Question about Maytag MGR8674AW 5.8 Cu. Ft. Gas Range with Speed Heat and Power Cook
I have a Maytag MGR8674AW gas range. It is 2 years old and hardly ever used. The stovetop and bake functions work fine. The broiler does not. At first it worked sometimes if we turned it off and on a few times., now not at all. We can hear the igniter click but no gas. We tried lighting with a match. Still doesn't work. What could be wrong? How expensive to fix? Common problem?
  • 262 Answers
SOURCE: BAKE MODE NOT WORKING ON MAYTAG STOVE
the gas valve has gone bad change the gas valve and the glow bar (igniter) at the same time.or you WILL have problems in the future
Posted on Dec 18, 2007
jsrock516
  • 5911 Answers
SOURCE: Maytag oven doesn't light, broiler comes on instead
On some gas ranges, the broiler comes on with the bake selection during warm up. This allows the oven to preheat much quicker. More than likely, the control pad is functioning properly and your bake igniter is bad. Igniters become weak with age and eventually go bad. Since the bake feature is used more frequently, it typically goes bad more often. The following link provides you with some guidance on oven igniters:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
Remember: just because an igniter glows, does not mean it is good. If they become weak, they will not draw the required current potential to open the gas safety valve.
If you determine the igniter to be bad, you can obtain a replacement at searspartsdirect.com. Just type in your model number and go to the "Gas Controls" heading and look for item number 14 (part number 74007498). If the igniter plug does not match the plug you have on your oven, the instructions will guide you to cut the wires and splice the ends together. There should be ceramic wire lugs that come with the igniter kit. CAUTION: Make sure you only use the ceramic (heat resistant) lugs that come with the kit. Splicing with regular wire lugs or electrical tape will melt due to the heat. Additionally, make sure you UNPLUG the appliance before replacing the igniter. Live voltage potentials are still present with the range shut off.
I hope you find this information helpful. Let me know if you require additional assistance.
Posted on Nov 11, 2008
SOURCE: oven igniter problem
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. Amperage should be 2.5-3A. If less than 2.5A - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers : WB2X9154, 4342528, SGR403, 5304401265;
Those ignitors are interchangeable, if you can splice the wires. If not comfortable splicing wires - replace it with the first one in the list, should be direct replacement.
Posted on Jul 15, 2010
fieraci
SOURCE: I recently bought a used
I had same problem, same model. Twice in 4 years. Was the lower ignitor gone bad. First time I assume to old age. 2nd time wife overloaded a roaster pan and it overflowed during cooking, and got liquid/**** on the ignitor somehow and killed it.
New one is $43 (http://www.repairclinic.com/Shop-For-Parts?s=t-crg9700-%3d%3d) online. More like $65-75 locally.
Tip: Upper (broiler) and lower ignitors are identical. For a quick test: Swap out the top one to bottom position and see if it works.
It has just today happened AGAIN to me 7 months later. Hence my being online for this.
It's an old horse, and 2 burners up top are acting funny for some time now. Rather than throw more good money into it I think I may trash it and just buy a new stove.
Posted on Feb 03, 2011
  • 910 Answers
SOURCE: Unable to use either the oven or the broiler of
Can you smell or hear gas when you try and ignite the oven or broiler?
Posted on Jul 09, 2011
Whirlpool WFG510S0AS2 range - stove burners work just fine, but both the oven and broiler does not stay lit. NOTE - this unit has been converted from natural gas to LP
when the lp conversion is done , it is normally just a jet size change that is done
however the air shroud has to also be adjusted to get a clean blue burn of the flame
The just jet change results in a slightly yellow flame which is incomplete burn of the gas and that creates carbon build up at the jet and burners causing partial blockage
I would suggest that you call in an accredited gas fitter to check the problem and if necessary , clean the jets and adjust the air shroud
Dec 30, 2015 | Whirlpool WFG510S0AS
Gas broiler and bake over do not work, top burners work.
Could be a board problem or the safety valve. Hard to diagnosis without being there. I'm leaning towards the board if both both burners won't light...hope this helps...
Nov 30, 2009 | Kitchen Ranges
Oven wont bake
sounds pretty simple a bake element
Oct 03, 2009 | Jenn-Air JGR8750 Gas Kitchen Range
No oven baking function
You need to replace the oven ignitor. The ignitor has to draw enough current to open the gas valve. Your ignitor is either broke or not working properly, so the ignitor will not lite the oven.
Jan 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven will not work - Hi/Lo broiler works fine
you have a bad bake ignitor. it is mounted to the long tube in the very back wall of the tube. usually held on by 2 1/4 inch bolts. usually if you replace the ignitor you have to cut the old one off and hard wire the new one in depending on what the new connection on you ignitor look like.
Jan 26, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore Propane Range won't bake
The glow plug underneath the over floor need to be replaced
Dec 19, 2008 | Kenmore 36665 / 36669 Gas Kitchen Range
Maytag Gemini gas top oven does not work.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}I had the same problem, same symptoms...
You probably need to replace the baking igniter, (Igniter,bake burner
Part Number: AP4102011 made by MAYTAG).
I tested the igniter function by (CAREFULLY) jerry rigging a bridge to wire the BAKE igniter to the BROILER controls. (Push/click plugs accessible by opening up the stove back) Testing the broiler controls this way the bake element remained cold. I then did the same test but connected the BROILER igniter to the BAKE controls and got a good glow. This indicates that the controls work but the Bake igniter's faulty!
You can access the bake igniter by removal of 2 screws at the front at the platform just inside the top oven. The broil and bake igniters appear to be identical but the push/click plugs are reversed at the back of the stove. (hence the CAREFUL jerry rigged wiring bridge.) The parts and wiring are pretty simple and visual once you get the covers off. Opening up the stove back is just a matter of removing several screws. UNPLUG the stove before you work. If you test as I described, make all connections while UNPLUGGED and then plug it in only for the brief test. Unplug again while disconnecting/reconnecting. Hope this helps.
Jul 17, 2008 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Oven doesn't heat
sounds like you have a bad oven ignitor, although oyu see it glowing orange its not hot enought hoopen the gas valve, very common occorance. 2 maybe 4 screws and 2 wires, order aand replace the bake ignitor
Mar 26, 2008 | Kitchen Ranges
Oven not working
Check continuity on gas valve. the middle connector is common, upper is broil and bottom is bake. Resistance between common and bake should be about the same as between common and broil. I believe you'll need to set the ohmmeter to KOhms (or x1000.
If no continuity between any of the connectors - replace gas valve (not much fun, and part is expensive).
Jan 21, 2008 | KitchenAid KGRC707 Gas Kitchen Range
Maytag MGR8674AW 5.8 Cu. Ft. Gas Range with Speed Heat and Power Cook Logo
134 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
