How do I fixture an issue with the color being on the red side and dark with a ghost when there is action?
Abouth 6 months ago I came home from work and my picture was dark, on the red side and whenever there was action the characters had ghost images. I came home one day and the picture was fine; I didn't do anything to the TV. It has happened again andI called cable and they verified it was not the cable.
    Top Expert:
  • Televison & ... Master
  • 74,459 Answers
Fault with its main board. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Dec 14, 2014
WD 73835 has ghosting images during dark or red scenes
Make sure your contrast isn't set too high. Most ghosting is caused by either contrast, brightness or tint issues. Try adjusting these settings. Also check if there is a Dynamic contrast setting for your TV as well as this can cause ghosting also.
Apr 06, 2014 | Mitsubishi Diamond 835 Wd-73835 73" 1080p...
My hitachi 55" ultravision hdtv has a green pear shaped color on the screen, only when it has a dark background, other than that no distortion, no blueing in the corner, no blurriness, nothing. What i
Damaged Optical light engine, this is not the only Hitachi with this problem the ones before the oval was red and was finally settled two years ago in a class action lawsuit.
Dec 15, 2012 | Hitachi UltraVision CineForm 55VG825 55"...
Red is ghosting to the right. i replaced the convergence tubes about 6 months ago. went with the expensive ones "not the cheapy's" used heat sync putty stuff and everything. the problem is...
Yes,the tv problems it is the same,it is the tv convergence problems again,now it just color it is shaded in shadows pictures,instead of wavies mis colors R,G,B mis alignments.Yes.The tv convergence board it is the problems,must be repair again.
Apr 27, 2011 | Sony KP-57WS500 57" Rear Projection...
My timer has been working fine for the last 6 years. I replaced the fixtures about a month ago and a couple of days ago I noticed the timer was about two hours off...Does anyone know what the problem...
John, This came up under chain saws, but I assume this is an electrical timer and the fixtures you replaced were the light fixtures that this timer controlled. Maybe the timer is about 2 hours behind and the fixtures took about 2 hours to replace, during which time the power was off and the timer did not run. Sorry if this seems too simple and obvious and you already thought of it, but you haven't given me much to go on.
Aug 11, 2010 | Garden
Hitachi 53SDX20B
Hi, common issue but difficult for lay person to fix, tube sockets and spark gaps on crt boards need to be cleaned, hard to get at but most local shops have probably done more than once, if you want to attempt get back to me & I`ll explain further, video-tek
Jun 09, 2009 | Hitachi 53SDX20B 53" Rear Projection...
We are getting ghost images and the color is not correct
I have red concave lines going across the screen, plus wording appears double like a ghosting effect, this is ongoing from the time the tv is turned on until it is turned off. This started 3 days ago. Is it time for a new tv, its 9 or 10 yrs old now.
Mar 29, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Shadowing
GOOD DAY ND GOOD LUCK;
TRY THIS, IT WILL CORRECT CONCERN:
50V500 ONLY
GHOST: May be described as "Out of Convergence" but ghost is still attached to main image.
CONDITION:
A "ghost image" appearing to the left or right of images in the picture. Can be varying shades of a primary color (red, green, or blue) as well as gray. Can easily be seen in the 4 x 3 mode, at the edges of the picture.
CORRECTION:
To correct the problem, please do as follows:
  1. Access I2C Menu. (See page 57 of the Service Manual).
  1. To enter the I2C Service Menu, with power off, (on the front control panel) press and hold the INPUT button. Then press the POWER button for two seconds. The following Service Menu will appear.
03b_ghost_image01.gif Figure 1
  1. BEFORE CONTINUING: CONFIRM THAT THE R, G and B DRIVE ARE SET AT 40.
  • Be sure to press SELECT after each change to SAVE the new Data.
  1. Using the Remote Control joy stick, scroll down to next page (see Figure 2) until LCD ADJUST is highlighted.
03b_ghost_image02.gif Figure 2
  1. Move the joy stick to the right to cursor right once. The next page will appear with the word GHOST highlighted.
  2. Cursor right again, and a white screen will appear with a BLACK SQUARE in the center, as in Figure 3. You will see LCD ADJUST, followed by “SHP” and a number (value).
Figure 3
  1. If the unit is out of adjustment, you will see a gray ghost on either side of the black square. Move the joystick to the right or to the left until the ghost disappears. The number values will change up or down.
    • If the ghost adjustment is off with a lower value, there will be a ghost to the left of the square.
    • If the ghost adjustment is off with a higher value, there will be a ghost to the right of the square.
  2. Once you get the square to look good without ghosts, press "SELECT" to save any data values that have been changed.
  3. Press the "EXIT" button three times to return to normal picture.
  4. Adjustment is completed
  5. I HOPE THIS WAS HELPFUL, big IRISH.
Jul 26, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
