Question about Garden
Tighten thechain where is the tightening scre
    Problem Solver:
  • 7 Answers
Follow the top of the chain back to where it mounts to the engine. It's small and inline with the chain. There is also a bolt on the screw that keeps the screw from loosening. Good luck
Posted on Dec 13, 2014
What is the cylinder head tighten torque
Have a look on this link. You may be able to find your car:
SPECIFICATION LOOKUPS
Cylinder head bolts are usually tightened to around 65 ft-lbs, depending on what the car is.
There's more than 4 cylinder head bolts... There's usually 10 bolts.
There's also a sequence for tightening the bolts:
cylinder head tightening order Google Search
When tightening cylinder head bolts do it in 'stages' and follow the sequence .. ie.. tighten the bolts finger tight first, then torque them up to about 25 ft-lbs. Wait 2 minutes.
Then tighten them to about 45 ft-lbs in sequence. Wait 2 minutes.
Do it again up to about 55 ft-lbs. Wait 2 minutes.
Tighten them up to 65 ft-lbs or whatever is recommended for your car.
Tightening in order/sequence pulls the cylinder head evenly onto the block. Waiting 2 minutes between stages allows a 'stretched' bolt to 'settle'.
Feb 17, 2016 | Cars & Trucks
I need the torque specs for replacing the valve cover gasket on a 2001 chevy cavallier 2.2 liter 4cly. thanks
This should do the trick, torque to specs then additional 90 degrees turn on all bolts
Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
  • Use the following sequence in order to tighten the cylinder head bolts: Tighten
    1. Tighten bolt 1 to 63 N·m (46 lb ft).
    2. Tighten bolt 2 to 58 N·m (43 lb ft).
    3. Tighten bolt 3 to 58 N·m (43 lb ft).
    4. Tighten bolt 4 to 63 N·m (46 lb ft).
    5. Tighten bolt 5 to 63 N·m (46 lb ft).
    6. Tighten bolt 6 to 58 N·m (43 lb ft).
    7. Tighten bolt 7 to 58 N·m (43 lb ft).
    8. Tighten bolt 8 to 63 N·m (46 lb ft).
    9. Tighten bolt 9 to 63 N·m (46 lb ft).
    10. Tighten bolt 10 (stud bolt) to 58 N·m (43 lb ft).
    11. Then tighten all bolts an additional 90 degrees
  • Jun 28, 2011 | 2001 Chevrolet Cavalier
    I followed the haynes manual to tighten up the head bolts on my 1995 mitsubishi pajero 2.8td exceed, supposedly, tighten up all uniformly to 100NM, back all the bolts off, tighten again to 50 NM, tighten...
    Cylinder head
    Renew bolts Yes
    Stage 1 Tighten 50 Nm
    Stage 2 Tighten 100 Nm
    Stage 3 Slacken off 360°
    Stage 4 Tighten 50 Nm
    Stage 5 Tighten 90°
    Stage 6 Tighten 90°
    Stage 7 Tighten M8=24 Nm
    Feb 12, 2010 | 1995 Mitsubishi Diamante
    Need to know what to tighten head bolts to on 1992 saturn sl1
    DOHC - Tighten all bolts in sequence to 22 ft. lbs. (30 N.m). Then tighten all bolts to 37 ft. lbs. (50 N.m). Repeat sequence, tightening all bolts an additional 1/4 turn (90 degrees).
    SOHC - Tighten all bolts in sequence to 22 ft. lbs. (30 N.m). Then tighten all bolts to 33 ft. lbs. (45 N.m). Repeat sequence, tightening all bolts an additional 1/4 turn (90 degrees).
    Torque Sequences
    Jan 26, 2010 | 1992 Saturn SL1
    How to hook up 2 solid copper wires to thermostat .
    Bare about 2" of the end and wrap it clockwise once or twice arount the terninal scre and tighten screw. cit off excess. Good Luck, Ned-
    Oct 09, 2009 | Heating & Cooling
    As I'm sewing the needle stops completely
    I unscrewed the screw that was in the wheel on the right , took the thingie out from the wheel readjusted some plate/washer, tightened it back up rescrewd it and wa-la it works.
    Apr 01, 2009 | Singer 3343 Mechanical Sewing Machine
    Shifting column is not working properly, tranny is ok
    Take the cable or linkage off the tranny. Push the tranny arm into park. If it is a linkage then adjust your linkage to match to tranny arm. If it is a cable with it disconnected see if it moves when you move the gear shift, The cable should move freely. You can pull on the end of the cable to make sure it is not broken. Make sure that your tranny arm moves in all gears. Please chalk the wheels so you don't get hurt.
    Mar 29, 2009 | 1994 Ford Aerostar Extended
    Torque specs for rod and main bearings
    please rate as fixya if this is what you want.
    rod bearings
    Tighten the bolts in three stages, using the sequence shown.
    • Stage 1: Tighten to 23 Nm (17 lb-ft).
    • Stage 2: Tighten to 43 Nm (32 lb-ft).
    • Stage 3: Tighten an additional 90-120 degrees.
    1. NOTE: Make sure to tighten the bolts in four stages.
      Tighten the bolts 1 through 20 in the sequence shown.
    Tighten the bolts 1 through 10 in the sequence shown.
    Tighten the bolts 11 through 20 in the sequence shown.
    Tighten the bolts in the sequence shown.
    Mar 14, 2009 | 1997 Ford F150 Regular Cab
    Need to know the torque sequence and ft lbs for a 1998 chevy cavalir 2.2 liter thank you
    I found two pieces of information, but no picture showing the sequence, but hopefully this will help.
    For the 2.2L engine. First Pass Long bolts 46 ft. lbs Short bolts 43 ft. lbs Final Pass Tighten all bolts an additional 90 degree turn.
    Jan 01, 2009 | 1998 Chevrolet Cavalier
    Chuck change
    After removing the screw and inserting the allen wrench shift the drill to the LOW position and turn the clutch to the drill only position. Use an allen wrench about the size of the chuck capacity so that it will not flex when hitting it with a mallet. Sometimes they are stubborn because of the torque but this should work. Put the allen wrench at about a 30deg angle and hit the wrench. I support the chuck on a workbench or a block of wood will do fine. The chuck has standard threads.
    May 10, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
    Garden Logo
    49 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
