Question about Frigidaire Refrigerators
Compressor runs and puts out the correct amp no., all fans run, coils clean but freezer and refrigerator maintains a steady 50 degrees and frost forms on first coil only of evaporator. Frigidaire mode
Replaced relay switch with hard start 3 in one. Cleaned all coils (which I do on a regular basis so see no issue there). Ran amperage test on compressor and it registers normal (6). Model number is FRS26H5ASB4. Compressor is Tecumseh.
  • Frigidaire Master
  • 744 Answers
Hello Suza;
My name is Peter. I am a retired field service technician.
I am sorry for the bad news. You have a restriction in your seal system. You should have a even frost pattern on all of the evaporator coils. You probably have a large block of ice in the upper right corner of your evaporator coil. The is where your capillary tube is. It is a small tube where the high pressure (165 PSI) liquid side turns to the low pressure (65 PSI) vapor. The thru hole in this tube is about the size of a small sewing needle. Broken down refrigerant or oil from the compressor can plug this tube.
You may have a refrigerant leak at tubing joints. If you feel an oily substance around the joint you have a leak.
Purchase your next unit at a Sears Outlet Store. You get a full year service contract and will save a couple of hundred dollars.
The part in your unit are probably worth a couple of hundred dollars. Strip the unit and sell them on Ebay. When you remove the control boards ground your self by touching something that is steel. Static electricity will knock out a board.
Posted on Dec 13, 2014
  • Peter Goodwin
    Peter Goodwin Dec 14, 2014
    Hello; This is Peter again. I forgot to mension, you can go into the following website type in your model number, you will see diagrams of parts to save as well as the price if they were new. http:/www.searspartsdirecr.com
Freezer only gets down to around 18 degrees but fridge is fine. No frost on the freezer evaporator fan is running
Modern consumer refrigerators only have coils in the freezer. In the lower back of the freezer there is a small fan and possible a damper (flap that opens/closes) to push cold air from the freezer to the refrigerator. Given that the freezer is 18 deg, it's probably cold enough to keep the fridge area at typically 34 deg.
So the cooling system (compressor, coils, thermostat) are not working properly to keep the freezer at, typically 0 deg. Possible causes: partial loss of refrigerant gas, icing around evaporator coils (in freezer), compressor failing, dust clogging condenser coils (under fridge), condenser fan clogged or broken (under fridge), thermostat failure.
I'd start with condenser. Remove the slotted trim at the bottom front and look in with a flashlight. Are the coils clean? Pull out the fridge and remove the lower back cover (usually cardboard). You can now see the coils and fan. Clean and blow them out.
If it's icing, it probably means freezer door not closing tight. If auto-defrost not working properly it would probably get worse over the period of a few days so not likely.
Apr 21, 2016 | Frost Refrigerators
Frost forming on top/front panel in freezer side subzero 632
In your freezer section there are 2 door switches -- press each one. One turns off the light. The other turns ON the freezer evaporator fan. If the freezer compressor is running the evap fan should RUN when the switch is depressed. If not, the fan motor is defective OR the switch is defective. Easy to troubleshoot the switch - just pry it out with a screwdriver, short the terminals with a piece of insulated wire. If the fan runs, it's OK and the problem is the switch.
If it's the fan, it's not hard to replace. Get replacement motor, turn freezer control to off, remove food and shelves, then the back sheet metal panel. Fan is right behind the panel.
Aug 02, 2017 | Sub-Zero Overlay Design 632/O Side-By-Side...
GE Profile Side-by-Side running warm
If it's cutting off at too high a temperature it is a good possibility the probe is faulty. However if the compressor is not cutting off at all, suspect short of gas.
Apr 24, 2012 | Refrigerators
40 TO 50 DEGREE IN SIDE REG/ FREEZER 32 DEGREE IN FREEZER. HOWEVER CLEANNING RESET DAILS BRING US 10-0 DEGREE FREEZER/ REF 32-38 DEGREE IN REF. THIS REF WILL NOT SABLE ITS SELF. WINTER TIME NO PROBLEM/...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 16, 2011 | Hotpoint Refrigerators
Refrigerator & freezer compartments @ 64 & 24 degrees F. respectively.condenser coil clean, however, "clean condenser coil" appears on display even after being reset. circuit board...
heatman101
Apr 16, 2011 | Sub-Zero 650 / O Bottom Freezer...
Doesn't cool as much as it should -- freezer, on
Does this model have a condenser fan that blows air over the condenser coil(coil on the bottom of the unit)? If it does then does the fan run?The fan has to circulate air over the coil to remove the heat from it. If the fan doesn't run then the compressor will overheat and cycle off then on on the internal thermal limit inside the compressor and the system will never come close to cooling as it should.
Nov 12, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer not freezing
when the freezer is not freezing, check the fan and fan motor in the freezer section. It should be running when the compressor is running. Check for frost. If you see frost on the rear inside panel, the frost is usually about 3 in. thick on the inside. Check and make sure the fan next to the compressor is running, if your's has one. It will run when the compressor is running. Check for gaps in your door gasket. If there is no frost, both fans are running, compressor is running, and no gaps, and your coils outside the refrigerator are clean, it doesn't sound good.
May 04, 2009 | GE Hotpoint Top-Freezer Refrigerator
Freezer works but refrigerator is staying at 60 degrees
listen to hear if you can hear the evap.fan motor running.check to see if you have any frost built up on freezer back panel.if so you have a defrost problem.clean coils under ref. and make sure condensor fan motor is running,that is by the compressor.
Mar 06, 2009 | Frigidaire GLRS263ZD Side by Side...
Refrigerators Logo
70 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
