Question about Del-Rain 1500-V 1500 Watt Ceramic Heater
I need a new foam rubber filter for my Del-Rain 1500V Ceramic Heater.
I just need a new foam rubber filter. Mine is falling apart.
2 Suggested Answers
mrgrzz
  • 88 Answers
SOURCE: Del-Rain 1500V ceramic heater switch.
is it a little rocker switch ? if so any local hardware store, like HD, or Lowes, or any appliance wholesaler will carry these switches, or try online to the manufacture, hope that helps
Posted on Jan 20, 2009
I have a 2004 new beetle convertible, automatic transmission. The cover strip on the shift mechanism disintegrated. Is it safe to shift the gears when that's gone?
I cannot see any immediate problems as it is only a trim cover. IT may be contributing to the reverse problem by bunching up and not allowing full selector movement. Some heater defroster units used foam strips around the core to prevent air from being drawn around the core and not through it as it lowers the heating efficiency of the heater unit. IF you are really interested you may check out the heater unit otherwise face the vents on the dash down so that you do not get foam bits in your eyes while driving.
Feb 01, 2014 | 2004 Volkswagen New Beetle Convertible
Sparking-i have 2 model lt-1500vi
I have had the same problem. I took it apart and found that one of the metal discs was corroded and little fragments were chipping off causing it to spark. I am looking to find a place to buy the disc.
Nov 01, 2013 | Del-Rain 1500-V 1500 Watt Ceramic Heater
How do I clean the glass plates in the flair living air f141023
Usually a mild cleanser is all you should need. In some extreme examples you to clean the contact area and the contact itself for ptting, and then lightly rub the mesh with 600 grit finishing paper to break up the silica that may have formed.
Ozone itself is a power oxidizer, it will clean the air in an enclosed room. Excessive Ozone "can" be a problem that usually manifests itself as upper respiratory irritation. Lower levels oxidize with pollutants and you never know it's there.
Ozone will also attack eurethane foams, foam rubber, and elastic rubber. So speaker surrounds usually decompose, and headliners in cars often fall apart about 6 months after exposure-used car dealers use them a great deal to kill residual tar and soot from smokers.
Feb 05, 2012 | Ecoquest Air Purifiers
Del-rain model lt-101 does not blow hot air only cool air!!
most likley the high limit,you can check with ohm meter,or simply short it out,but thats a fire hazard.if element is burned out is junk.again check with ohm meter.
Dec 22, 2010 | Del-Rain LT-101A 1500Watt Ceramic Heater
How many amps is this model
Like all 1500 watt appliances, 12.5. You divide the watts by the volts to get the amps (except for reactive loads like motors etc.). Why do you ask? Is it popping breakers?
Nov 15, 2010 | Del-Rain 1500-V 1500 Watt Ceramic Heater
When I turn it on it beeps constantly. It has been sitting idol for a few years. Need a manual too.
Check to be sure that it is sitting level to start with.
Second, unplug it. Blow it out with the hair dryer. Look for any breakage in the cord.
Nov 07, 2010 | Del-Rain 1500-V 1500 Watt Ceramic Heater
Jan 20, 2009 | Del-Rain 1500-V 1500 Watt Ceramic Heater
Heater smells like it got too hot!
check for dust in the air path through the heater. the fan forces air through the element.  if you have an air blower - blow air in a reverse direction through it.
Oct 15, 2007 | Del-Rain 1500-V 1500 Watt Ceramic Heater
DEL-RAIN 1500W MOVABLE HEATER
can you read resistance across the ceramic element?
Sep 11, 2007 | Del-Rain 1500-V 1500 Watt Ceramic Heater
What is name and address and phone contact customer service of del-rain?
Private Company, Headquarters Location 4808 Wilton Ave., Niagara Falls NY 14304-2145, United States (716)283-0060, Primary SIC: Heating Equipment, Except Electric, Primary NAICS: Heating Equipment (except Electric and Warm Air Furnaces) Manufacturing Description: Heating Equipment, Except Electric Hope this helps :)
Oct 18, 2006 | Del-Rain 1500-V 1500 Watt Ceramic Heater
Del-Rain 1500-V 1500 Watt Ceramic Heater Logo
47 people viewed this question
Top Del-Rain Heating & Cooling Experts
Paul Carew
Tim Whalen
Are you a Del-Rain Heating and Cooling Expert? Answer questions, earn points and help others
