Question about Acer Aspire 5750Z-4835, AS5750Z-4835 Charger, Power Cord
Acer laptop will not bootup
Laptop powering up then shutting down
  • 728 Answers
Hi John,
It sounds like it's not getting enough power from the adapter. Check the voltage on the adapter to make sure it's giving enough voltage to the laptop. You may have a bad adapter.
Posted on Dec 14, 2014
Testimonial: "well i suspected first if it was a bad battery first but it is not powering up anymore it did a few times without the battery but then it shutdown. so i suspect a bad power supply thanks for replying back"
  • Acer Master
  • 3,368 Answers
It sounds like a bad os or hard drive. Try booting a CD
Dell e5420 wont start up at all
Make sure no accessories are plugged into your laptop. First remove the battery and try a bootup. If does not bootup, remove the hard drive if you can and try again. If still no full boot, you can try the DVD drive and then the memory. Replace what you have found to be the problem. If none solves the bootup problem, it is either the power supply itself or a mainboard problem, which would required service from an authorized service center from Dell. Verify the center with Dell. The parts I have indicated to try are normally easily removed from the bottom of the laptop, by removing a few small screws.
Mar 15, 2013 | Dell Latitude E5420 Laptop Computer
Unable to enter setup in acer aspire 5315
You do not say what OS you are running. You could try F12 at bootup to see if you can get to the boot manager that way.
Jan 15, 2012 | Acer Aspire 5315 Notebook
Acer 7549-1284 shows acer symbol then goes to a black screen, it won't bootup
Well to start u need to go into the bios and shut off the acer splash screen. Then u can see where its hanging up at while its trying to boot.
Aug 16, 2010 | Acer Aspire 7520-5185 Laptop
Acer laptop goes off after 30 minutes exactly. wont come if i try immediately but after about 5 mins comes on when I power it. help
you have set ur computer to sleep or hibernate after 30 minutes of inactivity. you can customize this in you power setting.
Control Panel-> Power Options
Sep 27, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Need to reboot acer aspire without recovery disc
try in bootup using delete or F2 or F8 one of them should work for safe mode is the F8 for the mem the other two. good luck
Sep 09, 2009 | Acer Aspire 5610-4648 Notebook
Black screen.
A few questions up ahead please:
a. Is the power button lighting up when you press it or power on your laptop?
b. Is the battery fully charged?
c. is the power cable/charger still good when you connect to mains supply?
**If you answered YES to all the above...
Your laptop screen may be bad and as such must be replaced.
Otherwise, The windows operating system may have CRASHED.
If this is so, then you can try out this system recovery tips as the last resource:
1. try remove the hard drive which you can access by opening the back cover as shown in the owner's manual.
2. next, connect this through an external usb casing to another system and backup all files on the hard drive.
3. if you don't have an acer recovery cd(s) for your laptop, try get someone who has and can help you burn the software for your model and make.
4. next, format the hard drive before you reinstall it back into your laptop.
5. power on your laptop and continously press F8 to enter the bios setup.
6. Select bootup sequence and select boot from cd drive.
7. first reinstall a lower version windows os by inserting a bootable system software.
8. after installation, keep the cd rom drive open and shut down your laptop.
9. insert the acer system recovery cd into the cd rom drive and close shut.
10. Restart your laptop then, Follow the instructions and prompts.
Your laptop will be restored to the way it was originally from the manufacturer.
Jul 08, 2009 | Acer Aspire 5050-3242 Notebook
Acer Aspire 3100-1405
shut down the laptop. power it up, hit F8 when you see the horizontal scroll bar, select save mode and wait for it to load. once it is completed. right click on c:, click on porperties. check the scandisk under the tools tab. restart teh computer.
Nov 02, 2008 | Microsoft Windows XP Home Edition
Acer laptop bootup problems
Please try and bootup your computer in safe mode by pressing the F8 Button just before windows starts to load. a menu appears and you just need to select the safe mode option and see how it goes from there.
Let me know if this helps.
Oct 27, 2008 | Acer Ferrari 4000 Notebook
I was installing a program, and the screen went black adn the system shut down.
remove battery and try ac-power if laptop boots up then battery need replacing but if no laptop bootup then take it to be repaired and tell the tecnition what happened and he or she will try other options to get you going again. good luck on problem.
Aug 14, 2007 | Acer Aspire 3680 Laptop
Acer Aspire 5750Z-4835, AS5750Z-4835 Charger, Power Cord Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
