Question about Vacuums
The tubing inside my water tank popped off. I am trying to find a replacement water tank, not having any luck though.
Took steam mop apart, but water tank is sealed shut.
    Problem Solver:
  • 5 Answers
Call Lowes Hardware and ask for the website of the company that sells replacement parts for common household items such as pressure washers, cloth washers and dryers, ...
Posted on Dec 15, 2014
2 Suggested Answers
wentlanv
  • 710 Answers
SOURCE: my gold shark pro mop (costco) steams inside the
Hi escada48036,
Sorry to hear about the problems your having with your Shark. One of our experts, heatman101 wrote a tip we have in our files. Here is the webpage for the tip: http://www.fixya.com/support/r5859780-euro_pro_shark_steam_mop_problem
Copy and paste this into your browser and the page will open up for you.
In the tip he describes pulling off the attachment and finding a small hole that comes out of the tank and leads to the hose. From your description, this sounds like what is plugged up. I think once you clear that, steam should flow through fine.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Posted on Jul 29, 2011
Shark Euro Pro Steamer
Hi, you could try the following steps, if you have not done so already. Some of these steps may seem like common sense, but it's for people to forget about checking the least expensive part to replace first, so if some of the steps are those that you have already tried, then feel free just to skip through to the ones you have not tried already.
  1. 1
    Make sure the power cord is plugged firmly into the outlet. The steam mop will not start if it the power cord is loose.
  2. 2
    Check the fuse box or circuit breaker connected to the outlet the steam mop is plugged in to. Replace any blown fuses. Reset any tripped breakers.
  3. 3
    Check the water tank if the Shark steam mop will not produce steam. Add water to the tank if it is empty. The mop will not make steam without water in the tank. To fill the tank, turn the tank cap counterclockwise and lift it up to remove it. Set the filling funnel into the tank opening. Pour water through the funnel into the tank until the water level reaches the "Max" fill line on the tank. Replace the cap.
  4. 4
    Inspect the microfiber cleaning pad if the steam mop is leaving water on the floor. If the microfiber pad is too wet, it will leave water on the floor. Unplug the mop from the wall outlet. Replace the microfiber cleaning pad. To replace the pad, move the latch strips out of the hooks on the mop head. Pull the pad off. Set the new cleaning pad on the mop head. Hook the latch strips onto the hooks on the mop head.
  5. 5
    Use distilled water if the steam mop is leaving white spots on the floor. Hard water may cause white spots to be left.
If none of the above work, then is it something that you purchased recently, and is new? If you did, then it could still be fixed under the manufacturer's warranty regardless of whether or not the original length of the warranty has expired. This could be due to the fact that you have received a product that has some sort of manufacturing fault, rather than it stop working through misuse by the user.
If it's a common problem, then you will more then likely be able to return it to the manufacturer and have it replaced for a new one, let alone repaired :-) - This only applies to whether or not the item is New though :-).
Hope this info helps
Apr 29, 2013 | Vacuums
Need a diagram of the water reservoir for the shark s3202
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Jan 06, 2013 | Euro-Pro Deluxe Steam Mop S3202 Upright...
It heats up but no steam
i just fixed mine tonight. it was heating but not releasing steam. i took apart the mop, not the head and found that the tube connecting to the heating element popped off....the spring inside the tube was also haning out. i found the metal clamp that was holding it randomly in there as well. i pushed the spring back in the tube and then pushed the clamped back onto the tubing, then pushed the tubing back onto the heating element then slid the clamp down over the tubing and the heating element and now my shark works great again!!
Mar 26, 2012 | Euro-Pro Shark Steam Mop - Gray/ Purple...
The mop just stopes making steam to the head. Could this be A heat coil problem? Also a lot of others have had This happen.
On these steam mops, you have to use distilled water, if you use tap water and do not have a house water softner or some kind of water filtration system, the water running thru the tubes of the steam mop
will develop calcium deposits, these deposits are caused by hard water and will clog up the tubes, and keep the mop from producing steam, then you will have to replace the lines. i own this brand of steam
mop and had the same problem you had, I replaced the lines and started using distilled water, and have not had any problems since and that was last year. good luck!
Aug 18, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark steam mop s3501 no steam
On these steam mops you have to use distilled water, if you use tap water and do not have
a water softner, the feeder tubes that pull the water to create steam will be reduced in size
and clog up. the only other option is to take it apart, and replace the hoses, i used some
small fuel line with spring clamps that i bought at an auto supply, it works! good luck!
Jun 26, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark steam mop will not syeam grey pruple shark steam mop
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Nov 04, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
The water tank is getting really hot,steams come out the sides of it but no steam is coming out the bottom.
I was having the same problem. No steam out the bottom. I took the whole thing apart and cleaned it...inside and the mop heads. I now get water to the heads but steam is still coming out the sides of the unit and leaking. I took it apart again and this time had my husband look at it. He found a tube with a spring in it...the spring had punctured the side of the tube and was leaking inside the machine! I am really upset by this as the machine never really worked right from the beginning but I really did not know it was not supposed to work this way. Now the machine is over a year old. I will be calling tomorrow and complaining but am not very optimistic that they will do anything and from what I have been reading will NEVER buy another one!
Sep 03, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Took apart the s3101 and there is a long spring inside..where's it go. It's not obvious
The long spring goes over the plastic tube that goes to the head to support the tubing...
heatman101
Jun 19, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My shark steam mop heats up but won't steam. help
Problem: mineral dleposits. Just fixed mine.... DO THIS OUTDOORS. Add 1/2 c CLR to the tank, let sit for an hour, turn on, allow to heat and pump. May have to refill with CLR and repeat. Be persistent, and eventually you'll blow out a wad of dissovled minerals followed, happily, by billows of steam. Again, do this outdoors and keep the mop pointed away from people, plants and things. (I aimed mine into a cardboard box.) Follow up with a couple of tanks of water and pump until empty to clean out any residual CLR and loosened deposits. (I continued to get some black precipitate through the first water cleaning.) I will add that I began this process first with white vinegar, then with Lime Away..no luck put perhaps I was not sufficiently persistent. Or perhaps it was the sequence of attempts. (Also, do not take off the mop head...the part to which you attach the pads...it's tough to get off, does not allow access to parts that need cleaning (thought it would, not not so), and practically impossible to get back on.)
Alternatively, call Shark...they'll offer to repair for $18 plus $10+/- shipping, or may offer you a new one at "preferred customer" rate of $39.95 plus shipping. Good luck, and please remember to try the CLR outside.
Jan 10, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark steam mop
I had the same prob and found this site off google looking for the solution.
I went back to my shark and took out all the screws, some don't feel like they were coming out but it came apart. Take a pair of pliers and release the spring clip holding the hose to the heat nozzle. Then pull off the hose. Then take a paper clip, unkink it so it's sort of straight with a curve to go into the hole . Shove it in and out to clean out the hole. I got my fingers blasted with residual steam so you should let it cool first. But I think the steam bursting out helped clean out the hole. Don't throw it away till after you try that..It worked great after that. All the best, Satch
Oct 09, 2008 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Vacuums Logo
41 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
