Question about Kitchen Appliances - Others
I have a pressure chicken Broaster 1600 electric I just got it in used and it will not heat up all the way what do I do
  • 3,368 Answers
Take it back before the warranty expires.
Posted on Dec 14, 2014
3 Suggested Answers
SOURCE: I need wiring diagram for a Broaster pressure fryer Model 1800E
I have a service manual for the 1600 and 1800 Broaster and it has wiring diagrams in it
Posted on Dec 18, 2010
  • 910 Answers
SOURCE: Can I convert a Model
As shown in the literature at the link below it can be connected to a 1ph or 3ph supply. The only requirement for a 1ph supply is that the circuit its connected to can cope with the additional current. Do you know what supplies you have available?
http://www.broaster.com/pdfs/lit/1600-lr.pdf
Installation instructions supplied with these units detail how this can be done but they don't appear to be available, but I'll keep looking.
NOTE: - These works should only be carried out by a qualified electrician.
Posted on Jun 12, 2011
I have a broaster that turns on but will barely heat the oil. Does anyone know what would be causing this?
Is it made by the Broaster Company or a spin off like a Henny Penny? Is it gas or electric? If by the Broaster Company would it be a 1800 or a 1600? Give me this information and than I can tell you what the problem is. Not an expensive fix either.
May 09, 2014 | Broaster Pressure Fryer
I have a broaster fryer, and the pc board had burned out (possiblyt due to incorrect installation) need new board or can anyone fix it?
Replace the board. But first make sure the installation is correct. Then double check to see that the installation is correct.
Oct 05, 2013 | Broaster Pressure Fryer
Have a oil leaking problem in broaster chicken fryer
Faisal,
I am a Broaster distributor, and have parts available. Which model do you have, and you are saying the bottom drain valve is leaking, correct?
Jon
jondf1@gmail.com
Mar 14, 2013 | Broaster Pressure Fryer
Converting from Natural Gas to Liquid Propene
Banglasoya,
We have a Kit available for this if you have not resolved the problem yet!
Jon
jondf1@gmail.com
Jan 11, 2013 | Broaster Pressure Fryer
Broaster 1800 machine is over shooting oil from top back steam valve and the valve that goes to little bucket in front
Dan,
Sorry, I am new to this site, and did not know about it until today. I am a Broaster distributor, and have the parts available. Couple questions if you have not resolved issue yet. Does your pressure guage work? If so how much does it read with about 8 pieces of chicken in a load?
Jon
jondf1@gmail.com
Dec 16, 2012 | Broaster Pressure Fryer
I need wiring diagram to broaster 1400E chenge a 220 voltios
GVE_10
That is a tough one, as 1400E has been out of production for 30 years. Parts have been discontinued for about 20 years. When you say you need to change voltage, that machine was made as 208 0r 240. 240 machine was always fine on 220 volts. 208 machine could burn out heating element over some time, but since you cannot buy other elements anyway, I would just go ahead and use the machine. If your real question is how to convert from 1-phase to 3-phase or vice versa, that is different story, and I can help you with that.
Jon
jondf1@gmail.com
Dec 07, 2012 | Broaster Pressure Fryer
Pressure not building in 1800 broaster
In order to build pressure, you need to first make sure that you have enough product to generate enough steam to build pressure. In a Model 1800 you need about 5-6 pieces of chicken or the equivalent to build a sufficient amount of pressure. You also have to have enough heat to create the steam, so check the oil temperature with a thermometer to make sure the actual temperature of the oil is close to the set temperature. If you have enough product at the proper temperature but no pressure is being generated, you need to determine where the steam is escaping. If the steam is escaping around the cover, replace the cover o-ring. If the steam is escaping from the exhaust stack in the back right corner of the unit, then your pressure regulating valve needs to be cleaned or rebuilt. The pressure regulating valve is mounted to the front of the cooking well just below the countertop. If the unit is several years old you should go ahead and get the rebuild kit for it.
Apr 09, 2012 | Kitchen Appliances - Others
I have a Broaster 1600-1800 electric model and it takes about 3 hours to heat up. The digital readout blinks on and off saying both lo and intermittently going completely blank. After it heats up the LED's...
If the digital display is going blank, but the Power On light is staying on, the problem has to lie in either the Controller Transformer or the Controller. To determine which, just check the voltage at the 2 red wires that go from the Controller Transformer to the back of the circuit card. That should read around 26VAC whenever the Power On light is on. If the voltage is still present when the Controller goes blank, then the problem lies in the Controller. Contact The Broaster Company through their website, www.broaster.com, and call the Service Department. They can easily provide a Service and Parts Manual to you, as well as help you troubleshoot your problem. Good luck and I hope this helps.
Feb 03, 2011 | Kitchen Appliances - Others
Nov 03, 2009 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
71 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
