 2009 | Amana AEW4630DD Electric Double Oven
My '98 Escort ZX2 has 175,000 miles. I recently noticed a grinding or chattering with the clutch pedal depressed with the transmission in first gear. While stopped at a light the car suddenly began jumping...
Hi:
You need to check your clutch master cylinder reservour, not your brake cylinder. It is located approx in front of the clutch pedal, outboard of the brake cylinder. If it is low, you need to inspect for leaks around it, the lines connecting it to the clutch slave cylinder that is mounted on the transmission.
Dec 05, 2009 | Ford Escort Cars & Trucks
Building Materials Logo
Top Building Materials Experts
hpgwva
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
