Question about Health & Beauty
Freerider WestminsterMy indicators and 4 way light do not work I have changed the fuse
  • 1,271 Answers
Hi, sadly the logic board under the tiller can go wrong ,,, i offer a free testing service... you only pay the return postage..
Regards
gewizrepairs.co.uk
Posted on Dec 22, 2014
Indicator not working
Check the light bulbs, the connections to the bulbs and the fuses for the indicators. Start with the indicator lamp fuses if all indicator lights are not working.. Their location is shown in the owners manual.
If the problem is isolated to just one or 2 of the lights, you need to check the wiring, the connections and the light bulbs. However there will likely be multiple fuses on the car covering the indicator lamps so check these also. I have 4 different fuses on my own car covering different indicator lamps so check the fuse information in your owners manual for details of which fuses cover which lamps.
If you do find a blown fuse is the cause, only replace it with a fuse of the correct amperage. If it is a 15 amp fuse that has blown use only a 15 amp fuse as a replacement.
If the fuses, wiring, wiring connections and bulbs are all fine, but non of the indicators are working, the likely problem is a faulty indicator switch on the steering column.
Feb 17, 2015 | 2003 Ford Focus
Why are my indicators and brake lights on fiat stilo not working
The indicators and 4 ways are usually on the same fuse, see if the 4 ways flash. If they do but the indicators don't then try the flasher unit or the column switch. Brake lights could be the brake switch on the pedal is loose or faulty. Get into the footwell and remove any trim allowing you to see the pedal mechanism. See if there is a switch with a couple of wires on it operated by the pedal. If so pull the wires off and with the ignition ON short them together and get someone to check the lights? If they are On then change or remount the switch.
Aug 08, 2014 | Fiat Stilo Cars & Trucks
Indicators & hazard lights
it is worht checking the fuses and also keep working the hazard light switch as they are not used that often they tend to get sticky on the con tacts and that will knock out your indicators as well if they start to work after working afer working the haz switck then change the switch
Dec 30, 2013 | Mitsubishi Outlander Cars & Trucks
My trailer light board LHS direction indicator works fine but not the RHS direction indicator, (fault tested and replicated with two trailer light boards). I cannot find relevant fuses in the glove box or...
problem most likely in the plug/connection wiring -- broken , loose or corroded
if the indicators of the vehicle work it is not a fuse problem but wiring and connection
Nov 18, 2017 | Land Rover Discovery Cars & Trucks
I have a 99 GMC Jimmy with the 4 wheel drive. I
check fuse and relay to switch if power to switch retest switch new doesnt mean not defective if no power check connections and wiring for damage or breaks
Dec 02, 2009 | 1999 GMC Jimmy
Freerider mayfair, no life at all in scooter
Look carefully , you will find a fuse , gently pull the wires around the seat stem , sometimes it can get buried under the power leads from the battery.
Regards
GeWiz
Sep 30, 2009 | Health & Beauty
No front lights work
check the headlight relays under the hood also fuses under the hood and in the interior fuse pannel.
Nov 18, 2008 | 1996 Jeep Grand Cherokee
Health & Beauty Logo
50 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
