Question about Furniture
How do I get the base to stay on chair 98508CHN01
Followed manufacturers directions of inserting pipe of base into the hole of the brace for the bottom of the chair. Pipe will not go through the top hole to the cross brace.
dennymulford
  • 1055 Answers
SOURCE: how to lay out 3'' pipe 45degree to 10'' pipe size
measure both opens from center too floor then mulip;t it times 1.41 thats your cut piece
Posted on Mar 25, 2009
MPetro302
  • 298 Answers
SOURCE: fuel line from carburettor - is this a return feed?
usually their will be a tube leading off the carb to let excess flow drain from the carb to aviod flooding.
Posted on Apr 20, 2009
arauzvictor1
  • 466 Answers
SOURCE: replacing water pump and pipe that crosses through the engine
Ok if you replace the water pump has to disassemble the front of the engine time to remove the belt to replace the pump tube If you have to remove the intake manifold to ban the base where the nozzles and have a good space for I hope to change the tube will serve this thanks
Posted on Oct 18, 2009
SOURCE: Fabric softener does not drain out
I'm having the same problem with the fabric softener dispenser not emptying and filling with water. I, too, have cleaned everything out and there are no clogs. What's the solution?
Posted on Aug 02, 2010
  • 157 Answers
SOURCE: Trying to install a Maxx
Hello. You're not going to believe this, but MAXX says that the drain and the wall pannels (glued) will keep it in place if the floor is properly leveled before. Personally, when I installed mine (model 105525 - exactly the same installation instructions) I used silicone on the base at each stud area. it's secure, but not permanent, and won't allow an area for a crack to form.
Hope this helps.
Posted on Mar 26, 2011
Trying to locate a distributor/repair person who has a MH194V-0 (2 1/2" x 3") circuit board for a human touch EMS-12 massage chair
3ways you can get this information
1-- go to a retailer of the chair and find out where it can be repaired --that will get you an authorized service agent
2-- call the manufacturer direct for a list of authorized service agents
3--- go google and type in-- manufacturer of ems 12 massage chair-- and click on the distributor / service agents tab and call them direct on the phone
Nov 14, 2016 | Furniture
I would like to find out how I can order a replacement arm rest
depending on what chair you have the cheapest option is to try and get a generic replacement, search eBay for "wheelchair arm rest" they start from around 10 UK pounds or you might be able to find one from the same make and model.
if not then you need to search the web for the make and model of chair you have followed by "parts arm rest" so if you have a pride jazzy 1121 you would search google for "pride jazzy 1121 parts arm rest" that should point you to a replacment, if no joy there another option is to contact the makers, again search for maker to find contact info, or look for a dealer that sells the make of chair you have.
if this helps please click "yes" to let others know.
Oct 06, 2014 | Health & Beauty
Just bought some dining room chairs and we can't see how to attach the cushions! Is there a secret way of doing it?
By cushions if you mean the seat then all it needs is a few wood screws to fasten to the base. if there is no hole for screws in the base frame then you could fix these with angle brackets.
Aug 24, 2014 | Furniture
How do I replace rear exhaust manifold gasket on my 91 Buick regal
Not much room to work there, eh? On GM cars, there's a procedure called "rotating the engine forward". It tethers the engine in a forward-leaning position so you can work on the backside, gives you a few inches more to reach back there.
On the radiator support is one or two "dog-bone" braces that attach to top of engine. Remove the long bolt from both braces (15mm wrench or socket on the bolt and nut). On one of the dog-bones is a hole on the underside, see it? You have to lever or pry the engine forward, and fit the long bolt you removed back into that same slot, but with the hole in the dog-bone there where the bolt goes through the hole when it is re-inserted. This pulls the top of engine over towards the radiator by 2 or 3 inches. That's all you get to work on the backside, but it usually suffices. Remove the exhaust pipe from the exhaust manifolds, and the bolts or nuts for the exhaust manifold, any other obstructions (the O2 sensor connector, for one), and pull the manifold off. Clean gasket surfaces, place new gasket, and re-install.
Good luck.
Feb 09, 2012 | 1991 Buick Regal
Ordered Fuego Multi-Function Task office chair via Office Max online on 6/14/2011. Received UPS delivery of chair on 6/15/2011. However, there are no assembly instructions included. How can I put it...
step 1: press the 5 casters into the holes on the star base (it's a firm press until they snap into place) turn it over so the wheels are on the ground and push the gas cylinder into center hole. place black sleeves over it. set it aside.
step 2: attach armrests to seat base using bolts (I) and washers (K) (the longer and thinner bolts and smaller washers) using the allen wrench supplied.
step 3: attach the seat plate (the thing with the 3 handles) onto the bottom of the seat cushion using bolts (J) and washers (L) ( the fatter and shorter bolts and larger washers) usint the same allen wrench.
step 4: place the set onto the base into the big hole that acceps it. then sit on it to ensure it stays, otherwise when you pick up the chair it will come off the base.
step 5: slide the seat back bar into the groove where the know shows at the back of the seat. you may have to loosen that knob first. when it is in, press the little black plastic button (M) into the hole at the bottom of that seat bar to keep it from sliding out when you pull it up to adjust.
step 6: play with the levers to learn how to do different adjustments.
step 7: congratulate yourself and be proud that you did it!
Oh, make sure all the bolts are tight before putting into use.
Jun 15, 2011 | Office Equipment & Supplies
I HAVE AN AVALON WOODBURNING FIREPLACE INSERT, INSTALLED APX 1993. I NEED THE SUPPORT ROD AND ROD WITH THE PERFERATED HOLES IN IT TO BURN MORE EFFICIENTLY. I AM NOT SURE WHAT THEY CALL THE PIPE WITH THE...
