Question about Yamaha RX-V2600 Receiver
I have sirus sat radio...on the back of my v2600 there is a area for an antenna or some kind of connection. can you explain the purpose and what i need to use it.....
The receiver has imput for satelite radio but i dont have what i need to use it...
    Scholar:
  • 152 Answers
You need to get a satellite receiver compatible with your stereo
to hook up to that connection
Posted on Jan 04, 2015
Can you connect a siris or Delphic this to a yaesu transceiver
most yaesu transceivers are not capable of tunning the wide band FM broadcast band needed to hook up sirus or delphi satellite radio
Nov 28, 2014 | Yaesu Radio Communications
The signal will be fine for a while, then I get a "no signal" message...I usually get this after the radio has been on for a time
Hello
Please send me the model number of your Sirus Satellite Radio, and let me know whether can I place a solution before you. Ok.
Apr 02, 2011 | Sirius Satellite Radio Receiver
Can't found a blow fuse on a audiovox sirus sat
TWIST OPEN THE END OF THE CIGARETTE LIGHTER ADAPTER AND YOU'LL FIND A GLASS FUSE IN IT.
BE CAREFUL THERE MIGHT BE A SPRING IN IT THAT HOLDS FUSE DONT LOOSE IT.
Oct 20, 2009 | Audiovox SIR-PNP3 SIRIUS Radio Receiver
My sirus radio displays "aquiring signal" it has worked perfectly for 2 years and now I can't get anything
I had the same problem. If your radio is a kit and not factory installed in your vehicle it could be the magnetic antenna on top of your car. I had mine for about two years and from moving the radio around, or docking and undocking it, the wire from the antenna broke. It was not cut all the way through but it was enough to cause it to loose the signal. Check your antenna where it plugs into the back of the unit.
Oct 03, 2009 | Sirius Satellite Radio Receiver
2004 Jetta Radio
check the antenna ground to the chassis of the car.
May 28, 2009 | 2004 Volkswagen Jetta
Sirius satellite radio
Make sure the antenna has a good line of sight. Sirus works best when pointed in an Easterly direction. By default you should get channel 184 if there is no service activated on the radio.
All Sirius radios can be used for service only in the United States and Canada.
If you feel that the line of sight is ok and there are no obstructions from pointing your antenna either out of a window, on top of the car, or outside if it is used in a house, then try a different antenna. If you are using the smaller guage antenna wire, the connections can break inside during installation in a car from time to time.
If the radio is factory installed contact sirius at 1-888-539-7474 to see if they can see the radio on their end.
Oct 19, 2008 | Sirius Satellite Radio Receiver
Sirus radio
after the guys installed it ... u had to reset the radio... pen size reset under the volume... u have to reset it for siruis to work.. the only thing works is ch184 until u subscrbe
Apr 05, 2008 | Kenwood KDC-MP235 CD Player
Sirus radio
I had the same problem and I replaced my car antenna. That resulted in immediate signal improvement. But three months later, the same thing. So, another dot micro car antenna. Three months later, the signal went out again. The home kit worked perfectly. In my case, I bought a Sirius outdoor home antenna and replaced the standard indoor/outdoor antenna that came with the home kit. I took the home kit antenna and connected it to my S50 car kit and positioned the antenna on the front of the dash. No problems since then. Not one. Those dot antennas are horrible. I'd check that before getting a new radio.
Jan 13, 2008 | Sirius Satellite Radio S50-TK1 Satellite...
Yamaha RX-V2600 Receiver Logo
51 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
