Question about Sakar Hello Kitty 59009 Digital Mp4 Player
I got my daughter a Cyber Gear 8GB mp3 player. instructions said to keep off an charge for 2 hours. No battery indicator. just a page thats says loading. even after 2 hours of charging when I turn it
Mine is a cyber gear 8gb mp3 mp4 with video and music player. with changing faceplates. it's not a hello kitty one but the hello kitty one is on my instruction book. item number59378. So far I had it in off mode charged it for 2 hours. turned it on and all it does is say loading.
SOURCE: Lost instructions for the cyber gear slide click text messenger
to send hit
chat
then
type message
then push send
and the second call button
\to receve push chat the receve and Bamm!!!
Posted on Dec 18, 2008
  • 2692 Answers
SOURCE: Cyber Gear Slide Click Text Messenger
Here is the manufactures web site but they require you to regester to get the white sheets on your product.
]http://www.cybergear.com/index.php/Create-customer-account.html?return=referer
Posted on Dec 21, 2008
  • 7 Answers
you have to type the message in on messenger and have the oter messenger on reseve make sure the red light plastic parts are faceing athotor and when you want to send the message you push send and then real fast after you push send quicly pushcall icq they cant be farther then about 10 feet will work at around 1 ft to 5ft but the red light plastic part in the frount must be fasing one athor
  • 5 Answers
SOURCE: don't have instructions for cyber
password-you need to make one up like well 4444 or 9999 and p\i means press call at the bottom of the buttons then it'll say send that means it is sending
Posted on Jan 19, 2009
SOURCE: I got my daughter a cyber gear mp3 player model #
I encountered the same problem with the one I purchased for my 9y/o daughter. As it turns out, the player wasn't "technically" on. It was in "sleep mode". You need to do this Annie Oakley secret decoder ring nonsense to actually turn it on. You need to lock it, then UNlock it then hold the play key until it shows the little snowflake and says "welcome". Now if I could just figure out how to get the thing to play her songs...
Posted on Jul 26, 2009
How would i know that it is getting charged
When charging, the battery indicator will cycle from the current battery level to full. Once the battery is fully charged, the indicator will stop cycling.
Typically it takes approx. 6 hours to charge the battery from empty to full. (MMP8565 2GB Digital Audio Player)
Support Home Page
Feb 03, 2014 | Memorex Audio Players & Recorders
How long should I charge my trio mp3 player from my computer?
Several hours, it depends upon how flat the battery was before you started charging. The player may have a battery indicator that indicates the amount of charge in the battery.
Aug 12, 2012 | Mach Speed Trio h speed eclipse duo 4gb...
No problem just bought a mpd-1760 from someone its brand new never even been used ,but no instructions/need to know how long to charge battery for first time or at all //charging time for battery to watch...
To charge the battery back you want to
  1. Turn the power off the DVD player first as the battery pack will not charge with the power on.
  2. Attach the battery pack to the player.
  3. Connect the AC power adapter and the power cord to the player.
  4. Charging will now start and the Power/Charge indicator should now be orange.
  5. Do not unhook either cord until the Power/Charge turns off.
  6. Time of charging is approximately 4 1/2 hours.
  7. The battery pack will more than likely get warm while charging. This is normal. Keep it as much in the open as you can for the best ventilation possible.
  8. You will get a low power indicator on the screen when the battery has a low charge.
As for playback time you will get about 2 1/3 hours of actual playback and about 4 hours of standby with the DVD player actually on.
Regards, Tony
Apr 12, 2011 | Mintek Televison & Video
I have a Sansa View 8gb and the battery would die like within like 3-5 hours but when I connect it to my computer and go to properties I found that it was charged 84% what should I do about it?
What you need to do is let your player die. Then after it is dead keep turning it off and turning it on till it stops responding. This will run the player out of all battery charge. Then you will keep turning it on so that you can deplete the battery charge that your player sets up as a backup power. Then you need to plug it into your computer and let it charge all night. This will reset the player battery memory so that you can have full charge again. If this does not work your battery might be going out and you should look into either replacing it or investing into another mp3 player.
Oct 01, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
Battery on mp3 player dies alot
You have to charge the battery
Sep 01, 2009 | Audio Players & Recorders
Ipod nano 8gb Low battery Life
Umm i have heard that you are supposed to charge completely before you use them, also the more you charge it when it is low the less life it will have...
Jan 08, 2009 | Apple iPod nano
Battery won't charge
My MP3 Player will not connect to my computer. How do i charge it if it is a 1GB Philips GoGear MP3 Player?
Jan 24, 2008 | Philips Sport Personal CD/MP3 Player
Trouble charging
1. Plug in usb cable to computer.
2. Plug other end of cable into MP3 player.
3. Turn MP3 player on using the power slide switch. The display should change slightly to indicate charging. (Mine has a picture of a battery that will fill and empty...) Hope this helps!
Jan 12, 2008 | Audiophase MDP-1 Personal MiniDisc Player
Sakar Hello Kitty 59009 Digital Mp4 Player Logo
51 people viewed this question
Top Sakar Audio Players & Recorders Experts
Robert
Carlos L. Burgos
Carlos L. Burgos
Joseph Hoffmann
Are you a Sakar Audio Player and Recorder Expert? Answer questions, earn points and help others