Avalon Wood Burning fireplace Inserts are manufactured by Travis Industries. They are very protective of the retailers and will not field any questions or sell parts directly to the customer. With that in mind, you'll have to go back to the dealer you purchased it from (if they are still in business) or go to the link below and search for the dealer nearest to you. The tubes you require are part of the "Air Wash System".
http://www.avalonfirestyles.com/where_to_buy/
Hope this helps. Please let me know.
Mar 15, 2011 | Heating & Cooling
We have a problem with two of the burners on our Bosch hob which refuse to stay lit, at certain times. The problem is confined the front burners (medium size), with the largest and smallest burners which...
Remove the brass burner heads.Remove the Butterfly nut ( in some models just a screw ) and remover the cast iron base.At the narrow end there is a nozzle with a small pin hole which couples with this pipe. Take a fine needle or pin and insert into the small hole and clean. Reassemble and Voila !!!! bobhifi.jpg
Mar 07, 2011 | Bosch NHT645SGB Gas Cooktop
I have water pooling in the bottom of the freezer compartment. My model is TPX24BPDA
This is most likely the drain hole that is blocked.
Remove the rear cover on the freezer inside to expose the cooling coils.
At the base there will be a channel leading to an outlet pipe.
Use a piece of PVC covered wire to clear the pipe by inserting about 8" into that hole.
Follow it with a squirt of anti-bacterial cleaner to kill off any mould in there.
Replace covers and drawers.
Mar 02, 2010 | Refrigerators
Replace antenna
Remove old Antenna
  1. Activate the antenna switch to the up position.
  2. Using the wrench or needle-nose pliers, loosen and remove the original retaining nut on the base of the antenna mast.
  3. Gain access to the underside of the area of the trunk where the antenna is located.
  4. Remove the bracket or brace that is below the hole and holding the antenna in place.
  5. Remove the mast.
  6. Find the motor that controls the antenna mast. Generally, power antennas will have a constant 12-volt lead and a ground lead. The ground lead will be grounded to the panel next to the motor.
  7. Remove the ground lead from the panel.
  8. Pull out the antenna coaxial cable.
  9. Unplug the coaxial from the extension coaxial cable.
  10. Remove the original antenna coaxial cable. Note the route the cable follows.
Install new Antenna
  1. Inspect the fender area where the antenna mast will be mounted for rust.
  2. Clean the area before installing the new antenna.
  3. Plug the new antenna coaxial cable to the extension coaxial cable.
  4. Plug the new antenna's coaxial cable into the radio's chassis antenna jack if there is no extension coaxial cable. Tie or tape the string you put on the extension cable to the new antenna coaxial cable. This assures that the 2 cables stay together as you route them to the antenna mount in the fender.
  5. Connect the power lead of the antenna to the power antenna lead on the radio.
  6. Connect the 12-volt constant lead to the antenna to a 12-volt source or to the ignition switch.
  7. Direct the new antenna cable via the same route followed by the original antenna cable on up to the hole in the fender in which the mast will be mounted.
  8. Ground the ground lead from the motor to a clean metal surface on the metal panel near the mount.
  9. Insert the mast into the hole. Face the serrated side of the plastic cable on the bottom of the mast toward the motor side. The plastic cable can be inserted freely to about 12 inches and will stop.
  10. Turn on antenna switch to down position until the plastic cable goes down and catches into the gear mechanism of the drum housing. If the plastic cable does not gear into the mechanism, twist the cable slightly until the cable contacts into the gear mechanism while the motor is in operation.
  11. Stop the motor after the cable goes into the housing 12 to 25 inches.
  12. Secure the bracket or strap to the bottom of the antenna mast and to the metal fender.
  13. Replace the retainer nut to the base of the antenna mast and secure tightly.
  14. Replace the panel that covers the antenna mount area.
Oct 16, 2009 | 1996 Honda Accord
Kitchen faucet Installation
Many new faucets require some assembly before mounting to the sink; if that is the case, follow the manufacturer's directions. With most pullout sprayer faucets, the sprayer needs to be threaded through the faucet body first. Insert the rubber gasket between the base plate of the faucet and the sink top to create a watertight seal. If no gasket is provided, pack the cavity of the faucet with plumber's putty, then insert the faucet body through the holes in the sink top. Thread the mounting nuts provided onto the faucet shafts, then center the threaded shafts in the sink's holes and tighten the nuts firmly. Many manufacturers include a special long socket specifically to aid in tightening the mounting nuts. A hole in the socket accepts the shank of a screwdriver, guiding it as you tighten the nuts. If you're mounting the faucet on an installed sink, use this method. If you're installing a pullout sprayer faucet--or a faucet with a separate sprayer--now is the time to connect the sprayer to the faucet body. Check the manufacturer's directions to see if using pipe-wrap tape for this connection is recommended. Use an adjustable wrench to tighten the connection. Most pullout sprayer faucets and faucets with separate sprayers come with a counterweight that attaches to the sprayer hose. This weight helps retract the hose back in to the sink cabinet after you've used the sprayer. Follow the manufacturer's directions on where to secure the weight, and take care not to crimp the hose as you attach the weight. Hook up the faucet's hot and cold supply lines to the water supply shutoff valves under the sink. If necessary, gently bend the copper tubes coming out of the faucet for better access and connect flexible supply tubes to them. Simply wrap a couple of turns of pipe-wrap tape around the threaded nipples on the valves and connect the tubes. Tighten the nuts with an adjustable wrench.
Aug 27, 2008 | Danze D316440RBT Fairmont Two Handle Wall...
Furniture Logo
593 people viewed this question
Top Furniture Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
